Old January 1st, 2009, 10:05 PM   #1
headshrink
headshrink's Avatar
Thinking about changing my oil change routine
I have been changing my oil every 1000 - 1500 mi. since I got my bike. I have recently started changing some minor aspects of this routine to save $$.... for instance, the last time I did it I didn't replace the o rings, which seemed safe enough. This time I ordered the Fram filter for 1/2 what the dealer charges AND it really does come with the o rings (I thought that was just to good to be true). I am waiting to install these this weekend. I'm considering getting oil at Autozone, instead of the dealer..... but this has been covered in many other threads.
So here is what I am considering next..... rather than replacing the filter every time I do an oil change, how about every other time (2000 - 3000 miles)? Just a thought - would it matter much?
Old January 1st, 2009, 10:21 PM   #2
I personally think changing the oil every 1000-1500 miles is excessive once the bike is broken in. I changed frequently in the first 2k miles to make sure I had flushed all of the crap out of the crankcase. Now that I'm at 2K, I'm planning to do the changes at every 3K miles.
At that interval, you will save money over your present routine. If you feel squeamish about letting your oil go for 3K miles (which is quite frequent, in my book), I suggest using a full synthetic oil at your next change. Shell Rotella T 5W-40 is a great oil for our bikes and is economically priced and available at Walmart.
I stay away from Fram filters and prefer WIX filters or their equivalent at NAPA, which are their Gold line filters. Comes with O-rings, too!
Old January 1st, 2009, 10:34 PM   #3
Kurosaki
Akai Suisei - 赤い彗星
Kurosaki's Avatar
Motorcycle(s): 08 Kurosaki 250, 09 Honda 600RawrRawr
1000-2000 miles is a really short interval.
I do 5000.
Kurosaki is offline   Reply With Quote
Old January 1st, 2009, 11:47 PM   #4
headshrink
headshrink's Avatar
Why do you stay away from the Fram?
Old January 1st, 2009, 11:58 PM   #5
I've read a few oils study reports that have had not too good things to day about Fram filters. Search online and you'll find the reports too. Make up your own mind on their findings. You already know my decision.
Old January 1st, 2009, 11:59 PM   #6
grandmaster
grandmaster's Avatar
Motorcycle(s): 2008 Ninja 250R, CR125R
Anybody have the Part Number for the oil filters they use
grandmaster is offline   Reply With Quote
Old January 2nd, 2009, 12:05 AM   #7
check the oil change DIY.
Old January 2nd, 2009, 08:41 AM   #8
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
I worked at the company that used to make the filter paper for the fram filters.... that's more than enough for me to stay away! That company has since gone under, but I'm still not going near the fram filters, as I'm sure their new supplier doesn't have much bettre quality!
Old January 2nd, 2009, 12:58 PM   #9
headshrink
headshrink's Avatar
I never knew that.... I'll look into it. I did order 2, so I'll use them up pretty fast with my current change cycle. Then I'll look into the others - with o rings .
Old January 2nd, 2009, 02:57 PM   #10
Sailariel
Sailariel's Avatar
Shrink, I agree with Kelly. My routine is every 3000 miles using Shell Rotella 5W40. This is the same oil I have used in my Yanmar diesel on my sailboat for the past 20+ years. On the sailboat I change oil and filter every 150 Hours of operation. Yanmar will void your warranty if you use Fram. I use WIX filters on all my vehicles as well as Rotella-T. I change the filter every time I change the oil. I see little value in changing to a clean oil and leaving 40cc of dirty oil in the engine.
Old January 2nd, 2009, 03:18 PM   #11
headshrink
headshrink's Avatar
Good point.... I'll look for those filters and oil. Thanks!
God forbid I have a warentee issue, but I'll make sure I have an OEM filter in-place when I take the bike in for service.... regardless of what was actually in there prior.
I am assuming that I'll be OK running through the 2 Fram filters I currently have "in stock," as long as I don't make a habit of it?
Old January 2nd, 2009, 04:39 PM   #12
Sailariel
Sailariel's Avatar
Sure, Two filters are not going to do any damage--not at the rate you change oil. I am still using OEM Filters and Kawasaki 10W40 till my warranty in June expires. I saw no point in getting an extended warranty because I feel that anything that would be defective would come to light in that period. I am also blessed with two independent MC repair/service facilities in my area. Thanks to this forum, I found out that Shell Rotella-T is the way to go. It is a great oil. I have 230,000mi on my 95 Escort. The engine and trans are like new, but the body is shot. The Escort does not burn any oil andruns great--has had a Rotella diet since it was new.
Old January 2nd, 2009, 04:47 PM   #13
Broom
Track Junkie
Broom's Avatar
Motorcycle(s): '08 Ninja 250r Track Bike, DR350 commuter, KDX220 woods bike
i've always heard to stay away from fram for motorcycle filters too. not sure if its an urban myth kinda thing or not.
Las Escobas -- Track Bikes Save Lives
JonBroom.com
Broom is offline   Reply With Quote
Old January 2nd, 2009, 05:09 PM   #14
Sailariel
Sailariel's Avatar
Broom, I took a Fram filter and cut it in half after it had 3000 miles on it. The inside was totally scrambled (not due to my cutting) The glue had done something and I doubt that the filter could have filtered anything. The Yanmar folks are no dummies--they build the penultimate diesel.
Old January 4th, 2009, 07:55 PM   #15
Sailariel
Sailariel's Avatar
Correction: The oil I have been using in my cars and inboard diesel on the boat is Shell Rotella-T15W-40. It is a non-synthetic oil. The oil I will be using in the Ninja will be Shell Rotella-T 5W40 and that is a synthetic oil. I still will continue to use WIX Oil Filters in all my vehicles.
Is it normal for oil to increase a bit in the crankcase after an oil change? cadd 2008 - 2012 Ninja 250R Tech Talk 10 May 15th, 2014 08:38 PM
Thinking of changing front sprocket - any tips? n4mwd 1986 - 2007 Ninja 250R Tech Talk 37 May 28th, 2012 03:54 PM
thinking of changing my bikes colour scheme... LoneRonin 2008 - 2012 Ninja 250R Farkles 4 May 24th, 2012 07:53 AM
In case you were thinking about changing your front sprocket... M-Oorb 2008 - 2012 Ninja 250R Tech Talk 7 January 12th, 2009 09:40 PM
[webbikeworld.com] - Substitute Ducati Oil Filters - Changing the Multistrada Oil and Ninjette Newsbot Motorcycling News 0 October 26th, 2008 05:10 PM
