Old November 25th, 2014, 06:11 AM   #1
agentbad
agentbad's Avatar
How long do you go between new chains?
I am at about 12k on my bike and the oem chain still seems like it's in pretty good shape. I'm asking because my friend has a Rebel with 40k and he's only replaced the chain once.
Old November 25th, 2014, 07:32 AM   #2
flitecontrol
Motorcycle(s): Rebel 250s, Ninja 250s VN750s (currently nine total)
A lot has to do with the quality of the chain and the level of maintenance it receives. Some folks still put new chains on old sprockets because they think the sprockets look good so they must be fine. Not necessarily so. Unless a sprocket is badly worn, it's difficult to eyeball it and determine whether it needs to be replaced or not.
Regular cleaning and lubricating with a good quality chain lube will greatly extend chain life. One of my Rebels has a DID X-ring chain with over 20,000 miles on it, and no signs of wear. The OEM chain that was on it when I bought the bike from the PO hadn't been well maintained. It was rusty and had missing O-rings at 7,000 miles.
An easy way to tell if a chain needs to be replaced, other than frozen links and missing O-rings, is to grasp it at the three o'clock position on the rear sprocket and try to pull it back. If it moves more than a fraction of an inch, it is worn and should be replaced. Again, both sprockets should be replaced at the same time the chain is.
flitecontrol is offline   Reply With Quote
Old November 25th, 2014, 07:36 AM   #3
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
My first chain lasted ~10k miles but I got salt and **** on it and left it out in the rain/rode through the rain which accelerated the wear. I also started getting lazy about cleaning/lubing it. My current chain has 500-1000mi on it and is beginning to show signs of corrosion from being out in the rain, I need to clean and lube it real quick soon.
Really it's one of those things that'll last forever if you can keep it out of the elements and clean it properly but won't last terribly long otherwise.
Old November 25th, 2014, 07:44 AM   #4
Bigballsofpaint
Scottoiler will pay for itself if you are a little lazy about chain maintenance. i have about 10k on my 250 chain, and 15k on my 1000 chain. Both dont need replacing. Scott oiler on the 1000 since its my main bike. Installed it around 2,000 miles, the 250 was always cleaned and waxed every 500 miles before it was a track bike. Now i just clean and lube before each track day.
Old November 25th, 2014, 07:46 AM   #5
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I've wanted a scott oiler for the longest time, I'll probably invest in the next year or so. Also 500mi isn't often enough for me unfortunately. That's around the rate I was cleaning it.
Old November 25th, 2014, 08:11 AM   #6
Ghostt
Ghostt's Avatar
Thumbs up
My 2¢ on chains,
If you properly maintain your chain, it should last awhile, no really set mileage.
Proper maintenance includes cleaning, lube, and correct adjustments.
I myself use the DuPont Teflon spray, here is a link to review,
http://www.webbikeworld.com/t2/motor...n-chain-saver/
http://www.webbikeworld.com/t2/dupon...ain-lube-2012/
I generally clean and lube my chain about every third tank of fuel, on my Ninja 500 I've managed to get close to 20k miles out of a chain, I replaced it when it started to stretch like crazy.
violente et ignorantia
ZX-2R BLOG
Old November 25th, 2014, 08:24 AM   #7
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
keep it clean and lubed, and they last 20-30k.
TEAM ALFALFA
www.apexassassins.com
Old November 25th, 2014, 08:45 AM   #8
Hero Danny
Inline 4!!!
Hero Danny's Avatar
As long as you don't ride in the winter (where there is road salt) and you properly maintain your chain, I could see you getting 30k miles out of. Maybe more maybe less. Regardless, if it looks good then mileage doesn't matter
Be careful. Remember you are
invisible
Old November 25th, 2014, 08:46 AM   #9
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Yeah, I was lubing my chain every 200 miles and cleaning it every 500. Isn't it funny how the bike feels faster after lubing the chain?
invisible
Old November 25th, 2014, 09:05 AM   #10
allanoue
allanoue's Avatar
MOTM - Sep '14
I cleaned my chain about every 2000 miles. The chain has 21,000 miles on it, and needs to be replaced. No issues with it under 60 mph but no highway speeds until I replace it.
Old November 25th, 2014, 09:10 AM   #11
verboten1
verboten1's Avatar
MOTM - June '15
wow, If I think about it I might do it once a month or so. a ride is usually 200 at least.
I replace the KLR chain about every 10-15,000 miles which is about a year typically. It's lucky if I take the mud off when I am done off road.
The ninja chain is original I'm sure. at about 8,000 miles, it seems fine, the sprockets are wearing, but the chain is fine.
I'll probably replace at the end of next year, just because.
Ride more, worry less.
Old November 25th, 2014, 02:06 PM   #12
fast1075
Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite
Wink
I had a bike once that needed new chain and sprockets every 25 miles .
Did I mention it had a 10" slick and 300+ horsepower?
"They don't pay me enough to ride this thing!" Kenny Roberts after winning the Indy Mile on the TZ750 powered Grand National bike.
fast1075 is offline   Reply With Quote
Old November 25th, 2014, 02:10 PM   #13
Ghostt
Ghostt's Avatar
Talking
KLRs run better when their dirty, proven fact
ZX-2R BLOG
Old November 25th, 2014, 02:53 PM   #14
snot
sammich maker
snot's Avatar
MOTM - Apr '15
I inspect mine regularly, I do a quick lube during the season and a good such and lube before my first ride of a new season.
+1 on changing the sprockets at the sametime.
Racing chains? Diablita Ninjettes At Speed 11 March 6th, 2024 08:49 AM
All about chains Sirref 2013 - 2017 Ninja 300 Tech Talk 27 September 1st, 2014 10:33 AM
Any others using Silicone on their chains caltony General Motorcycling Discussion 1 May 21st, 2014 07:07 AM
Chains? quadcrazy 2013 - 2017 Ninja 300 Tech Talk 2 January 22nd, 2014 06:03 PM
sprockets and chains xA2D9 2008 - 2012 Ninja 250R Tech Talk 2 April 17th, 2012 05:44 PM
