Old July 19th, 2013, 05:08 PM   #1
radioflyer
radioflyer's Avatar
Motorcycle(s): 250 ninja
carb problem
After cleaning my carbs the bike revs up fine but is slow to come back down to idle. I tried looking for an air leak by spraying around the various clamps both front and back...but no change. When I spray starter fluid in the air filter intake it comes right back down to idle. Anyone seen this problem before?
radioflyer is offline   Reply With Quote
Old July 19th, 2013, 06:55 PM   #2
Runeknight95
Motorcycle(s): 08 cbr1000rr, 2008 + 2012 ninja 250, 06 zx6r (636!) track only
I had an issue where it would hang when the idle adjuster was set too high.
Runeknight95 is offline   Reply With Quote
Carb problem... dies when on the gas jboyd12 2008 - 2012 Ninja 250R Tech Talk 43 April 9th, 2014 03:31 PM
Carb problem? Carytowncat 1986 - 2007 Ninja 250R Tech Talk 15 March 8th, 2014 11:21 AM
Carb Float Problem Trainsk8 2008 - 2012 Ninja 250R Tech Talk 3 June 4th, 2012 12:31 PM
Carb Jetting, dont know if there's a real problem? Trainsk8 2008 - 2012 Ninja 250R Tech Talk 6 November 11th, 2010 12:50 PM
carb cleaning problem, not a novice! revlis240 2008 - 2012 Ninja 250R Tech Talk 15 May 8th, 2010 08:10 PM
