Old September 19th, 2012, 04:03 PM   #1
dcx4610
Motorcycle(s): Ninja 250R
Popping the clutch
Yeah, more questions.
Popping the clutch. What exactly is this and when should you NOT do it? As noted in my other thread, I'm about 500 miles in on my 250 and I'm still playing around and getting comfortable with various things.
I've noticed I've become really good (?) at shifting quickly. When I first started riding, all I had read and watched was that you need to let out the clutch slowly and smoothly. My gear changes were pretty pathetic because I would hold in the clutch and sloooowly let it out, hold it and then let go.
Now, it's clutch in, kick up, throttle on, clutch out almost all in one motion. It feels smooth and never feels like it upsets the bike. Am I "popping" the clutch doing this? Am I NOT supposed to be shifting that quickly?
Is popping the clutch really only if you are in neutral, you rev up and then let out the clutch too fast?
I guess what I'm getting out is it proper for me to be doing quick clutch releases when shifting as long as I'm already in first gear?
dcx4610 is offline   Reply With Quote
Old September 19th, 2012, 04:06 PM   #2
dropping or popping the clutch means going from fully depressed, to no pressure and letting the clutch engage as quickly as the clutch springs will allow.
never ever pop the clutch.
Old September 19th, 2012, 04:09 PM   #3
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
Old September 19th, 2012, 04:15 PM   #4
you can be fast while still being smooth. riding motorcycles is all about being smooth.
Old September 19th, 2012, 06:40 PM   #5
Originally Posted by dcx4610 View Post
.........I guess what I'm getting out is it proper for me to be doing quick clutch releases when shifting as long as I'm not already in first gear?
Clutch-in can be done as fast as you want.
Clutch-out should be tailored, regarding quickness, according to the relative speeds of engine and rear wheel.
Think of it as a coupling between crankshaft and transmission, that you can modulate more or less in order to make it more or less flexible.
Smoothness is the key, as Alex said.
Old September 19th, 2012, 07:30 PM   #6
rabies
time is running out....
rabies's Avatar
Motorcycle(s): pregen ninjari
popping the clutch is more of a trick. and it refers to doin wheelies. especialy wuth these bikes u realy gotta ramp up the revs n pop it to get the front weel off the ground.
but yea...dont do it. jus keep riding safe
The King
rabies is offline   Reply With Quote
Old October 6th, 2012, 04:14 AM   #7
Apex
Livin' the Minimoto Life
Apex's Avatar
It is bloody fun.
Do this this weekend:
1. Pull in the clutch with the very tip of your fingers
2. Rev the engine until it is banging off the rev limiter
3. Then slide the tips of your fingers off the lever, allowing the clutch to return to its normal position as fast as it can
4. Enjoy the aftermath
Old October 6th, 2012, 06:01 AM   #8
rabies
rabies's Avatar
Originally Posted by Apex View Post
It is bloody fun..
Could be Literally.....
The King
Last futzed with by rabies; October 6th, 2012 at 10:17 AM.
Old October 6th, 2012, 08:15 AM   #9
Whiskey
Now that you have the clutch upshift working well try the clutchless upshift (never clutchless downshift)
Once you're in 2nd or higher (it can be a long way up through neutral...)
Preload the shifter by putting a little pressure on it, roll slightly off & back on the throttle (like blipping it but going the other way) once you've rolled off the bike should shift up smoothly.
It may take a couple of attempts to get the initial feel for it
There is another method which involves a sharper flick up timed with a sharper roll off & back on but that's something to pick up once you have the basics down.
I don't want this one to become another discussion on the merits of clutchless shifting.
http://www.ninjette.org/forums/showthread.php?t=51617
Old October 6th, 2012, 08:57 AM   #10
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
It is bloody fun.
Not a very good explanation for new rider with only 500 miles experience.
Let me add;
5. Hold on for dear life.
Old October 10th, 2012, 02:48 PM   #11
Let me add;
you forgot:
6. pick up your looped bike out of the gutter
Old October 10th, 2012, 02:52 PM   #12
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
7) Proceed to coroner.
Old October 10th, 2012, 03:00 PM   #13
crashed that 636 yet, nicky?
Old October 10th, 2012, 03:25 PM   #14
lgk
how do you pick up the looped bike?
Old October 10th, 2012, 06:08 PM   #15
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
It's a 600...no not yet...had a few little incidents that could have been worse lol
To pick up looped bike...call friend, and tell him to do it.
popping noise jcsalazar 2008 - 2012 Ninja 250R Tech Talk 13 October 25th, 2014 03:30 PM
Popping during deceleration chikenstrips 2008 - 2012 Ninja 250R Tech Talk 5 April 25th, 2012 07:00 PM
Popping on deceleration... Skippii 1986 - 2007 Ninja 250R Tech Talk 26 October 3rd, 2011 02:34 AM
Backfiring and popping Keenan84 2008 - 2012 Ninja 250R Tech Talk 13 April 21st, 2010 09:01 PM
Tight valves=Popping? diablo250 2008 - 2012 Ninja 250R Tech Talk 15 April 11th, 2010 04:07 PM
