Old November 4th, 2009, 03:54 PM   #1
ThunderBlue250
ThunderBlue250's Avatar
Motorcycle(s): 2009 Candy Thunder Blue Ninja 250
Looking at a high mileage bike, what should I look for?!
Hi, I found a bike that I was thinking of buying as my last deal fell through at the last minute. (Someone offered the seller full price literally the day I was supposed to come and pick it up), anyways, It's a 2009 special edition, with 8,100 miles. Has had three dealer services at 600/4,000/7,500 miles. Never been laid down or in an accident. He's looking for 2,500$. What should I look for or consider, as this is the highest mileage new style 250 that I have seen. Thanks guys
"Respect All, Fear None"
ThunderBlue250 is offline   Reply With Quote
Old November 4th, 2009, 04:06 PM   #2
Midnightrider
Motorcycle(s): Black 09 Ninja 250
Neglect destoys motorcycles, not mileage.
Midnightrider is offline   Reply With Quote
Old November 4th, 2009, 04:13 PM   #3
nate-bama
North Alabama Mtn. ryder
nate-bama's Avatar
Motorcycle(s): 2006
umm would you consider a honda high mileage with 50000 miles? that bike should be fine, actually my 2 cents is it's just broke in...remember it's not a 1984 chevy
QTRltrPWR
nate-bama is offline   Reply With Quote
Old November 4th, 2009, 04:40 PM   #4
untdavid
Motorcycle(s): Candy Plasma Blue 250r
Sounds like the bike is just broken in. I would follow up on the maintenance and get records from the dealer it was taken too. Good Luck on your purchase!
David
untdavid is offline   Reply With Quote
Old November 4th, 2009, 05:08 PM   #5
HKr1
IC2(SW)
HKr1's Avatar
3 oil changes in 8000 miles! Dam, Kelly did that many in 150
Old November 4th, 2009, 06:04 PM   #6
ThunderBlue250
interesting, I'll make sure he has the records. For some reason I thought that was worth than it appears to be.
Old November 4th, 2009, 06:06 PM   #7
andrewexd
andrewexd's Avatar
Motorcycle(s): 07 GSXR600 (N250 sold :( )
3 dealer services doesn't mean 3 oil changes... If you like the bike go for it. 8k is not alot of miles in the long run, the only problem is that you will probably have a harder time re-selling it. btw, why do you want another 250 ?
andrewexd is offline   Reply With Quote
Old November 4th, 2009, 06:10 PM   #8
ThunderBlue250
I'm not looking for another one. I thought I had the first one locked up and it was a bit of a drive from my house and someone came down with the money before I could get there. So I am, as of now, unfortunately ninjaless
Old November 4th, 2009, 07:12 PM   #9
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
My 2009 250 turned 1 year old on friday and has 8900 miles. Got the valves adjusted. Have changed the oil 3 times. Rear tire flat in the middle yet still showing wear markers (will replace soon). front tire in good shape. Brakes still have plenty of pad left. So I would say go for it.
Old November 4th, 2009, 07:31 PM   #10
Damn. That's considered "high" mileage? I'm significantly higher already.
Old November 4th, 2009, 09:31 PM   #11
it's due for it's first valve inspection/adjustment. Has that been done? if so, I'd say that's a good deal. Typically, the valve adjustment runs a couple of hundred dollars at least.
Old November 5th, 2009, 01:08 AM   #12
Well, that's what was supposed to happen at 7,500 miles, so if it truly "Has had three dealer services at 600/4,000/7,500 miles," it should have been done. FWIW, I couldn't get it done for less than $330.
Old November 5th, 2009, 06:21 PM   #13
In Rhode Island 2 hours @$75 per hr to check + 1 more hour if adjustment needed.
Old August 26th, 2010, 03:45 PM   #14
road_rascal
Motorcycle(s): ___
I would be more concerned about a ten year old bike with 1K-5K miles on it than a newer one with 15-20K.
road_rascal is offline   Reply With Quote
Old August 26th, 2010, 10:14 PM   #15
GeneJunkie
GeneJunkie's Avatar
Ryan's Buell is just barely a year old had has 8,000 miles on it, I wouldn't say it's high mileage. Seems like a good deal imo as long as service has been kept up on it.
GeneJunkie is offline   Reply With Quote
Old July 13th, 2013, 10:55 PM   #16
sunspots
sunspots's Avatar
Motorcycle(s): 08 Plasma Blue 250
Thats an awesome price for a 2009.
I picked up a 2008 with 7700 miles 2 weeks ago for $2250. Best purchase I've ever made.
My friend who rode the bike back for me was really impressed by it, he owns an R6 and said that the clutch control and shifting on the bike was really nice and that it accelerated very smoothly and well.
sunspots is offline   Reply With Quote
Old July 14th, 2013, 12:40 PM   #17
Driddle
Driddle's Avatar
This thread is almost three years old..
2008 Kawasaki Ninja 250r | Yoshimura Stainless Full Exhaust | Pazzo Levers | Puig Double Bubble | DynoJet Stage 2 | K&N Intake |
Driddle is offline   Reply With Quote
Old July 14th, 2013, 01:21 PM   #18
verboten1
verboten1's Avatar
MOTM - June '15
So where's the high mileage bike you are asking about?
Ride more, worry less.
Old July 14th, 2013, 03:20 PM   #19
sunspots
sunspots's Avatar
lol what the ****
I was looking through "new posts" and this thread was on the first page.
dammit now I just feel silly
Old July 14th, 2013, 05:34 PM   #20
rcruz17
rcruz17's Avatar
Motorcycle(s): 09 250r
lol what the ****
I got mines with 13k and so far its been smooth sailing and no signs of problems either.
rcruz17 is offline   Reply With Quote
Old July 14th, 2013, 07:42 PM   #21
dwright0723
Motorcycle(s): 08 Ninja 250
lol what the ****
dwright0723 is offline   Reply With Quote
Can the ninja handle high mileage GREY NINJA General Motorcycling Discussion 80 November 12th, 2022 07:50 AM
High Mileage Ninjettes eddiekay General Motorcycling Discussion 32 May 9th, 2014 07:15 AM
what would be considered high mileage? michael38 General Motorcycling Discussion 12 July 4th, 2012 02:00 PM
Riding a bike that's too high... ninja_sleeper Riding Skills 38 April 13th, 2012 12:34 PM
[topix.net] - BMW's high Mileage award for that special motorcycle moment Ninjette Newsbot Motorcycling News 0 June 29th, 2011 09:00 AM
