July 6th, 2013, 02:18 AM | #1 |
Wiring
Hi folks,
So I bit the bulletin and got some heated handle grips- came out good they are all installed just waiting to be wired up I tested them out on the battery so I know they work and I'm just left with the question around how to wire! For some reason those "spare" wires don't seen to be getting current, so I think I'll just buy a relay and wire it to he battery- ca someone explain to me the basic functns of what a relay actually does? |
July 6th, 2013, 04:53 AM | #2 |
Join Date: May 2013 Motorcycle(s): '89 klr 650, '00 250r Posts: 177
my understanding is a relay basically has two circuts. the best example is the headlight. when you turn on the ignition, the headlight does not come on but when you thumb the starter, regardless if the engine comes on or not, it goes through the headlight relay which in turn triggers the second circut in the relay, turning on the headlight.
personally, i would wire it up from the battery like some do for heated vests. then put the the toggle switch on the handlebars, so you can turn it on and off at will, rather then on and off with the bike. |
July 6th, 2013, 05:03 AM | #3 | |
Read the answer to your questions here: http://faq.ninja250.org/wiki/Electrical_%26_Lighting
July 6th, 2013, 05:51 AM | #4 |
Aimless
Join Date: Feb 2013 Motorcycle(s): 01 ninja 250 Posts: 69
Did you check your fuses? When I first used my heated gear this spring off the accessory leads I was getting no power. Changed the fuse and no problem since.
I just dropped in to see what condition my condition was in |
July 6th, 2013, 12:07 PM | #5 | |
But bear in mind that the Ninja 250 doesn't generate a huge surplus of power. It might be a better idea to just carry a small gel cell with you.
July 7th, 2013, 05:02 AM | #6 |
All done! Ended up joking to battery direct ! They seem to work not too bad for 5 bux!
July 8th, 2013, 08:20 AM | #7 |
Join Date: Sep 2012 Motorcycle(s): gsf1200, gsxr750, r6, gpz400, gpx400r, zx6d Posts: 21
i ran the set or oxfords i put on the battle ninja direct off the battery but threw a relay that is powered on with the headlights. so no one can hit the on button and drain the battery.
Help with wiring | gasguzziler | 1986 - 2007 Ninja 250R Tech Talk | 6 | May 21st, 2014 10:57 AM |
ignition wiring | rabies | 1986 - 2007 Ninja 250R Tech Talk | 7 | August 13th, 2013 08:19 AM |
Wiring help | Avenged7Fold | General Motorcycling Discussion | 1 | November 13th, 2012 02:02 PM |
Coil wiring? | expat | 2008 - 2012 Ninja 250R Tech Talk | 2 | February 26th, 2012 07:57 PM |
Wiring up for GPS | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 13th, 2009 04:20 PM |
