October 3rd, 2011, 08:32 PM | #1 |
Join Date: May 2011 Motorcycle(s): 2002 ZZR 250 Posts: 127
Engine Grinding noise,cam chain?
Hello, I was out riding my bike and all the sudden I heard strange noises and lost power. Tore the engine apart and everything in the top end was fine. Bottom is fine my bike is shifting fine and will move forward slowly. Put it back together and it starts but has the loud sound again and im pretty sure its the cam chain loose. I took out the tensioner and reinstalled and still got the noise. On-top of this when i start my bike and im getting this noise if i try to rev it higher than 3k it will stall out. can it still be the tensioner?
October 13th, 2011, 07:24 AM | #2 | |
October 16th, 2011, 04:59 AM | #3 |
CBR? This is ninjaaaaaa!!
The rattle can be caused by a loose clutch basket. As far as the stalling goes.... I have no idea.
You mean when you rev it up past 3k it returns back to and BELOW 1k rpm and stalls? |
October 16th, 2011, 05:50 AM | #4 |
The clutch basket is pretty common, but in this case, i don't think that's it. He said it happened suddenly while he was riding. Unfortunately, he didn't say what the noise actually sounded like.
If the cam chain slips, the engine wont usually run at all. The spring cam tensioner actually works pretty good. There is a slider inside there that pushes against the chain. That could fail, but honestly, I've never heard of anyone claiming that it did. Since he's got it all apart, it wouldn't hurt to examine the chain and associated parts. Hopefully he will post with more data soon.
October 18th, 2011, 10:47 AM | #5 |
Video of engine problems help!
anyone know what this sound is ? the engine turns and runs but as soon as i give it throttle it starts to die.
October 18th, 2011, 10:51 AM | #6 |
October 18th, 2011, 11:01 AM | #7 |
/merged with original thread
October 18th, 2011, 11:17 AM | #8 |
Have you checked the compression of the cylinders yet? That may explain the lose of power. It also sounds as if the timing may be a little off now as well.
October 18th, 2011, 03:33 PM | #9 |
A few suggestions...
There are a lot of things that can make it do that.
You said you tore it apart. Did you check the valve clearances when you were in there? Also, I just did my valves and I was reading about people who had bikes swallow up rocker arms. Did you check to make sure there are all 8 in there? Checking compression will also tell you a lot. Check the low voltage wires to the coils and make sure they haven't come loose. Also check the fuses. I can't tell if the ZZr is a 2-2 or a 2-1 exhaust. If you have 2 mufflers, start it again and feel the two exhausts for significant differences in pressure. They should be identical, but if not, its a clue. A lot of times when an engine suddenly starts acting up while you are going down the road the problem is electrical. The most obvious thing is a malfunctioning spark plug. Time to change those if you haven't already. Check to make sure the coils are working and that each plug is actually firing. If you are using champion plugs then that is your problem right there. It really sounds like one cylinder is working and the other isn't. That's my guess. I would check the electrical first because its easier, but then it could also be a plugged carb. Do you have an inline filter? Not sure if they have ethanol in the gas up there, but here it causes all sorts of problems. A clutch basket isn't causing your problems. I seriously don't think its a cam problem or it wouldn't run at all. The cam chain should be tight and you shouldn't be able to pull it away from the teeth. That isn't to say its good. If a rocker broke loose and got wound up in there, the cam chain could be damaged even though its still working.
October 19th, 2011, 11:27 AM | #10 | |
October 19th, 2011, 12:13 PM | #11 | |
I suggest you rotate the engine several times and watch to see if the valves operate like they should. The cam chain failing is a possibility, but its pretty remote.
October 19th, 2011, 02:54 PM | #12 |
I watched the video you posted. It sounds like an EX-250 engine running on only one cylinder. They'll run on one cylinder, I've actually ridden around the block on one cylinder. On one cylinder the EX-250 engine sounds totally different than it normally does, it's really down on power, it bogs, it won't rev any higher than about 4,000.
Have you confirmed that both sparkplugs are firing, getting good spark? Hold each spark plug near a piece of metal (that you're not currently touching!) and crank the engine over to see if a spark jumps. |
October 25th, 2011, 03:56 PM | #13 |
im almost sure its the valves, how do i tell if they are normal when im turning the motor by hand?
And my plugs are good i just put in new ones and the old ones were fine too and its not my carbs because i turned the screws and they are leaking good And its not a hole in the piston because when i took the top end apart they looked nice and new |
October 25th, 2011, 06:58 PM | #14 |
When you had it apart, were you able to get a look at the cylinder walls?
There are 3 reasons why a cylinder could have low compression: 1) The compression rings are not working like they should which could be either they are broken or the cylinder is gouged. 2) The valves are leaking, or opening at the wrong times. 3) You have a leaky head gasket. The number of miles on the engine are helpful in figuring out which one. Did you look to see if all 8 rocker arms are still in there? And working?
October 26th, 2011, 03:58 PM | #15 | |
i did a leak down and 80% in the exhaust valves, how do i fix this any help? Only 15000km on the bike and yeah all 8 rocker arms are there and working |
October 26th, 2011, 04:30 PM | #16 | |
But I can say that if you are sure the valves are adjusted properly and the rocker arms are working and present, its time to pull the cams and head and closely examine your valves and timing chain. Timing chains don't usually break, they stretch. If its especially loose, it might have hopped a tooth. But the tensioner should have picked up the slack on an engine with only 9000 miles on it. A kawi engine failing at only 9K miles is very rare. But having a radically lower compression in one cylinder says there is likely something wrong with the valves. If I lived up there I'd come over and give you a hand, but instead, maybe check with a kawi dealer and see if they will let you talk to their mechanic to see if he's heard of anything specific to your bike. Maybe offer to buy him lunch at McDonalds. Broken Kawi 250 engines are rare like diamonds, just not as valuable. PS- In case you didn't already know this, there are two TDC marks on the flywheel on the left side of the bike. The left TDC cylinder is marked "1T" with a line through it so it looks like "1|T". And the right cylinder TDC is marked "2T" or "2|T". I think there is also a "1D" or something in there too, but ignore that one.
October 26th, 2011, 05:55 PM | #17 | |
As for the timing chain i thought i heard it slipping but i opened it back up and they were lined up perfect at 33 teeth like its suppose to be. I dont see how anything coulda got stuck as this happened while i was riding how do you check to see inside the valves? Like i know how to take apart the whole engine im just not sure how you remove the valves or inspect them or anything like that. |
October 27th, 2011, 07:30 AM | #18 | |
I have a hard time thinking it has anything to do with the cams. If the cam chain was bad or maladjusted, it would affect both cylinders and not just one. Its pretty rare for an engine with only 9K miles on it to fail. Is there a chance that you let the engine run without oil? Or overheat? I have never done anything more serious to my Ninja than a valve adjustment so I'm basing this on what I know about other engines. Typically, to get the valves out, you have to use a valve spring compression tool to squeeze the springs down and get the valve keepers out. These are little wedges at the top of the valve stem. I've attached diagrams in case you don't already have them. The tool is two parts: a big C-clamp 57001-241 and the adapter 57001-1202. These are very expensive from kawi so I'd look around for other sources. You could probably weld one up from a standard C-clamp and a short piece of steel pipe. But before you start, exactly what were the two compression measurements? Were they radically different? The normal compression for a Ninja 250 is 142-218 psi. If your values were in that range, then I wouldn't be too worried. Also, before you mess with the valves too much, I would drop about a tablespoon of marvel mystery oil down the spark plug holes and recheck the compression. If your rings are bad, the compression will increase dramatically. Here is what the manual says about low compression: 1. Gas leakage around the cylinder head - replace the damaged gasket and check the cylinder head for warp. 2. Condition of the valve seating. 3. Valve clearance - If a valve requires an unusually large adjustment to obtain proper clearance, the valve may bend, and not seat completely. 4. Piston/cylinder clearance, piston siezure. 5. Piston ring, piston ring groove. Let me know what you find out.
October 27th, 2011, 07:55 AM | #19 |
Another guy told me that if the valves are not seating properly, you can tell by checking the valve clearances because the valve will have a wide gap at TDC. The normal valve wear process makes the valves get tighter not looser with mileage. Have you checked your valve clearances? With METRIC feelers?
November 29th, 2011, 11:32 AM | #20 |
if anyone was wondering i found out what it was!
The valves were perfect like an arrow but it was the tensioner lever. not the tensioner but the lever it sits on had snapped off and made the cam chain loose which was messing up the timing/ firing should have her up and running for winter.. lol :P thanks for your help all! |
November 29th, 2011, 01:12 PM | #21 |
Glad to hear you found it. Its pretty rare for a failure with that few miles, but I guess somebody has to be the exception.
Are you referring to part #13168? Do you feel that this caused the low compression, or is it possible that you may have measured the compression wrong? I know that some people have replaced the standard tensioner with bolts. However, I am against that as it can easily put too much stress on the rocker and break it.
November 29th, 2011, 01:24 PM | #22 |
Glad you tracked it down. Good catch.
Just knowing that this unusual tensioner failure can happen might help some people in the future. Looking at your picture of the fracture sight it appears that part #13168 is cast from some really unimpressive metal, or is it dark colored plastic? Although, it certainly would more helpful if you would post your pictures in the correct orientation. Or do you hang the bike by the rear wheel from the garage rafters when you work on it? |
November 29th, 2011, 01:50 PM | #23 |
Yes it is part #13168?
well from what i was told the reason i would get bad compression is because the cam chain isnt holding anything in place alloying air to flow freely compression test should be good once its all fixed i added a explanation for anyone who is curious or for the future the pictures may look off because they are on the stand i built for my 250 in school :P its very cool ill post pics sometime |
November 29th, 2011, 03:12 PM | #24 |
You're probably right about the compression.
The part is $14 at RonAyers assuming its the same as the one in the Ninja.
Cam Chain replacement, possible engine damage | Ginganinja | 1986 - 2007 Ninja 250R Tech Talk | 113 | April 10th, 2014 05:08 AM |
Cam chain rattle noise | silentIm | 2008 - 2012 Ninja 250R Tech Talk | 18 | March 23rd, 2014 01:54 PM |
Engine Noise, Cam Chain Tensioner Problem? Pics And Video | az3200 | 1986 - 2007 Ninja 250R Tech Talk | 38 | August 27th, 2013 04:31 AM |
Grinding noise - chain questions | n4mwd | 1986 - 2007 Ninja 250R Tech Talk | 15 | October 6th, 2011 05:51 AM |
Strange noise from engine after tightening chain | Red'09250 | 2008 - 2012 Ninja 250R Tech Talk | 32 | June 9th, 2009 04:32 AM |
