February 4th, 2012, 01:31 PM | #1 |
Join Date: Mar 2010 Motorcycle(s): 2008 Ninja TwoFiddy Posts: 160
Bike has been sitting for 9 months and won't start
Bike has been setting for 9 months and won't start. It seemed at one point it wanted to start. I recharged up the battery. I going to dump out the gas and add fresh gas. Is there anything else I should do?
Thanks |
February 4th, 2012, 01:33 PM | #2 |
Clean the carbs
February 4th, 2012, 02:12 PM | #3 |
February 4th, 2012, 02:19 PM | #4 |
Here's two pages about that. Sorry about the pictures on the thread from ninjette. The method from the FAQ section of ninja250.org has plenty of pictures though.
http://www.ninjette.org/forums/showthread.php?t=65198 http://faq.ninja250.org/wiki/How_do_...n_the_carbs%3F I recommend soaking them in pine-sol overnight (that's what faq.ninja250.org recommended somewhere in their wiki as a method of soaking them that won't damgae plastic or rubber parts in the carbs) and then using compressed air like kkim recommends. Personally, I wouldn't use a brass wire like the faq recommends. Just me. |
February 4th, 2012, 02:35 PM | #5 |
Super Noob
Join Date: Oct 2011 Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc Posts: A lot.
Before you go ripping your bike apart...I'd recommend draining the float bowels first. Put fresh gas in your tank, pour about a bottle full of seafoam, put the tank on "Prime" and drain the float bowels for about 10-15 minutes. After that, put the tank on "ON" and attempt a start.
This is the procedure I used to start my ninja who had been in her beauty slumber for 6 months. Good luck. |
February 4th, 2012, 02:43 PM | #6 |
CVMA #74 WSMC #750
Join Date: Oct 2009 Motorcycle(s): All of them Posts: A lot.
9 months. I hope it was stored inside (i.e. garage). Another 250 I picked up was sitting OUTSIDE for 6 months straight. Ran into all kinds of problems trying to get it started. Kinda still am. But I got it started and idles fine. Gotta test/tune it for track.
February 4th, 2012, 02:46 PM | #7 |
Just using Seafoam won't get everything out, but is definitely worth a try. If that doesn't work, then try opening it up and cleaning them manually. At the very least, trying Seafoam will loosen up the gum in the carbs for when you manually clean them.
February 4th, 2012, 03:40 PM | #8 |
Been in the garage all this time. Any instructions for draining float bowels. Found some info on another site but for the older Ninjas.
Last futzed with by FerociousNINJA; February 4th, 2012 at 07:33 PM. |
February 4th, 2012, 10:03 PM | #9 |
They're the same carbs. There should just be a hex screw on the bottom of the bowl...
February 8th, 2012, 05:23 PM | #10 |
SOLVED:
Got it started. Thanks for all the help. What I did: 1.- Empty the gas tank. 2.- 2 fl. oz of CRC Motor Treatment (like Sea Foam). Let it sit with for 5 min. 3.- Added 1 Gallon of Gas (89 octane) . 4.- Choke and after a few cranks it started. |
February 8th, 2012, 05:34 PM | #11 |
Join Date: Jun 2011 Motorcycle(s): 2011 Kawasaki Ninja 250R (sold), 2007 SV650s (deer wrecked), 2010 Suzuki SV650S Posts: 334
I guess it was clogged carbs?
February 8th, 2012, 05:39 PM | #12 |
If it's a carb'd bike that worked before it was put away, and has been stored for a long time, the carbs are clogged/ dirty 99% of the time.
At least that's what the shop told me right when I got my bike and it had been sitting for 4 years. |
After LONG winter sitting, bike wont start | RedNinja09 | General Motorcycling Discussion | 44 | January 20th, 2018 02:34 PM |
Bought first bike and 1 day later it won't start: do I have a junk bike? | brendandubs | 1986 - 2007 Ninja 250R Tech Talk | 43 | May 11th, 2014 07:59 AM |
Bike sitting for ~6 months | LazinCajun | 2008 - 2012 Ninja 250R Tech Talk | 15 | May 24th, 2011 04:17 AM |
Bike won't start | chowbray | 2008 - 2012 Ninja 250R Tech Talk | 20 | March 21st, 2011 07:51 PM |
bike won't start :/ | SephiaSputnik | 1986 - 2007 Ninja 250R Tech Talk | 20 | March 12th, 2010 02:40 PM |
