Old October 29th, 2011, 10:19 AM   #1
little fish
little fish's Avatar
Motorcycle(s): 2003 Nija, 1984 es200 ATC
valve adjustment
well that was easy, just adjusted the valves to the 250 and it only took about an hour, pretty straight forward. runs ALOT better and idles great now.
two of the exhaust vavles were real loose and the rest were too tight all good now.
little fish is offline   Reply With Quote
Old October 29th, 2011, 10:25 AM   #2
Old October 29th, 2011, 10:25 AM   #3
How many miles on the bike?
Old October 29th, 2011, 10:27 AM   #4
WhiteRice
Kamikaze Squirrel
WhiteRice's Avatar
Motorcycle(s): 2010 250r
One hour? That's awesome. Was it your first time? What informational materials did you use?
WhiteRice is offline   Reply With Quote
Old October 29th, 2011, 10:48 AM   #5
little fish
the bike has a little over 15000 i followed the steps i found at http://faq.ninja250.org/wiki/What_is...t_procedure%3F
Old October 29th, 2011, 10:58 AM   #6
Jono
Jono's Avatar
Glad it went smoothly!
Old October 29th, 2011, 03:07 PM   #7
greg737
Motorcycle(s): -
Glad to hear the adjustment went smoothly.
Because your bike is younger than a 1996 model and because it has 15,000 miles on it I think you'll find that this valve adjustment will last for quite a while. In other words, it should take a while for the valves to tighten up again (probably 5000 miles or more of normal riding).
The aluminum alloy used in casting the EX-250 cylinder head prior to 1997 was softer and wore more quickly than the alloy they've used since then (about 1997 to present model). Also, with 15,000 miles on your bike most of the deformation that will occur in your engine's valve seats has already happened.
The valve seats in the cylinder head get harder and wear more slowly as the miles add up (maybe the repeated heat-cycling of the engine over all those miles tempers the valve seats). Things should be pretty stable for about 5000 miles as long as your engine is never overheated (which can cause the valves themselves to "tulip" which will also cause them to go out of proper adjustment, becoming "tight").
Old November 4th, 2011, 08:32 AM   #8
pop0tart
Motorcycle(s): stolen :(
Did you notice a different sound when riding with the adjusted valves? It definitely sounds like my valve train is making a bit of a different sound since I did my valves. All of my exhausts were too tight before adjusting.
pop0tart is offline   Reply With Quote
Old November 4th, 2011, 10:10 AM   #9
little fish
only that the rattling sound went away. i adjusted mine to .005 / inch on the intake and .006 / inch on the exhaust i'm not racing so i didn't need them on the tight side. my idle is set at about 1100 rpm. and at @ 100 mph i'm hitting 11k-12k rpm ( just wanted to see if the little rocket would go that fast).
just make sure, after you adjust the valves and you ride for about an hour ..go back and make sure the valve cover is still snug. i noticed i could tighten mine a quarter turn after my first ride....one week later still no leaks.
Would you do your valve adjustment? Bigballsofpaint 2008 - 2012 Ninja 250R Tech Talk 30 July 24th, 2013 09:04 PM
Valve Adjustment quarterliter 1986 - 2007 Ninja 250R Tech Talk 7 June 25th, 2013 05:32 PM
Valve adjustment ?s Jewtoys 2008 - 2012 Ninja 250R Tech Talk 5 August 1st, 2012 08:47 PM
Valve Adjustment-Really Tight adjustment screw? mikesova 1986 - 2007 Ninja 250R Tech Talk 5 May 2nd, 2010 04:57 AM
anyone want to help with a valve adjustment? diablo250 Group Rides and Local Events 2 March 28th, 2010 02:00 AM
