Old June 14th, 2016, 02:49 AM   #1
ZeroGravity360
Just sittin on my stool..
Motorcycle(s): 2012 Ninja 250
Rear tire?
Is it possible to get a wider rear tire on a ninja 250? I rode a bigger bike this weekend and I felt a little more stable going over rough patches and I'm convinced it's because of the larger tires.
ZeroGravity360 is offline   Reply With Quote
Old June 14th, 2016, 05:11 AM   #2
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
Appropriate tire size is limited by rim width for proper profile. There are many reasons why the other bike may have felt more stable, it may not be the rear tire size in particular.
That being said, a good radial tire, in a 150 section width and a 60 series aspect ratio (150/60/17) would probably be the largest width rear tire that I would recommend on a stock rear wheel.
Old June 14th, 2016, 05:16 AM   #3
VaFish
VaFish's Avatar
MOTM - Jan '16
What tires do you have on your bike now?
My daughters pregen had the stock Dunlop on the rear and a Pirelli on the front. I had Pirelli's front and rear. We swapped bikes once in the mountains, on the first tight corner I was all over the place. I put a Pirelli on the back of hers the next day.
Old June 14th, 2016, 05:21 AM   #4
ZeroGravity360
PRetty sure they are stock, the previous owner never did anything with the bike, it has 4.8k on it
Old June 14th, 2016, 06:17 AM   #5
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
There are a number of issues with a stock Ninjette that could affect how stable it feels. I'd put tire width at the end of that list.
  • The springrates are mismatched. (Front, Rear)
  • There's a good chance neither springrate matches your weight.
  • Stock tires are bias-ply.
  • Stock tires are known more for longevity than performance.
  • Stock 2012 tires are nearing the end of their useful life now, regardless of their mileage.
  • Little Ninjas are known for weak, flexing frames.
I have a 150/60 on my wider aftermarket wheel. I switched from a durable bias-ply tire to a performance radial, so it definitely feels different, but I'm pretty sure the extra 20mm has minimal to no effect.
Here's what going from a 130/70 to a 150/60 looks like.
Keep in mind that going to a wider tire on a wheel that's too narrow will actually pinch it in, causing the profile to be altered, which can lead to less tire in contact with the ground. The 300 uses a 140 rather than a 130, but it also has a wider wheel.
A 150/60 is also getting close to fitment limits. People have had trouble with certain tire models in that size just due to spacing issues from using a different sprocket size.
In my opinion, springing the bike to match your weight and getting modern radial tires like the Pilot Street will do a lot more for you than getting an extra pencil-width of tire.
Old June 14th, 2016, 06:34 AM   #6
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
Why are you "convinced" it's because of the larger tires?
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Old June 14th, 2016, 07:19 AM   #7
allanoue
allanoue's Avatar
MOTM - Sep '14
Michelin Pilot Streets come in 130 and 140. I ran 140's on my 2009 250. I think you would be just as happy with ether one and the 130's are cheaper. Like has been said, It maybe the quality of the tire and not the width that you like.
140s look better
Last futzed with by allanoue; June 14th, 2016 at 10:01 AM.
Old June 14th, 2016, 07:27 AM   #8
ZeroGravity360
Originally Posted by allanoue View Post
Michelin Power streets come in 130 and 140. I ran 140's on my 2009 250. I think you would be just as happy with ether one and the 130's are cheaper. Like has been said, It maybe the quality of the tire and not the width that you like.
140s look better
it could be possible, it just felt a lot more "grippy" and less like I was going to lose it in the corner, could have been the bike too, dunno
Old June 14th, 2016, 07:35 AM   #9
ZeroGravity360
Would a 140/70R-17 66H be too much off? I think youre supposed to go with a 130/60 technically, does going from 60 to 70 effect your speedometer?
Old June 14th, 2016, 07:36 AM   #10
allanoue
allanoue's Avatar
MOTM - Sep '14
Higher powered bikes have wider tires to get the power to the road at the expense of maneuverability.
You are right. The OEM tires are hard and were made to last a long time and not to be grippy.
Old June 14th, 2016, 07:39 AM   #11
allanoue
allanoue's Avatar
MOTM - Sep '14
140/70R-17 Is what I got and the speedo was the same 7% off as the OEM 130s
Old June 14th, 2016, 07:42 AM   #12
ZeroGravity360
Is there a way to fix this
Old June 14th, 2016, 07:58 AM   #13
allanoue
allanoue's Avatar
MOTM - Sep '14
Yes, if you search the site there are some how too's but the math is easy. If your speedo shows 85 you are actually going about 80.
I just go by GPS on my phone. When I get my Shully in a few weeks, GPS will be heads up
Old June 14th, 2016, 08:00 AM   #14
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
The speedo cable goes to the front tire.
<-- Linky
Old June 14th, 2016, 10:00 AM   #15
allanoue
allanoue's Avatar
MOTM - Sep '14
Too many times I have referred to Pilot Streets as power streets
Fixing
Pilot Streets
Old June 14th, 2016, 10:09 AM   #16
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
The difference in diameters between the sizes is 20MM. This means the rear of the bike will be raised 10MM with the 140 tire.
Goin' fast on slow bikes!
Old June 14th, 2016, 10:28 AM   #17
Ausoi
Motorcycle(s): 2008 (Black) Kawasaki Ninja 250R
The biggest tire you can get away with without having it pinch was the Bridgestone Battlax BT-016 150/16 but I think they don't produce them anymore. I sold my Ninja 250 but I can recommend that tire 100%.
In my opinion having a larger tire is not the problem with the ninja feeling stable, it just has to do with the weight of the bike. You just have to get use to the feeling of being blown around a bit.
Ausoi is offline   Reply With Quote
Old June 14th, 2016, 12:05 PM   #18
CrazyCanuckGoat
Motorcycle(s): 2003 ZX12R (sold), 2012 250R, 1975 Honda XL250, 1980 XJ650
I just put a new pair of Kenda's on mine and I'm quite happy with them for the price. I believe they were the K671's.
Stock front size and I bumped the rear up to a 140/70 which is what my 01 ZZR250 had stock.
CrazyCanuckGoat is offline   Reply With Quote
Old June 14th, 2016, 02:43 PM   #19
1wardogusmc
1wardogusmc's Avatar
Motorcycle(s): 2010 250/ZX-10R, 2014 300
Fixing
Pilot Streets
I'm a huge fan of the pilot road as well. I have the pilot road 4 on for.t and back. They are a great commuter tire. The pilot power however is more of a sticky tire if thats what your looking for.
1wardogusmc is offline   Reply With Quote
Old June 14th, 2016, 03:38 PM   #20
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Have you taken the MSF yet?
If not they will teach you how to ride on rough roads.
1. Stay light on the bars. Any input on the bars become output by the bike (all the way to the tires)
2. Raise up off the seat when going over bumps.
The tire size won't make as big of a difference as proper riding techniques.
The tire pressure can also change the feel, to much will give less grip.
Old June 14th, 2016, 04:38 PM   #21
Actually, a larger tire will make your bike less stable, the suspension worst and the lean angle bigger.
There is a reason for the engineers that designed your bike to specify that size of tire.
Regarding grip, you can rest assured that at this stage of your riding development, you have a huge amount of grip in reserve.
Old June 14th, 2016, 05:59 PM   #22
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
ahhh no
the 140 is the width of the tire, the next number is the aspect ratio or height in % of the width. So a 140/70 17 140(width in mm)/70 (height 70% of 140mm = 98mm) 17 (rim diameter in inches)
With that being said a 130/70 17 would have an aspect ratio of 70% of 130mm = 91mm
98 - 91 = 7mm so a 140/70 17 would be 7mm higher than a 130/70 17 if they were the same tire other than size.
Old June 14th, 2016, 06:08 PM   #23
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Originally Posted by subxero View Post
ahhh no
98 - 91 = 7mm so a 140/17 17 would be 7mm higher than a 130/70 17 if they were the same tire other than size.
130/60 is what was ZeroGravity posted here. 60% of 130 is 78. 98-78mm = 20mm. half of that is 10mm.
Old June 14th, 2016, 06:11 PM   #24
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
^ you are still wrong just FYI
Old June 14th, 2016, 06:25 PM   #25
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Whatever helps you sleep at night.
Old June 14th, 2016, 06:45 PM   #26
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
^ seriously, why are you dividing the aspect ratio difference by 2?
Old June 14th, 2016, 07:22 PM   #27
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
Two thoughts on this:
It could be the suspension. The stock Ninjette suspension is not the best even when tuned and if not appropriately set this could easily make the ride feel bumpier/less stable
It could also be the advantage of the Ninjette: light weight/flickability. A larger bike will weigh more and thus have more momentum keeping it going the way it's going. It will also have wider tires for reasons already discussed. If you're tight on the bars or otherwise giving input in rough situations then this ease of maneuver could work to your detriment and make the bike feel less stable. Good throttle control and light on the bars is the number one way to stabilize a bike, regardless of size.
Old June 14th, 2016, 08:30 PM   #28
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
yes, you can put on a tire up to 150/60/17 on the new gen 250. I ran Metzeler M5 150/60 on the rear for a long time.
this is the left over from max lean angle.
TEAM ALFALFA
www.apexassassins.com
Old June 15th, 2016, 04:38 AM   #29
I don't know about divide by 2, but it seems that the discussion is missing the multiply by 2 that is necessary when calculating tire height. Yes - 140/70 means that the height of the tire is 70% of 140, or 98mm. But that's on both the top and bottom of the wheel, so the overall diameter of the tire is 98mm for the top of the tire, + 17" for the wheel diameter, + 98mm for the bottom of the tire. A difference of 7 mm in the calculated tire height of the tire itself, by tire size, would be a 14mm difference in actual tire diameter on the bike, right?
All of this gets fuzzy in the real world, as the tire sizes themselves aren't exactly accurate, and differ based on manufacturer and type of tire.
Old June 15th, 2016, 05:01 AM   #30
DEFY
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
DEFY's Avatar
Originally Posted by Alex View Post
I don't know about divide by 2, but it seems that the discussion is missing the multiply by 2.
Alex, I would have thought of all people you would think of it as a shift left or right
Spoiler for topic:
It might just be the [you] tag
Old June 15th, 2016, 05:11 AM   #31
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
I guess the devil is in the details and it pays to be as clear as possible.
Originally I was only talking about how much the rear would raise the rear end of the bike. So I was only using the change in aspect ratio (x1) as the other side of the tire would be facing up and have no effect on ride height. But yes, you are correct the overall tire outer diameter would be different
(aspect ratio x2)
And I totally agree on different tires, I did make it appoint to say this is only accurate if it was the same tire just in different sizes. I know far less about street tires than off road tires but in the off road world off the top of my head Dunlop, Pirelli and Bridgestone I think, use the same sizing, Then Michelin uses a different sizing, and so does IRC. In off road tires a Dunlop 120/100 18 is comparable to a IRC 140/80 18, and the Michelins run "small" as well. it might be a 130 = a 120 Dunlop there, its confusing and annoying at best.
Old June 15th, 2016, 05:32 AM   #32
ZeroGravity360
why is there math in this thread! lol, my head is hurting already...
Old June 15th, 2016, 05:43 AM   #33
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
I dislike math as well but unfortunately it is quite important to motorcycles and their geometry which effects many aspects of handling.
Fortunately this math is easy Start looking at the math as far as how that couple of mm is going to effect the rake and trail of the bike and then your head will really start hurting.
Motorcycle frames are practically designed from the tires up. The engineers need to know what size tires they plan on using on the bike before they start figuring out the chassis geometry and fork/shock length ect... to give the bike the desired handling characteristics they wish to achieve. Is 7mm here or there going to make a drastic super dangerous change... probably not but just be aware that changing the tire size is give and take with the handling of the bike and a few small changes can add up to make big differences.
Old June 15th, 2016, 06:09 AM   #34
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
I wouldn't recommend the pilot powers. They lack a lot of feel.
Old June 15th, 2016, 06:16 AM   #35
ZeroGravity360
After reading so many people giving good advice on here, I researched it hard yesterday. A few people even went to 150/70/17 on th eback and 130/70/17 on the front. They reasons they gave was because they like the way it makes it look like a 600. I agree it loos much better with bigger tires, even if it doesnt improve handling, i think it is cosmetically appealing :-p
Old June 15th, 2016, 06:58 AM   #36
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
what ever floats your boat, some people find this cosmetically appealing, I mean who really cares about form and function right? If you can't ride well then you might as well at least look good while riding.
Old June 15th, 2016, 07:35 AM   #37
So... You realize there's about 1,000 differences between a ninja 250 and a 600cc Supersport... right?
Pardon my density, but how in the heck did you narrow it down so quickly and confidently to just that one variable; tire width?
Old June 15th, 2016, 07:47 AM   #38
allanoue
allanoue's Avatar
MOTM - Sep '14
It is a bad idea to put 130s on the front.
Old June 15th, 2016, 08:23 AM   #39
ZeroGravity360
i was thinking of keeping a 110 because they are the ones that come in the set:
http://www.bikebandit.com/tires-tube...7_QaAhKt8P8HAQ
Old June 15th, 2016, 08:35 AM   #40
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Function before looks
Rear Brake Lever Travel is Excessive and Rear Brake won't Lock Tire. N-m 1986 - 2007 Ninja 250R Tech Talk 14 July 17th, 2014 04:13 AM
rear tire akcalhoun 2008 - 2012 Ninja 250R Tech Talk 7 February 21st, 2013 09:22 AM
need new rear tire?? mhesse 2008 - 2012 Ninja 250R Tech Talk 5 June 30th, 2011 04:46 AM
rear tire james250ninja 1986 - 2007 Ninja 250R Tech Talk 5 October 16th, 2010 12:58 AM
Wide rear tire Snake 1986 - 2007 Ninja 250R Farkles 22 February 15th, 2010 09:30 AM
