#1 |
Opinionated individual :)
Join Date: May 2011 Motorcycle(s): 2010 Ninjette Special Edition (red/black) Posts: 342
Notes for Kkim regarding California model "Gettin Nekkid", gas tank removal, carbs
Gettin Nekkid
5mm allen for bottom rear of fairings (no washer) 4mm allen for top forward of fairings (plastic washers) Medium size flathead screwdriver for plastic rivets on underside of fairings. #2 phillips for press rivets on front inside of fairings. 4mm allen for screw no washer on inside front CALI gas tank removal Seat bolts are 3/16 IMPERIAL allen (NOT 5mm, they are very close in size and 5mm WILL STRIP the bolt) 10mm bolts holding tank down 3 hoses on front left of gas tank (unmarked, blue sticker, red sticker) red hose spits a little gas when removed :P carb screws: all black on carb one, all silver except one black on carb 2 Ill post up relevant pictures here soon enough as well. Hoped this would help out other newbies and prevent people from guessing at bolt sizes and stripping stuff. ![]()
Yoshi slip on, shimmed 2 washers, zip tie throttle mod, pre-load #2, snorkel delete 2010 SE 250R! Miles in the saddle: 1000 |
#2 |
Usually, you'd want to put something like this in the actual thread it's relevant to.
![]() That said, I have a folding metric hex set that fits the two bolts under the rider seat just fine. I doubt it's SAE/Imperial. |
#3 | |
And im dead sure it 3/16". I have a whole set of "security bits" with every head you could imagine. The 3/16" fit perfect. Pictures to come soon of the cali gas tank and wierd kleen air system.
#4 | |
![]() That said, I've never found the seat bolts too tight at all. In fact, I've seen complaints about them working out on their own! Are we both talking about the same thing? I'm talking about the two bolts holding on the rider's seat that are only accessible after taking off the side panels. |
#5 |
Yup, thats them
#6 |
3/16" is too small and will round it out. They are 5mm. This is on a Federal model.
Always get a second opinion because most of these people are makin' this stuff up ![]() |
#7 |
I would imagine everything is metric since it's a Japanese bike assembled in Thailand. I haven't had any issues with 5mm (aren't they the same bolt as the bottom fairings as well?).
#8 |
Join Date: Sep 2010 Motorcycle(s): 10 Ninja 250R Posts: 160
Yessir, same bolt as the bottom fairing bolts. And I have never had ANY issues with using a 5mm.
#9 |
Internet Slut
Join Date: Sep 2010 Motorcycle(s): 04 FZ1, 07 FZ6 Posts: A lot.
Yup 5mm hex works just fine, as far as I can tell you can do anything to these bikes with a 8 mm, 5 mm, 4 mm hex, #2 driver (jis is best) #3 driver (if taking off bar ends) 10 mm, 17 mm socket/wrench can pretty much take the entire bike apart with those.
Strange "marks" on the gas tank | Hero Danny | General Motorcycling Discussion | 4 | June 27th, 2014 07:00 PM |
WTB: 08+ Gas Tank(red) Front Upper Cowling "Bracket?" | xaple | Items Wanted | 3 | January 23rd, 2013 05:46 PM |
[topix.net] - "The Fonz", "Ralph Malph" & "Potsie" are giving away Fonzie's motorcycl | Ninjette Newsbot | Motorcycling News | 0 | August 16th, 2012 04:30 PM |
08+ Ninja 250 CA model Gas tank port questions (Evap System Removal) | abhijitz | 2008 - 2012 Ninja 250R Tech Talk | 2 | April 3rd, 2012 09:59 PM |
KKIM dowm line "MALAYSIA" | kirana | New Members | 6 | January 18th, 2009 11:25 AM |
