Old July 10th, 2010, 05:30 AM   #1
Betlog
Betlog's Avatar
Motorcycle(s): 2009 250r
Ticking noise on front wheel?
When I am pushing the bike(while it's off and on neutral) I hear a ticking noise similar to the noise one hears when a card is hitting their bicycle spokes. Is this the mileage counter? Or is this not normal? Thanks for any info.
Betlog is offline   Reply With Quote
Old July 10th, 2010, 07:40 AM   #2
Sailariel
Sailariel's Avatar
Leo, You might want to check your speedometer cable. Does the speedometer needle pulsate in a regular pattern? Mine did, and it turned out to be a frayed speedo cable. The only other thing I can think of is that you may have gotten some debris on your disc rotor or in the caliper. If you have a compressor available, you might want to blow some air on the disc brake assembly. Good luck.
Old July 10th, 2010, 12:28 PM   #3
Yup, definitely not normal.
Old July 11th, 2010, 09:42 AM   #4
Betlog
Betlog's Avatar
Ok guys, I just had a chance to put the bike up on stands and free-wheel spin the front. Well, there's no ticking noise. I think it's just a piece of pebble wedged between one of the grooves on the front tire. Thanks for all the quick replies though!!
Old July 11th, 2010, 10:10 AM   #5
Ken08Ninja
Motorcycle(s): 08 Ninja 250R Candy Plasma Blue
Try putting the rear up on a stand and spin the rear tire. Maybe the chain is making noise on the front sprocket.
Ken08Ninja is offline   Reply With Quote
Old July 11th, 2010, 10:21 AM   #6
bob706
bob706's Avatar
+1
Old July 11th, 2010, 05:50 PM   #7
miks
I'm lovin' it.
miks's Avatar
Motorcycle(s): '09 Black 250R
Think my bike does the same/similar thing, is there any damage that could occur??
Son: When I grow up I want to ride a motorbike.
Father: You can't do both son.
miks is offline   Reply With Quote
Old July 11th, 2010, 06:21 PM   #8
Betlog
Betlog's Avatar
And if the chain is making noise on the front sprocket what does that mean?
Old July 11th, 2010, 06:22 PM   #9
Betlog
Betlog's Avatar
Good question, I'll defer to the mechanics and experts on this site...
Old July 11th, 2010, 11:08 PM   #10
Ken08Ninja
That you need to clean the excess chain lube / grime out from your sprocket. Or your rear tire alignment could be off causing the chain to ride one side.
Old July 11th, 2010, 11:14 PM   #11
miks
I'm lovin' it.
miks's Avatar
Just found out that my bike only makes the noise when I put the bike in neutral and hit the kill switch and let it roll. Is that normal??
ticking noise jcsalazar 2008 - 2012 Ninja 250R Tech Talk 5 October 29th, 2014 12:24 PM
Fix for front wheel squeak noise/Front wheel removal cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 13 April 23rd, 2014 12:25 PM
Whistling Noise from front wheel? BlackNinja8 2008 - 2012 Ninja 250R Tech Talk 3 March 18th, 2012 08:35 PM
Noise from front wheel sherbear 2008 - 2012 Ninja 250R Tech Talk 3 May 19th, 2009 09:48 PM
Help - squeaking noise coming from front wheel / fork? muffinman 2008 - 2012 Ninja 250R Tech Talk 5 March 17th, 2009 05:11 PM
