Old July 4th, 2014, 10:46 AM   #1
agentbad
agentbad's Avatar
Should float height stay stock after rejetting?
When I first rejetted my bike it ran really smooth and idled perfectly. After getting the valves adjusted and float needles replaced in the winter of last year I have noticed the idle is bit more shaky and the launch from first gear is a bit sluggish. Getting the bike going in the morning even when it's warm it hesitates for the first maybe 10 seconds then its good to go. I'm running 112 mains, 40 pilots, no shims, and fuel screw at 3 turns out. Should I mess with the float height to see if that helps? I already went up .5 on the fuel screws with no noticeable difference.
Old July 4th, 2014, 05:35 PM   #2
j98sprint
Motorcycle(s): '02 Ninja 250, '98 Triumph Sprint 900, '69 H-D Sportster XLCH 900
Nope. Float height stays stock.
j98sprint
j98sprint is offline   Reply With Quote
Old July 4th, 2014, 07:29 PM   #3
Originally Posted by agentbad View Post
........ After getting the valves adjusted and float needles replaced......
You should verify float heights each time that you change float needles.
http://faq.ninja250.org/wiki/How_do_..._the_floats%3F
http://faq.ninja250.org/wiki/How_to_...e_your_jetting
Don't guess, measure and experiment instead.
Old July 6th, 2014, 10:44 AM   #4
agentbad
agentbad's Avatar
j98sprint
Okay thanks.
Perfect thanks.
Need help asap with float needle height M42 1986 - 2007 Ninja 250R Tech Talk 2 September 24th, 2014 01:14 PM
stock fork height over triple tree Lychee 1986 - 2007 Ninja 250R Tech Talk 10 August 30th, 2013 01:12 PM
EX250R stock fork height Kangxi 2008 - 2012 Ninja 250R Tech Talk 6 February 23rd, 2012 06:25 PM
Raise rear back to stock height EddieNewYork 2008 - 2012 Ninja 250R Tech Talk 11 July 15th, 2011 03:18 PM
Carb tuning take 2 - AEM wideband info & has ANYONE adjusted float height? rwheelz 2008 - 2012 Ninja 250R Tech Talk 6 March 30th, 2011 06:43 AM
