Old January 7th, 2023, 07:14 PM   #1
MikeCL
Motorcycle(s): ‘04 EX250
Question Clutch lever bracket
Hey just wondering I have an '04 ex250 and I was wondering if the bracket for the clutch would fit on the '04 model?
MikeCL is offline   Reply With Quote
Old January 22nd, 2023, 07:59 PM   #2
Bob KellyIII
Retired motorcycle Mc.
Bob KellyIII's Avatar
unknown.... but it should... most clutch lever brackets are 7/8" and if your is too it should fit... weather it will clear everything else is the big question though.... not the fit on the handle bar !
give it a try what can it hurt ?
to get the handle bar grip off shove a long thin screw driver under the outside edge of the grip all the way to the control housing and squirt WD-40 in there and do that 2 or 3 times... around the rubber grip and then you can twist off the grip....
you can get the WD-40 off with Rubbing alcohol and a rag later.
or you may be able to just split the controls... i dunno.
Bob.....
Old January 23rd, 2023, 07:53 PM   #3
MikeCL
Oh yeah I forgot an update yeah it fits no issues even the plug fits.. and my clutch lever fits just fine..
I may change the brake side because a tiny play is enough to turn on my brake like without the brakes being on.
Front brake = left lever; Clutch = right lever cadd Riding Skills 27 October 7th, 2014 08:29 AM
WTB: Clutch lever, handle bar end, dummy cap, and clutch lever holder. 09 250r SwagenGTI Items Wanted 5 March 4th, 2013 12:20 PM
WTB: Left side turn signal/clutch lever/ shift lever/fairing (green/red or black) daedrick Items Wanted 0 April 3rd, 2012 12:44 PM
Ebay lever broke my clutch lever mounting bolt! pilotgeorge747 2008 - 2012 Ninja 250R Tech Talk 8 December 22nd, 2011 07:22 AM
