September 1st, 2013, 09:34 AM | #1 |
Join Date: Jul 2013 Motorcycle(s): Pregen body with a newgen engine. Posts: 117
Could someone please tell me which are the starter circuit coil terminals?
On the Starter Circuit relay? I'm thinking it's the one circled and either of the ones with a red dot.
I want to check I get voltage in the coil when I push the ignition button, I already ruled out all the switches and fuses, starter and solenoid as probable cause for my problem, so it comes down to this relay or a damaged cable somewhere in there... Last futzed with by peterpayne; September 1st, 2013 at 09:45 AM. Reason: avoid confusion as to which coils I'm referring to. |
September 4th, 2013, 06:46 PM | #2 |
Join Date: Aug 2012 Motorcycle(s): Ninja 250 2001 Posts: A lot.
Lol
Can't help you sorry.
Mods: Offset clutch pressure plate |
car battery terminals | james250ninja | Off-Topic | 1 | September 16th, 2013 08:18 PM |
Starter Relay/Starter Problem | Time Mage | 1986 - 2007 Ninja 250R Tech Talk | 13 | July 13th, 2012 05:02 AM |
Removing and checking terminals? | Zombiphone | 2008 - 2012 Ninja 250R Tech Talk | 4 | November 13th, 2011 04:02 PM |
