Old June 17th, 2011, 10:28 PM   #1
Davis937
Davis937's Avatar
Motorcycle(s): 2007 Ninja 250r (silver)
Best tire pressure ...
Hey Everyone:
... and Happy Weekend to all of you! I know this topic has come up previously, and I do know that correct / best tire pressure has been a continuous subject of debate. Anyway, a lot of good experience here so I'll throw this out. I just purchased a pair of Pirelli Sport Demon tires ... have had them for just a few days. As recommended by you all, I "broke" the tires in for the first 100 miles or so and rode pretty conservatively. I'm very pleased with the tires ... bike handles really nicely, corners better, and the tires just feel great (haven't had the opportunity to see how they handle a wet road yet ... please chime in if you've had some experience). Anyway, to my question ... I checked the tire pressure for both front and rear tires (yeah, tires were cold). Both tires had a reading of 27 psi (I triple checked the reading). I'm thinking that this is probably not the best pressure for the tires (possibly, too low?). Also, I always thought that the rear tire should be about 3-4 psi higher than the front. Please help ... what's a recommended tire pressure for these Pirelli tires? Thanks in advance for your comments and help ...
Davis937 is offline   Reply With Quote
Old June 17th, 2011, 10:29 PM   #2
28f/32r (measured cold) is a good starting point, adjust to taste.
/moved to pre-gen tech area
Old June 17th, 2011, 10:31 PM   #3
http://www.ninjette.org/forums/showp...2&postcount=21
Old June 18th, 2011, 05:20 AM   #4
DaBlue1
DaBlue1's Avatar
According to Pirelli the min tire pressure is 32F/42R. I would start there then make adjustments as necessary.
Last futzed with by DaBlue1; June 18th, 2011 at 08:00 AM.
Old June 18th, 2011, 08:22 AM   #5
What is that doc, Blue? Is the full version available anywhere? 42 on the rear seems unbelievably high for such a light bike, and is so far off the recommendation on the OEM tires, that it's very surprising to me.
Old June 18th, 2011, 10:26 AM   #6
Davis937
Davis937's Avatar
... thanks, Alex!
Old June 18th, 2011, 10:27 AM   #7
Davis937
Davis937's Avatar
Aloha, Kelly ... mahalo!
Old June 18th, 2011, 10:28 AM   #8
Davis937
Davis937's Avatar
... thanks, Blue! Wow ... those numbers, especially rear tire, do seem high. Do you own Pirelli tires?
Pirelli tire owners please chime in!
Old June 18th, 2011, 10:29 AM   #9
Davis937
Davis937's Avatar
Hey, Alex ... yeah, I hear you and I agree!
Old June 18th, 2011, 11:52 AM   #10
DaBlue1
DaBlue1's Avatar
The doc is from Pirelli. It is the fitment guide. Let me correct that- 32 psi is the min for the front 42 is the max. 36 psi is the minimum for the rear, 42 is the max. Sorry fro the confusion was rushing try to take care of wifey's request.
http://www.us.pirelli.com/en_US/brow...LI_FULL_07.pdf
http://www.us.pirelli.com/en_US/brow...elliDealer.pdf
Old June 18th, 2011, 07:54 PM   #11
Davis937
Davis937's Avatar
Hey Blue ... thanks for the information -- certainly appreciate it.
Again, thanks also to the rest of you!
Old December 26th, 2013, 03:23 AM   #12
fast1075
Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite
I run 36 front / 38 rear on mine. With the front lowered 3/4", it has REALLY good turn-in. At 2000 miles on mine, the wear is very good.
I would go down on pressure a bit for a track day, but the tires stick well during SANE street riding, and the higher pressure helps slow down center tread wear.
"They don't pay me enough to ride this thing!" Kenny Roberts after winning the Indy Mile on the TZ750 powered Grand National bike.
fast1075 is offline   Reply With Quote
Old December 30th, 2013, 12:29 AM   #13
kirk595x
kirk595x's Avatar
Motorcycle(s): 03' Ninja 250ex
They handle rain very well.
Perform Random Acts of Coolness!!ATGATT
kirk595x is offline   Reply With Quote
Old December 30th, 2013, 12:50 AM   #14
Binnie
Binnie's Avatar
Motorcycle(s): GPX250, 2000 R6
in general pirellis have a softer carcass than dunlops/bridgestone, so pressures need to be a little higher than usual, but 42R does seem a little high for the light bike unless you weigh like 100kg.
I would probably start with around 30f/32r and go from there, Its all based upon how the bike feels to you, and the tyre wear you're seeing.
Binnie is offline   Reply With Quote
Old February 17th, 2014, 04:12 AM   #15
fast1075
4,000 mile report
I'm at 4,000 miles now with my Sport Demons. The center is just beginning to show flattening, but not very noticeable yet. The traction is remarkable, and I have not had a single instance of bad behavior from the tires.
The only thing I would change if possible would be the aspect ratio. With an aspect ratio of 90, the tire is a bit pinched. When I finally wear these tires out, I may try the Pirelli MT-75, though I fear they will not last nearly as long.
Anyways, Sport Demons on a 250 = Performance equal to Q3 on a Buell XB12s. (or better since I can toss the 250 into corners MUCH harder than the Buell)
Pirelli Sport Demon - Highly Recommended!
Old February 17th, 2014, 11:48 AM   #16
quarterliter
Motorcycle(s): 2004 Ninja 250
The MT75s won't last long. I've got 1500 miles on my set and the rear is flat spotted.
Old February 17th, 2014, 12:40 PM   #17
fast1075
Guess the cheaper cost is false economy. They wore out pretty quick on my Blast too. But I figured it was because of the bore kit, cams, mikuni, and my less than gentle riding.
Old February 17th, 2014, 02:25 PM   #18
quarterliter
It's all in how you ride. If you cruise around I'm sure the tires will last much longer.
Tire pressure gauges Soujyu General Motorcycling Discussion 44 April 4th, 2015 07:20 PM
Once more... recommended tire pressure AlexCWO 2008 - 2012 Ninja 250R Tech Talk 6 June 4th, 2013 11:36 AM
Tire pressure + Handling FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 4 March 28th, 2013 04:05 PM
Bt-45 tire pressure indr 2008 - 2012 Ninja 250R Tech Talk 1 July 5th, 2011 09:05 AM
Tire pressure.... Davidb1986 2008 - 2012 Ninja 250R Tech Talk 31 May 24th, 2010 12:59 AM
