Old November 27th, 2009, 01:54 AM   #1
Trixxr
Motorcycle(s): Ninja 250r
250R FI + US Exhaust.
So guys, i'm just a stupid dane.
I recently ordered a full system Yoshimura from eBay, and now i want to know: What exactly do i have to do, to make it fit? I know that there is some sort of "lambda" thingy, something that controls the gas or something,that has to be weld on. other than that, how do i "jet" it? Is there another option than buying a powercommander?
I might not make any sence at all.
Hope you can help me :b
//Trixxr
So to break it up :
Is there a guide to install a carb exhaust on a FI bike
What do i have to do to the fuel injection system, after the exhaust has been assembled.
Trixxr is offline   Reply With Quote
Old November 27th, 2009, 08:27 AM   #2
SteveL
old git
SteveL's Avatar
Motorcycle(s): BMW K1300S
I don’t know about the exhaust fitting by what you need is an up graded ECU putting carbs on a FI bike is not a good idea.
Steve
Some mistakes are too much fun to make only once.
SteveL is offline   Reply With Quote
Old November 27th, 2009, 08:29 AM   #3
randomwalk101
self wrencher
randomwalk101's Avatar
drill a hole in the header and weld a nut to mount the oxygen sensor. EZ
Old November 27th, 2009, 10:11 AM   #4
http://www.ninjette.org/forums/showthread.php?t=19769
Old November 30th, 2009, 05:40 AM   #5
Trixxr
kkim i just saw that thread!
and i'm not putting carbs on my bike dude :b
and is it really that easy? Is there a guide for it or something?
Old November 30th, 2009, 06:08 AM   #6
Trixxr
http://www.powercommander.com/powerc...dl=227&yr=2008
isnt that the one i'm looking for? I'm from Denmark, so i guess i have one of the EU FI Bikes D:
Old November 30th, 2009, 06:30 AM   #7
HKr1
IC2(SW)
HKr1's Avatar
You dont want the PCIII, you want the PCV with auto tune module. Power commander only supports 09 and up for pcv. But will work on the 08 too.
http://www.powercommander.com/powerc...dl=227&yr=2009
Old November 30th, 2009, 06:38 AM   #8
Trixxr
I don't wanna spend 250$, as there is already a map for the setup i'm putting on mine
And are you sure it will fit mine? (Probably a stupid question, but i just wanna be on the safe side! (: )
Old November 30th, 2009, 06:54 AM   #9
bprayogo
Motorcycle(s): N250R
You should install a powercommander, either pc3 or pc5 will work fine. Only the pc5 offer one more throttle position column (15%) for tuning and its smaller and u dont need to run the engine for it to load maps, and also later you can install autotune module so you can fine tune on the road .
Then you go to the nearest dyno tuning center and have your bike tuned for custom map,this is the best way to extract maximum power from your bike .
If you use full system exhaust from carbed bike , you dont need to install your original O2 sensor bung on it and you dont need the O2 sensor, the PC3 will tune from low end to top end and you can disable the close loop system by plugging the O2 sensor eliminator to the original O2 sensor socket so the instrument cluster wont display a FI error , this eliminator is provided in the PC3 or 5 kit, if not ask the PC seller for the appropriate sensor eliminator.
If later u decide to install AUTOTUNE with PC5 then u need to weld the provided sensor bung to your exhaust and install the O2 sensor provided by the autotune kit.
Hope this help
bprayogo is offline   Reply With Quote
Old November 30th, 2009, 07:38 AM   #10
randomwalk101
self wrencher
if i were you, i'll email Dynojet directly and ask. Most of us don't have FI so our answers is sort of pulling it out of our a$$e$$.
Old April 28th, 2011, 01:21 PM   #11
vaibhavtri001
Motorcycle(s): Honda 954, Ninja 250R, HondaF4
hi Guys,
I have got, Ninja 250R Fi (2010), and wish to put in the totsubo exhaust systems on my machine. toshubos exhaust system is shown in the link below:
http://www.youtube.com/watch?v=JBHGwD9ENVA
Can you guys please advise on the mods that I need to do on my machine, so that I can achieve the optimum performance with out harming the engine.
Im a new bie here and need your advise and guidance on the same... please help
thanks,
Vaibhav
vaibhavtri001 is offline   Reply With Quote
FS: 08-12 250R AreaP Exhaust DJK Motorcycle-related 4 August 5th, 2013 06:57 AM
2011 250r custom exhaust greatwhiteninja 2008 - 2012 Ninja 250R Tech Talk 24 June 14th, 2011 07:44 PM
WTB: exhaust for 08+ ninja 250r shift_6 Items Wanted 1 April 5th, 2010 08:52 AM
aftermarket exhaust for 09 250R gizmogamez Items Wanted 13 July 2nd, 2009 05:07 AM
250R Exhaust wongboy 2008 - 2012 Ninja 250R Farkles 6 December 18th, 2008 08:17 PM
