Old September 21st, 2022, 04:48 AM   #1
Shafer
Motorcycle(s): 07 Ninja ex250 blue and 07 Ninja black
White residue inside fork oil seal
*just got the bike a month ago. 2007 - 12k
Started a fork rebuild last night because one of my tubes was leaking.
I was inspecting all the parts after disassembly for wear when I noticed a white residue inside the leaking side oil seal. It looked like bacon grease.
*already plan on replacing all fork seals
So my question is anyone know what this white build up is inside the oil seal?
Shafer is offline   Reply With Quote
Old September 21st, 2022, 04:50 AM   #2
Shafer
Old September 21st, 2022, 05:22 AM   #3
I don’t know but maybe the previous owner tried to use some leak-stopping product? I guess it could also be something like spiderwebs or slug slime that built up over years of disuse until the forks were compressed and the seals concentrated a thin film of old deposits right where the seals slide. In that case, you might say they are just doing their job.
Old September 21st, 2022, 06:12 AM   #4
Shafer
Yeah it's weird whatever it is. Reminds me of bacon grease.
So I was going to use waterproof grease to slide the new seal on but I wonder if the residue is old grease or maybe while lithium.
Maybe I'll just use fork oil as lube to slide the seal on.....thoughts?
Other non leaking fork seal has no white residue.
Old September 21st, 2022, 10:32 AM   #5
I used some fork oil on mine when reassembling several years ago but I don’t recall if it was needed. Regardless, it couldn’t hurt though it might make the job a little messier.
Edit: I think I might’ve also packed the space between the dust seal and the oil seal with some kind of grease. Not sure what instructions I was following back then to check but I think so could recall the grease leaving grease rings that made it look like it was leaking when it wasn’t.
Old September 21st, 2022, 12:25 PM   #6
Shafer
My weight - 185
Replacing stock spring with Sonic Sping 0.85kg/mm
Old weight for fill 75w
Live in NH - ride late spring, summer and early fall
Another question:
I'm thinking I'm going to do a oil level of 160mm.
Any suggestions or is 160mm the sweet spot?
Old September 21st, 2022, 12:51 PM   #7
Shafer
Sorry I'm planning on 15w fork oil not 75
Old September 22nd, 2022, 01:08 AM   #8
crimsondragon
Motorcycle(s): 2006 Ninja 250
Looks like white lithium. It has a distinct smell. I use it all the time for seals but not specifically fork seals.
crimsondragon is offline   Reply With Quote
Old September 22nd, 2022, 02:36 AM   #9
Shafer
Thanks for the reply. I'm thinking it's white lithium also. It made a smooth lip inside the seal causing my leak.
Old October 2nd, 2022, 12:01 PM   #10
Shafer
Update:
Did the spring upgrade to weight appropriate and oil 15w filled to 130mm.
Amazing different!
I just got the bike this year and had nothing to compare, until today when I rode my girlfriends stock 250 and felt that fork dive during braking, so scary. She's getting new springs!
Do the springs! The bike is so much fun in the corners and braking is sharp. It's night and day, how much better it made the bike. Now onto the rear shock lol
gas washer gasket and weird white rubbery residue all inside the carb. 07 ninja 250 bigBug 1986 - 2007 Ninja 250R Tech Talk 1 March 24th, 2022 11:03 PM
Oil and dust fork seal diameter and dimensions Sylar 1986 - 2007 Ninja 250R Tech Talk 1 May 10th, 2018 02:00 PM
OEM Brand New Fork Oil Seal, Dust Seal (08-12) capriccio Motorcycle-related 3 June 9th, 2013 05:11 AM
Front fork oil seal change... ManOfGod 1986 - 2007 Ninja 250R Tech Talk 17 April 20th, 2013 07:54 PM
Fork seal and oil advice capriccio 2008 - 2012 Ninja 250R Tech Talk 1 July 23rd, 2011 04:05 AM
