Old March 30th, 2015, 12:24 PM   #1
Dsheumaker
Dsheumaker's Avatar
Motorcycle(s): 14 Ninja 300 (Track Only), 07 CRF150RB
Header Stud Came Out of the Block??
So as i am going through my new 250, i wanted to remove the exhaust system to clean it up since parts of it were rusty. One of the studs came out of the block.. .What do i do? Just treat it as a bolt now? Ive never had this happen on any bike that i have owned so im at a lose and a quick search didnt yield any results.
Dsheumaker is offline   Reply With Quote
Old March 30th, 2015, 12:54 PM   #2
gantt
gantt's Avatar
Motorcycle(s): 2019 Ninja 400, Sold 2012 Ninja 650, Sold 2009 Ninja 250r, Sold 2007 DRZ400s
I would run a tap through the threads in the block to be sure they are ok. if any damage happened the tap will clean it up, as long as it wasn't bad. as for installing, if you can run the stud back in by its self do it. if not run it in with the nut and torque it the same as always.
gantt is offline   Reply With Quote
Old March 30th, 2015, 06:05 PM   #3
verboten1
verboten1's Avatar
MOTM - June '15
Replace it with a new one. And new nut. I fought this on my KLR for years before replacing it.
Ride more, worry less.
Old March 30th, 2015, 06:44 PM   #4
Dsheumaker
Dsheumaker's Avatar
Any damage in reusing the old one?
Old March 30th, 2015, 08:58 PM   #5
There is always corrosion slowly happening between the steel of the stud and the aluminum of the block.
Check if the stud feels too loose inside the thread.
If so, there is some damage in the aluminum thread that will only become worse with time, temperature cycles and vibrations.
Some high temperature mild thread locking compound may help there.
If not, just place two nuts jammed against each other at the external end and use them to drive the stud in as deep as safe, not over-torquing much.
Exhaust header stud broke jcgss77 1986 - 2007 Ninja 250R Tech Talk 17 February 3rd, 2020 08:58 AM
[roadracingworld.com] - Isle Of Man Government To Conduct Comprehensive Economic Stud Ninjette Newsbot Motorcycling News 0 November 14th, 2011 01:00 PM
[roadracingworld.com] - Former AMA Pro Racer Dean Mizdal To Speak To High School Stud Ninjette Newsbot Motorcycling News 0 February 23rd, 2011 11:40 AM
[roadracingworld.com] - Former AMA Pro Racer Dean Mizdal To Speak To High School Stud Ninjette Newsbot Motorcycling News 0 February 22nd, 2011 06:10 PM
[superbikeplanet.com] - Chaz Davies: Spud Stud Ninjette Newsbot Motorcycling News 0 August 5th, 2010 10:30 AM
