Old August 7th, 2022, 07:40 PM   #1
Sandr
09 250r Ignition coil/wire replacement. Aftermarket solutions?
I'm having trouble with the bike, and we think we're having Ignition coil problems on the right side. All I can find are OEM coils/wires all in one for upwards of 150 USD each. Is there an aftermarket solution anyone has found? or ones from another model that would plug N play?
Please link me solutions
Sandr is offline   Reply With Quote
Old August 7th, 2022, 08:07 PM   #2
hi, have you isolated problem to actual ignition coil itself?
As in swapped coils between sides and have problem move with coil to other side?
Most of times, it's wiring issues that cause ignition issues.
1. If it indeed is coil issue, you can use any variety of inductive coils. From pretty much any bike, or even auto coils such as Accel or MSD.
2. can convert to COP using CBR600RR coils. Be sure to get units of similar primary-impedance of stock coils 2.2-3.5 ohms. Or add ballast resistors. Want current draw around 0.5-0.6a. https://www.ninjette.org/forums/showthread.php?t=123425
3. I've got some pre-gen coils I can send you for cost of shipping.
Old August 8th, 2022, 09:06 AM   #3
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
I used ZX-6R CoPs on my EX500. I got 4 of them with the harness (enough to convert two bikes) for under $25 on eBay.
It didn't really seem to change performance at all, though I was able to open the plug gap up a bit with no issue. However, it simplifies things and removes the plug wires and the issues they were known to have.
Old August 8th, 2022, 01:33 PM   #4
Saves some weight too!
Old August 9th, 2022, 11:48 AM   #5
Ghostt
Ghostt's Avatar
Go with the CoPs set-up, much better in the short, and long run.
I did a write-up awhile ago
https://www.ninjette.org/forums/showthread.php?t=241339
Like @InvisiBill, I also run this set-up on both of my EX500s, and I did on my PreGen 250.
I didn't bother with installing anything extra, no load resistors, etc. Just be sure to get wiring harness with the coils.
FYI the Ninja 300 uses CoPs from the factory.
violente et ignorantia
ZX-2R BLOG
Old August 9th, 2022, 05:30 PM   #6
Depends upon set you get. Some people have had issues with too much current.
https://www.ninjette.org/forums/showthread.php?t=259402
Kawasaki ZX Ignition Coil Pack/ coil over plugs (CoPs) modification. Ghostt 1986 - 2007 Ninja 250R Tech Talk 44 June 10th, 2019 03:48 PM
Wire going to coil - What is it? Jpc647 1986 - 2007 Ninja 250R Tech Talk 10 July 31st, 2018 06:14 AM
Ignition coil wire leads headshrink 2008 - 2012 Ninja 250R Tech Talk 7 June 25th, 2014 05:59 PM
2012 ninja 250R ignition coil question webfoot 2008 - 2012 Ninja 250R Tech Talk 5 June 22nd, 2014 10:18 PM
