Old May 8th, 2014, 08:05 AM   #121
sprinter
Motorcycle(s): 2018 Ninja 400 Race Bike (in progress...)
Originally Posted by sharky nrk View Post
Very cool, I bet its a crazy difference. I am always shocked at how bad the brakes feel when I get off the 6R and back on the Ninjette.
Yeah, budget bike with budget brakes and budget suspension, that's what makes it fun to modify!
sprinter is offline   Reply With Quote
Old June 11th, 2014, 09:45 AM   #122
sprinter
Things will finally start happening with the bike build again, just got the new high-comp pistons from JE yesterday! 13.5:1 compression, stock bore, so it's going to probably take 50/50 mix or pure race fuel, we'll see. Once we get it back together we'll have to dyno it and get a PC-V map built. Hopefully in the next couple weeks.
I do have one extra set of JE pistons if anyone else want to bump up nearly 3 points in compression on their 300!
Old June 11th, 2014, 11:17 AM   #123
supersport
Motorcycle(s): Ninja 300
Awesome thread!
What size tire are you putting on the 4.5 rear?
supersport is offline   Reply With Quote
Old June 11th, 2014, 11:45 AM   #124
sprinter
Originally Posted by supersport View Post
Awesome thread!
I'm going to run the Bridgestone 250GP slicks, the rear is a 165/630.
Old June 11th, 2014, 12:10 PM   #125
sprinter
And now it looks like we'll be adding high lift cams too, thanks to a reference from supersport!
Here's the place selling them:
http://danielcrowerracing.com/i-5935...s-2008-14.html
Old June 11th, 2014, 01:28 PM   #126
supersport
Glad i can help. You gave us good insight on the possibilities from this thread and your other threads on web.
Old June 11th, 2014, 02:27 PM   #127
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
very cool, are you going to dyno and before and afters on this thing?
Old June 11th, 2014, 05:33 PM   #128
Badassssss! Keep us posted. I'd love to see a reliable 45 horse.
Old June 11th, 2014, 06:05 PM   #129
mgentz
Board Member
That is a lot of lift in those cams. Piston to valve clearance will most likely be tight and must be checked.
Old June 12th, 2014, 11:48 AM   #130
sprinter
Nah, just after to build the map, I don't really care what the HP number is all that matter is how fast will it go!
Old June 12th, 2014, 11:49 AM   #131
sprinter
Yeah for sure, especially since I have different pistons!
Old July 2nd, 2014, 02:41 AM   #132
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
@sprinter, may I ask you if you got your Marchesini's already because I would like to know what their weight is?
And also as information, the Galespeed GP1 used at the NSF250R in Magnesium are 1930 gr front and 2680 rear (2.5x17 and 3.5x17).
http://acv.co.jp/products/00708
Thank you in advance.
Old September 11th, 2014, 03:10 PM   #133
sprinter
I do have the wheels, but sorry I didn't weigh them.
Old September 11th, 2014, 03:13 PM   #134
sprinter
BIG progress today, IT RUNS!! Still need to get it on the dyno for a custom map, it's way too lean now, but at least we got it running and heat cycled the engine a couple times.
Feel the power! Ha ha!
http://youtu.be/Dlv3wbPlDEg
Old September 12th, 2014, 12:55 PM   #135
sprinter
Got her all together now, just needs some more decals and most-importantly to get on the dyno for tuning. There is plenty of clearance for the Bridgestone 250GP slicks, it's nowhere near rubbing the chain or swingarm. Should have more than enough grip. We also raised the Woodcraft rearsets up higher with some brackets for extra cornering clearance.
Old September 12th, 2014, 06:17 PM   #136
accumack
accumack's Avatar
Motorcycle(s): honda crf230l & 2013 ninja 300se wife has Honda crf230l & honda cbr250r repsol
Looks sweet can't wait for you to race it.
accumack is offline   Reply With Quote
Old September 12th, 2014, 08:38 PM   #137
Looking good I can't wait to see some scraping belly pan
But I don't see the most important part; where's that GoPro mount so I can see some hot laps??!?!
Old September 13th, 2014, 08:43 AM   #138
sprinter
I can do even better! I have the AiM SmartyCam GP HD camera and AiM Solo-DL data logger that I'm going to take off my other bike so I'll be able to get GPS data overlayed on the video!
Old September 13th, 2014, 05:44 PM   #139
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Sweet
Old September 16th, 2014, 05:19 PM   #140
whitejr60
Motorcycle(s): EX300, ZX-6R
Can you pass on information on the Ohlins MKII that you used? It appears to be a GSXR shock but was wondering if you re-valved it for the 300 or used it as it was shipped? I pulled the prints on SU789 today as it's the right length, but was thinking I need to re-valve it. the How did your MKII compare to the KA-841 you had on previously.
Also, let me know if you still have the spare JE pistons, as I would be interested it them.
whitejr60 is offline   Reply With Quote
Old September 16th, 2014, 05:26 PM   #141
JohnnyBravo
Guy did his homework
@whitejr60 welcome to the forum
Old September 16th, 2014, 06:30 PM   #142
whitejr60
Thanks Johnny for the welcome!
I've been racing for a lot of years, including quite a few years in Europe with FIM under a Dutch license. I just picked this 2014 300 up for my son and started the part selection process. So far I went with the K-tech cartridge which are to due to arrive Thursday because there's not many choices for this bike. Friends in Europe have use the K-Tech, so I at least was familiar with the brand. Ohlins offering is very low end for this bike despite the large amount of racing around the world with this bike. The only other component I have sourced this week is the exhaust, which is from M4. (Sponsor, can't beat the price).
I set myself up with a ZX-6R, which it mostly done except for new paint. Hope to have it paint in the next couple weeks.
Old September 16th, 2014, 11:09 PM   #143
JohnnyBravo
You're welcome.
Sounds like you have a lot of interesting stuff going on yourself! You may have stumbled into the right place!
Old September 17th, 2014, 06:42 AM   #144
sharky nrk
sharky nrk's Avatar
ommmnommmnommmnomm
Old September 17th, 2014, 07:22 AM   #145
sprinter
I'm not sure which model TTX it is, it was built by Andreani in Italy. I do still have one set of the pistons left, $300, just PM me.
Old September 24th, 2014, 10:39 AM   #146
sprinter
Just got it back from dyno, 40HP at the wheel, not bad for still being 300cc.
Old September 24th, 2014, 11:08 AM   #147
BlownWideOpen
BlownWideOpen's Avatar
Motorcycle(s): Stuff
Sweet! Do you think the 4.5's will hold a 170? Without clearance issues of course... I have 4.5's coming but decided on a 160/60. 170 sounds tasty.
Paint side up, rubber side down!
BlownWideOpen is offline   Reply With Quote
Old September 24th, 2014, 11:12 AM   #148
sprinter
The Bridgestone 250GP slicks I'm running are 165 profile and they fit fine with no clearance issues, so I'd suspect a 170 would fit too.
Old September 24th, 2014, 11:21 AM   #149
BlownWideOpen
What's the sidewall height, if you don't mind me asking? I'm worried about it nipping the front of the swingarm. The chain guard would have to go but no biggie.
Old September 24th, 2014, 02:11 PM   #150
What all have you done to the engine and what did that dyno give you for the stock setup?
Old September 24th, 2014, 02:43 PM   #151
sprinter
I'm not sure on the height, but there's at least an inch or more of clearance with the front of the swingarm.
Old September 24th, 2014, 02:57 PM   #152
whitejr60
I'm have a 170 mounted on my rear 5.0" wide Dymag for use during my construction stage and it clears fine. However, I wouldn't ride with this on the 300, as the 250GP profile tire is the better option. The 170 tire adds weight and the profile isn't as user friendly as the 250 tire.
This bike has a long wheel base and very relaxed rake, so the 170 would slow the transitions.
On my bike, I've added an aluminum swingarm with the 3.5/5.0" magnesium dymag and will mount fresh 250GP tires to hit the track. Up front I used 43mm forks, as they are lighter than the OE forks, with a 310 rotor paired with a 6 piston PFM caliper I had purchase for one of my supermotards but never got around to installing it.
I'll post some pictures soon but don't what to hijack sprinter thread.
Old September 24th, 2014, 03:15 PM   #153
sprinter
32hp stock with slip-on and power commander on that same dyno. I don't know bone stock. Mine has high-comp pistons (stock bore), hotter cams, ported heads, full Scorpion exhaust, power commander w/custom map.
Old September 24th, 2014, 04:28 PM   #154
whitejr60
Great numbers, who did you use for the cams? I got the Pistons today, thanks again.
I'm working on some over sized valves as well, would you be interested in a set?
Once mine is together, we'll have to try to get together for a track day. Ii don't know if I can make it happen before the end of your season, as you got a head start on me. I've only had this bike about three weeks.
Old September 25th, 2014, 05:28 AM   #155
BlownWideOpen
To be honest, I don't ride my bike hard enough/on enough twisty roads to notice a difference. A lot of my riding is light to light stuff. Just want something that looks better, and won't cause me hell. My front is lowered if that matters. As it is, it dives into corners hard, and it's fun enough for me Thank you for the feedback! Now to find a tire with a good enough track record that will fit.
Old September 25th, 2014, 06:10 AM   #156
whitejr60
You can use any trackday tire in a 160/60/17, as they all measure 170.
When you change tires, any change in diameter will change the bike's geometery. The large rear tire will bring the rear of the bike up and change the rake slightly if you keep the same front. This will reduce the amount of trail, lowering the fork also reduce the trail.
Old September 25th, 2014, 06:29 AM   #157
sprinter
Crower Racing did the cams. I've gone as far as I want to on the engine at this point, I was hoping for 40 HP and that's where it's at, so it's all good. We'll see at the track this weekend how it compares to the other 300's out there.
I also weighed the bike now with the Marchesini wheels on, and we're at 321 lbs. with very little fuel, so it appears the wheels dropped about 9 lbs. Bone stock was 359 lbs. My winter project this year will be to drop those last 21 lbs. from it to get down to 300 lbs., which is the goal. I think it will be easily achievable by cutting off the subframe and replacing all of the heavy steel brackets in the front of the bike with some custom aluminum pieces. If that's not enough, then I'll look into one of those aluminum swing arms.
Old September 25th, 2014, 06:45 AM   #158
BlownWideOpen
Any sound clips of it with the cams?
Old September 29th, 2014, 02:18 PM   #159
sprinter
First track weekend is now complete, had a great time on the 300. It's definitely got more "go" than it had before. I had a little advantage on the straights over any of the other 300's. Compared to a bone stock 300, I could pull up next to it on the straight look over, wave, and then twist the throttle and pull away. Pretty big difference. With the guys who have race bikes that are lightened, full exhaust and tuned, I still had a noticeable power advantage, with a similar weight rider. Doesn't necessarily mean I can lap faster, but I never got passed on the straights! Ha ha! I have to ride quite a bit below the limit since I'm running the events, I can't afford to get hurt. I think if I can get out to a race round or two next year I can go pretty quick on it.
Old September 29th, 2014, 06:02 PM   #160
howlinhoss
Mother of god...
howlinhoss is offline   Reply With Quote
