August 9th, 2012, 10:34 AM | #1 |
help me please lol
i have an issue with my ninja pre gen, it idles fine starts fine,but when i try to ride it it seems to have a rev limiter in all speeds,and it is erratic,it sounds like it is blip blip blip blip blip,i pull in the clutch and rev it up and it still blips then it will rev higher some times, i do notice that the fuel filter doesnt have much gas in it ,in the on position but seems to run better on reserve but still does a blipblipblipblipblip,and i have to feather the clutch at a low speed all the way home,i cleaned out my tank it was a lil rusty,but the fuel filter is really clean and i replaced it couple weeks ago, this problem just started two days ago,any advice would help thanks
August 9th, 2012, 10:59 AM | #2 |
Join Date: Jan 2012 Motorcycle(s): Blue 08 250 - Blue Magic Posts: 162
I'm pretty new to this but I think you're on the right track - it sounds like fuel delivery. If the tank had rust or garbage in it, it could have gone to the carbs? Maybe clean the bowls and possibly the jets?
August 9th, 2012, 11:28 AM | #3 |
i dont think it is the carbs this time, i had cleaned the carbs 3 time already before cause rust made it to the carbs because of lack of good fuel filter,and it ran great after, but the filter is brand new and squeeky clean,i think the hose on the pet cock might be the culprit cause gas is trickling out to the filter very slow, on open or reserve, thanks for the reply i appreciate your time and knowledge
August 9th, 2012, 11:50 AM | #4 |
August 9th, 2012, 12:44 PM | #5 |
uhh... are you sure its not actually hitting the rev limiter?
check your ground connections. maybe a loose ground wire? maybe a plug wire coming out? maybe the wiring to the coils is iffy.
August 9th, 2012, 01:01 PM | #6 |
What year is your bike?
August 9th, 2012, 01:37 PM | #7 |
Jigglin' your Jiglets
MOTM - Apr '13
Are you an ex-ninjetter because you can't get your bike to run?
August 10th, 2012, 12:21 AM | #8 |
troll bait
Join Date: Jul 2012 Motorcycle(s): 2006 Ninja 250EF Posts: 72
Just lol | JELY1990 | Videos | 19 | June 12th, 2013 02:41 PM |
lol | Z300 | Videos | 16 | December 16th, 2012 08:52 AM |
Just saw this lol | Z300 | Videos | 8 | October 9th, 2012 11:01 AM |
Hi All! I need as much help as I can get lol | W.Roworth | New Members | 28 | September 18th, 2012 06:19 PM |
NEW to EVERYTHING lol | iknowyouz | New Members | 19 | August 29th, 2011 11:14 PM |
