March 28th, 2015, 02:33 PM | #321 | |
1st off: You shouldn't be dragging stuff in the first place. A proactive review of your riding every now and then should reveal a potential problem before it happens. And yes, I know emergencies can change this, when you need to lean.... by all means... lean it. Never give up until the bike does! 2nd: Your default reaction to most corner issues should be to continue the throttle roll. UNLESS.... you get into real nasty stuff or real trouble. Then... as I have done many times... (as a couple of ninjette members have witnessed...) Stand that bike up and use every inch of pavement you have to brake as hard as you can in a controlled way. The simple reality is... if your gunna hit something anyway, why not hit it at 25mph vs. 50mph. Just before you get to the edge of the pavement, you are at the moment of truth, can you turn the bike again? If so, then flick that sucker in hard and do it without hesitation. Now there is an exception to my answer to #2. The hook turn is a "track oriented" technique that pays dividends on the street when you find yourself in a "situation". Honestly... you aint got much time to figger out what to do, but whatever you do, do it with conviction and purpose. A timely executed hook turn can save many turn in point and bad line issues. The main reason you hook it is, to not violate throttle control rule number 1 and yet still be able to tighten you line mid corner. If you feel you need to widen your line... countersteer the bike up, roll off (do not chop it!!!), avoid your issue, repoint the bike (resteer) and get back to the throttle ASAP! Lastly... pray you never need to do any of the things listed above.
March 28th, 2015, 03:18 PM | #322 |
i believe i would rather try to go for the turn and lowside on pavement and deal with a 6 inch drop and slide than i would straight line it off road on the brakes, instantly lose traction and hit a tree or guard rail or something
March 28th, 2015, 03:34 PM | #323 |
Private Joker
MOTM - Mar '14
Id go that far in the second attempt but I'll let myself correct and brake before I let myself run the risk of lowsiding
March 28th, 2015, 03:38 PM | #324 |
i always trail in so it's usually not an issue to just trail it further in, but when you've already gone down all the way and that blind decreasing radius turn gets tighter up ahead and you need to make some buffer in order to pull up and do some extra hard braking again... sometimes you just run out of room from the retry and you just have to go for it. you know you'll scrape it up but i'd rather go back down and go for it rather than just hope for the slowest impact on the side.
March 28th, 2015, 03:42 PM | #325 | |
Either way... good braking braking has the possibility of slowing down faster than a body sliding on pavement. I see what your getting at though. If the rider isn't good on the brakes you're hitting the tree faster than sliding into it. That is a call I can't make though, the rider must make it. Then there is the human part of things, when at the end of the day the rider asks "why" and what could I have done differently. When I go to bike night, I hear "I just leaned and prayed" most often. We both known each other Alex, you know I am not a fan of "just praying". But then again... I also know, that many riders are not even close to the limits at that moment of truth when they believe they are going down. It's a tough call to make, and even harder when asked the question on an internet forum. :\
March 28th, 2015, 04:11 PM | #326 | |
Also, when you run outta pavement (tire hits dirt) the game totally changes. I am not really throwing that into the mix as the choice to give up or leave it up to luck has already been made at that point. Ya know... only somewhat relevant to the current question asked by cadd.
March 28th, 2015, 04:15 PM | #327 |
for sure.
and yeah running off the track is totes different from on the street. i don't even know how many times i've run off the track. those little ninjas offroad pretty well when you got the room. worst ive done was blowing turn 5 at chucky on the 600 and hitting the burm... somehow didn't go down... got back on track at the pit in and nursed my balls back to life
March 28th, 2015, 04:38 PM | #328 |
here i was playing with the video editor and got carried away.
March 28th, 2015, 07:03 PM | #329 |
cadd cadd cadd
MOTM - May '15
2 question for you track guys (and girls):
1- Is it necessary to get your knee down on the track (250/300 specific)? Would a knee down always = faster speeds? 2 - When the feelers on the pegs touch down....at that lean angle....with proper body positioning, would one be able to get his/her knee down? I'm just trying to get a mental image of how leaned over you have to be to get the peg feelers down. |
March 28th, 2015, 07:08 PM | #330 | |
March 28th, 2015, 07:12 PM | #331 | |
Private Joker
MOTM - Mar '14
knee down does not always mean faster, in fact I have passed several riders who were knee down mid corner without my knee down simply because I apexed later and was able to power out sooner and had more drive out of the exit while they were still leaned over. As a rule of thumb though, if someone is taking a good line and has their knee down they're probably flying. 2. If your bp is right you'll drag knee before feeler or peg. Personally I believe the absolute limit of lean to be when you are dragging your knee, elbow, and your peg at the same time. To reach that level of lean requires an insane amount of commitment to yourself and practicing your riding skills at the track. The feelers will touch down pretty quick but won't be an issue. Personally I remove mine since I use my knee as my feeler at the track and I don't ride hard enough on the street for it to matter. If you want to know how far leaned over you need to be to get the pegs down just tip your bike over seriously though, sport bikes (ninjette included) have crazy ground clearance and you're more likely to hit your own mental limit than to hit the bike's limit of lean until you're very comfortable with the bike. Also, scraping pegs is and isn't a big deal. It isn't going to put you down right away if you're just skimming them but if you're touching your pegs to the ground while riding at all you need to be on a track for your own safety. edit: beaten to it by @csmith12 guess it pays to not be so long winded
March 28th, 2015, 09:02 PM | #332 | |
2, with proper body positioning, you would be dragging all kinds of body parts long before you touched any hard parts. you gotta be over pretty damn far to be touching your pegs... with good body position, you'll be sliding around from so much lean before you would be touching things... so with good body position you almost never worry about it unless you're really givin it what for.
March 29th, 2015, 04:18 PM | #333 | ||
Join Date: Feb 2015 Motorcycle(s): Ninja 300, Duke 690 Posts: 33
March 29th, 2015, 04:25 PM | #335 |
I have stock Woodcraft rearsets in the top-rear position and once I get excited there can be quite a lot of peg-dragging action That said, when the excitement gets high my body pos might suffer a little bit too... I'll also notice pretty quickly if I position my foot too far down on the edge of the peg - since switching to a 300 on the track I get the full money's worth out of my replaceable toe sliders
March 29th, 2015, 10:10 PM | #336 |
Join Date: Feb 2013 Motorcycle(s): 1999 Ninja 250ex 1989 Ninja 250ex 2005 Ninja 250ex 2007 Ninja 250ex 2011 Ninja 250r 1993 CBR600 Posts: 199
"I had so much fun crashing my Ninja" - Said by No One Ever |
March 29th, 2015, 10:50 PM | #338 |
What is that haha?
March 29th, 2015, 11:11 PM | #340 |
ohh haha. Should I changed it up?
March 29th, 2015, 11:15 PM | #342 |
Oh well fine then.
March 30th, 2015, 02:20 PM | #343 | |
Track Clown
MOTM - Sep '15
2. When i had stock pegs, i removed the feelers and from cornering the pegs were ground to the rubber. so yes. |
April 5th, 2015, 11:41 PM | #344 |
Wannabe racer
Join Date: Aug 2014 Motorcycle(s): 2010 ninja 250 race prepped, 2009 Zx6R Posts: 96
the first and only time i have hit peg i low sided at the track ha.. a combination of things.. this is a crappy pic but shows a decent lean angle.. couldve had my knee closer in. After riding more and gaining more track experience you see all these crazy BPs that you have to wonder if they are hindering or helping but all that matters is your position when the checkered drops in the end i guess.. I have felt that my bp is decent but i use my knee like a crutch and sometimes im mid corner and think to myself "i need to pull my knee in to get more lean and carry more speed" or that it is taking me off my line but not allowing more turn in so i pull it up and in and it works well. When i was down at chuckwalla one of their super fast dudes rides way tight to the bike even at full tilt so his knee isnt out or down as much as i would have thought it was but he romps like crazy..
May 26th, 2015, 12:31 PM | #345 |
Join Date: Oct 2010 Motorcycle(s): currently: Yamaha YZF 250 dirt/motard Posts: 787
Just thought I would post my new favourite photo from this past weekend mini racing. This is on the Kayo 125 mini GP bike So much fun!!
"Leap and the net will appear!" superbikeschool.com www.motomom.ca |
May 31st, 2015, 09:15 AM | #346 |
That pic is great. I'm thinking, damn that GoPro camera is huge. Before I realize that the rider isn't huge, and the bike is actually tiny. The very slick proportions on that bike don't give away its size without a reference.
May 31st, 2015, 03:40 PM | #347 |
I like that suit pattern.
The picture looks like when people photoshop their track pictures to make their head the proportion of a bobble head. |
June 2nd, 2015, 03:16 PM | #348 |
June 2nd, 2015, 03:24 PM | #349 |
Welcome Marko!
June 4th, 2015, 11:01 AM | #350 | |||
Looks pretty good! Quote:
June 4th, 2015, 12:26 PM | #351 |
Fighting Texas Aggie '05
Found a pic of you while pursing OMRL facetubes lol
June 7th, 2015, 01:30 AM | #352 |
Join Date: May 2009 Motorcycle(s): 2007 EX250 (street), 1994 EX250 (Race), 2008 250R (Race), 2000 250 (project), 1991 EL250 (a cruiser!) Posts: 287
Here's a screen capture from my last race weekend. I rotated the image to make the horizon closer to flat.
AFM #867 (5309) |
June 7th, 2015, 01:42 AM | #353 | |
And here's me in the very same corner, same race weekend Edit: Ah, that is T3, this is T5b... Photo by 4theriders/Joe Salas |
June 9th, 2015, 07:05 AM | #354 |
Looking good through there!
AFM #867 (5309) |
June 9th, 2015, 10:00 AM | #355 |
vampire
Join Date: Feb 2011 Motorcycle(s): 2 many 2 list Posts: A lot.
One of my fav winter activity:
Back in 2003, I visited Moab, UT with my dirtbike: Last futzed with by "A"; June 9th, 2015 at 07:07 PM. |
June 10th, 2015, 12:52 PM | #356 |
I had just made a sweet sweet pass Can't wait for the next race weekend!!!
Did you see that my kid (just turned 6) did his first race that same weekend. He's kinda addicted.
June 23rd, 2015, 11:01 AM | #357 |
Ok, had to share this photo of my son's (just turned 6) second race! He's proving to be a natural
4 out of 4 members found this post helpful. |
June 23rd, 2015, 11:13 AM | #358 |
Nice!!! Hoping to get my son on the track this season. Like you, imma put him on the kart track first.
Nice!!!! Time to raise those pegs and love to see the kids puttin' in werk! They are the future.
June 24th, 2015, 12:31 AM | #359 |
Join Date: Jan 2014 Motorcycle(s): SC28 Fireblade Posts: 463
+1 same here I have a year to go with school.
94 900RR 04 BMW Z4 2.5 M Package 01 R170 AMG Sport Package |
June 24th, 2015, 02:28 PM | #360 |
Join Date: Feb 2015 Motorcycle(s): 286, 296, 599, 799 Posts: 436
hard to hang off at 4'10"
This never gets old. Braking with lean angle. | Gurk | Riding Skills | 33 | April 27th, 2014 10:46 AM |
[visordown.com] - Caption that the 85 lean angle | Ninjette Newsbot | Motorcycling News | 0 | February 25th, 2014 07:00 AM |
Got a new Bike and some lean angle ;D | WesleySnipes | Pictures | 7 | October 29th, 2013 07:20 PM |
[motogp.com] - The Lean Angle Experience | Ninjette Newsbot | Motorcycling News | 0 | September 26th, 2013 10:40 AM |
Ever wonder what serious lean angle looks like | rojoracing53 | Videos | 6 | April 4th, 2013 12:06 AM |
