Old April 13th, 2010, 07:06 PM   #1
DRivero
DRivero's Avatar
Motorcycle(s): 2001 Ninja 250 (Sold); 2008 Ninja EX500
12V cigarette lighter plug-REALLY basic DIY?
Okay, I've searched high and low, and although there are plenty of DIY's out there, they all assume that the reader has some basic knowledge of these things (i.e.: Step 1- connect the wires directly to the battery; Step 2- install an inline fuse......um, huh?). I do not possess such knowledge.
I do, however, have this:
and THESE:
(Incidently, I'm not sure what those wires are; they're just sort of laying there. My bike is a 2001; I've heard that gen Ninja has "accessory wires", but heck if I know if this is them)
So, anyone seen a VERY BASIC, created-for-a-six-year-old, idiot's guide-type DIY for hooking one of these up? OR.....maybe someone can take pity on me and create one? OR.....truly take pity on me and just come here and install it? Okay, that last may be a bit much to ask; I just want the gorram thing on my bike, and I don't feel like blowing my electrical system in the process, just because I'm a dumbass.
A little help?
DRivero is offline   Reply With Quote
Old April 17th, 2010, 08:23 AM   #2
foxpaws
Motorcycle(s): 10 kawi ninja 250
+1
also, maybe this should be in the one of the tech forums.
foxpaws is offline   Reply With Quote
Old April 17th, 2010, 10:16 AM   #3
JeffM
Mr. 988
JeffM's Avatar
Motorcycle(s): One
Not sure what those wires are however, http://faq.ninja250.org/wiki/What_ar...to_anything%3F
The ones in the front
And the ones in the middle on the right side by the fuse box
JeffM is offline   Reply With Quote
Old April 17th, 2010, 10:52 AM   #4
Snake
Snake's Avatar
Both those wires are 12 volt power sources that you can conect accessories to. Only the pre-gens have the ready to connect wires.
Old April 17th, 2010, 11:50 AM   #5
2WheelGuy
2WheelGuy's Avatar
I put one of those in my bike to charge our phones while we are camping at MotoGP. I keep it loose in the tail of my bike. If you want it accessible you can make a mount in the fairing.
It's quite easy. Go to radio shack and get an in-line fuse, a couple of connectors, some extra wire and connection wrap.
Fuse:
http://www.radioshack.com/product/in...ductId=2102782
Connectors:
http://www.radioshack.com/product/in...ductId=2103495
(Not sure if this is the correct size. The ones I use say #12 1/4" stud. Make sure the battery bolt will fit through the hole.)
Wire:
http://www.radioshack.com/product/in...Value=18+gauge
(Get the same gauge as is on the outlet, should be about 18 gauge.)
Shrink Tubing:
http://www.radioshack.com/product/in...lickid=prod_cs
(You need to cover your wire connections. You can substitute good ole' electrical tape but I prefer shrink tubing. It is much cleaner and more durable than tape.)
Solder:
http://www.radioshack.com/product/in...odsInSession=1
(You need to solder you wire connections to keep them secure. You'll need to heat the wire to melt the solder. You can use a soldering iron, a small torch or even a cigarette lighter.
If you prefer not to use solder/shrink wrap you can use butt splice connectors. (Yeah I said "butt splice" )
http://www.radioshack.com/product/in...ductId=3004022
(I don't like using these but they do work.)
First: locate your socket where you want to mount it.
Next: attach your in-line fuse to the positive (red or white) wire.
(To solder wire together. Strip 1/4"-1/2" of insulation from the wire. Use a wire stripper or razor blade or sharp knife. Cut 1-2" of shrink tubing and slide it over one of the wires. Twist the two wire ends together. Heat the wire and apply the solder until it melts into the wires. (It is common for the solder to drip so don't do it over anything important.) Slide the heat tube over your connection and heat it. (Hair dryer or quickly moving a cigarette lighter over it until it shrinks.)
==>Alternatively you can use the butt splice connectors. I'd recommend you get a crimping tool if you use these.
Next: attach a length of wire from the fuse to the battery positive terminal +.
Repeat: attach a length of wire from the negative (black) wire of socket to the negative - terminal of battery.
Next: attach connectors to the ends of your wires. (You should use a crimping tool but you should be able to get a good crimp with a pair of pliers.)
Finally: remove the two battery bolts (negative first). Attach the socket connectors and replace the battery bolts (negative last).
If you stop by my house I'll install it for you, for a small fee.
AFM #278
Old April 18th, 2010, 01:24 PM   #6
cnichols79us
Fastly Slow!!!
cnichols79us's Avatar
Motorcycle(s): 2007 Kawasaki Ninja EX250, 1980 Honda XL125
I just tried this with that EXACT same 12 volt acc. plug, AND the plug was bad right out of the packaging.....
cnichols79us is offline   Reply With Quote
Old April 20th, 2010, 05:16 AM   #7
demp
I seem to have the exact same problem - same plug, and I can't believe it's a bad plug, but it does appear to be. Tried wiring it in the exact same way I had my gps hooked up and it just won't work.
Old June 27th, 2010, 06:56 PM   #8
DRivero
DRivero's Avatar
Okay, I'm bumping this because I am beyond confused.
I bought the adapter (in the photo above), and I've connected it a couple different ways, trying to decide which is best. I settled on using the pigtail for my battery tender, permanently attached. I bought the same type of connector that's on the pigtail and crimped it onto the 12v adapter. When I plug in my 12v Slime tire pump, it works great. When I plug in my car charger for my phone, the little green light on it lights up, but it will NOT charge my phone. I thought maybe it was some sort of resistance issue with the connector I hooked up (boy, I almost sound like I know what I'm talking about, huh? Yeah...I don't. Moving on.....), so I removed it and touched the 12v adapter wires DIRECTLY to the battery, with the same result: little green light, yes....charging phone, NO.
I have now reached the end of my electrical knowledge, and I'm stumped (admittedly, this is no great feat). Does ANYONE have any ideas?
www.facebook.com/#!/profile.php?id=1568567524
Old June 27th, 2010, 07:24 PM   #9
bob706
bob706's Avatar
This is the one I followed when I did mine
http://www.kawiforums.com/ninja-250r...t-install.html
Old June 27th, 2010, 07:52 PM   #10
Soujyu
Did you try this with the engine running? Also, can you give us the output current and voltage of your car charger?
Old June 27th, 2010, 08:00 PM   #11
DRivero
DRivero's Avatar
Yes, tried it with the engine both off and on. No dice.
I would be happy to.....just, um....tell me how? I do, unbelievably, have a voltmeter (left over fom the ex), but no clue how to get it to do my bidding. Yes, I know you're all probably thinking, "Step away from the motorcycle, Debbi...."
Posted via Mobile Device
Old June 27th, 2010, 08:12 PM   #12
Soujyu
It should be written on the charger itself. I'm concerned that your charger may be overtaxing the electrical system on the bike, which may explain why your phone is not charging.
Old June 27th, 2010, 08:15 PM   #13
Snake
Snake's Avatar
The only thing that I can think of is that the wires may be backwards. I'm sure you hooked the positive (+) wire from the adapter to the positive (+) wire leading to the battery and the negative (-) wire from the adapter to the negative (-) wire leading to the battery so this is just a wild guess on my part.
Old June 27th, 2010, 08:16 PM   #14
DRivero
DRivero's Avatar
Oh! Reading I can do....
BRB!
Old June 27th, 2010, 08:33 PM   #15
Snake
Snake's Avatar
Since the motor on the slime tire pump will run foward (blowing) or backwards (sucking) a simple way to make sure you have the wires hooked up correctly is to plug in the pump and see if it sucks or blows. It's worth a try.
Old June 27th, 2010, 08:41 PM   #16
Originally Posted by Snake View Post
...is to plug in the pump and see if it sucks or blows.
And what self-respecting thread could ever be considered complete without a Spaceballs reference?
(cheat-sheet for spaceballs quotes)
Old June 27th, 2010, 08:52 PM   #17
Snake
Snake's Avatar
Which one?
This one:
"[aiming his Schwartz ring at Lone Starr's crotch] Say goodbye to your two best friends- and I don't mean your pals in the Winnebago!
I'll bet [Dr. Philip Schlotckens' nurse] gives great helmet.
Commence operation [pause] "Vacu-Suck"! "
or this one:
"Dark Helmet, Skroob, and Sandurz: [watching Mega Maid vacuum up Druidia's air] Suck...suck...suck! "
Trust me no pun was intended. Just trying to help.
Old June 27th, 2010, 08:54 PM   #18
This one, of course!
Colonel Sandurz: It's Megamaid! She's gone from suck to blow!
Old June 27th, 2010, 09:04 PM   #19
LED lighting discussion moved to this thread...
Old June 27th, 2010, 10:29 PM   #20
DRivero
DRivero's Avatar
Okay well the car charger itself is no help....it only says "Input 12v". Zero clue about the output.
As far as Rick's advice: I will test that theory tomorrow. I will add, though, that the adapter packaging states which wire is pos (the gray) and which is neg (white). Even so, I did try it the other way 'round, just for giggles.....that time, the Slime pump came on (sucking or blowing, I don't know which), but the green light on the charger stayed dark.
It's for sure a mystery to me, and it doesn't make me happy, but I can at least run my tire pump if I have to.
PS- Yay Spaceballs!
Old June 27th, 2010, 10:54 PM   #21
Soujyu
PS- Yay Spaceballs!
That worries me right there. Does your car charger work when you put it into a car?
If you've got a charger that works with a regular outlet, there's something else we can try.
Old June 27th, 2010, 11:16 PM   #22
PS- Yay Spaceballs!
does the charger have an inline fuse somewhere? if so, how many amps is the fuse?
Old June 28th, 2010, 03:29 AM   #23
karlosdajackal
karlosdajackal's Avatar
Motorcycle(s): Ninja 250R Fuel Injected Model 2009
For a LED to light up current has to be flowing in the right direction the D being a diode (a diode is a two-terminal electronic component that conducts electric current in only one direction). Your tire pump probably has one of these also to prevent it running backwards. So the output appears to be good.
I have a powerlet cable, which comes with an extra adapter as some devices don't recognize the cable as a charging cable, your phone may be one of these special devices. Got any other devices you can plug in and try?
My vlogs on Youtube are here
karlosdajackal is offline   Reply With Quote
Old June 28th, 2010, 10:37 AM   #24
DRivero
DRivero's Avatar
Well, I have a little auto vacuum cleaner (a Minimaid?)....somewhere; I'll have to dig it out. I also have a doohickey that plugs in to a cigarette lighter and converts it to AC power; however, I don't know if that's safe to try. It's probably fine, I know, but we fear what we don't understand, and I definitely don't understand electrical stuff.
Old June 28th, 2010, 11:11 AM   #25
Ash
Ash's Avatar
I just ordered:
http://www.powerlet.com/product/sae-...ket-cables/319
It is an aux power socket that plugs into the Battery Tender connector.
I found the website from another post on this forum about an iPod attachment.
Ash is offline   Reply With Quote
Old June 28th, 2010, 11:15 AM   #26
Snake
Snake's Avatar
This problem is a mystery to me. The slime tire pump should draw more current than the phone charger so I am baffled as to what the problem could be. I wish I could be of further assistance but I'm not sure what else to test or try.
Old June 28th, 2010, 11:19 AM   #27
Snake
Snake's Avatar
^^^^ I just went to the website and for the price it is worth a try. The nice thing is that it is a plug and play connection. No splicing required. Great find Ash.
Old June 28th, 2010, 11:26 AM   #28
DRivero
DRivero's Avatar
I just ordered:
Ummm......wow! I ALREADY have the pigtail connected to my battery! Okay, I'm totally ordering this. I think. How can I be sure that my phone won't have the same issue?
Old June 28th, 2010, 11:30 AM   #29
Snake
Snake's Avatar
There is no way of knowing that your phone will not have the same issue but at least you will have no doubts about the connections and can easily instal and remove the power socket as needed.
Old June 28th, 2010, 11:42 AM   #30
Ash
Ash's Avatar
I can't take credit it for it - I found the website from this post:
http://www.ninjette.org/forums/showt...ight=apple+12v
Ninja250 should get the credit
Old June 28th, 2010, 01:04 PM   #31
DRivero
DRivero's Avatar
You guys split the credit.....I followed 250's link and still never managed to find that nifty little item!
Old June 29th, 2010, 12:39 PM   #32
SCREEM
SCREEM's Avatar
Motorcycle(s): 09 250R, 08 connie 14, 08 honda ruckus(gave to mom)
try to find a marine SS socket with a rubber plug, regardless of where you install.
SCREEM is offline   Reply With Quote
Old July 2nd, 2010, 03:33 PM   #33
DRivero
DRivero's Avatar
UPDATE!
Ordered the Powerlet doodad....got it today....eureka, the gorram thing works. Shiny! (Any Browncoats out there?)
My advice to the non-electrical-savvy, like myself: Www.powerlet.com, 20 bucks including shipping, you're done.
Thanks, everyone!
Old July 2nd, 2010, 03:46 PM   #34
Ash
Ash's Avatar
I am big fan of Firefly and Serenity!
Old July 2nd, 2010, 04:04 PM   #35
DRivero
DRivero's Avatar
Woohoo, another Browncoat! Yay! Of course, I have every episode, plus the movie, on DVD because I'm a big ol' nerd. Ash, if you're ever down my way, I'll pop the popcorn. I can never get enough Jane!
Oops....off-topic, I know. Um.....yay, Powerlet!
Old July 3rd, 2010, 06:51 AM   #36
Ash
Ash's Avatar
TV/Movie nights are always fun!
FYI - The powerlet cables works as it should charging my Samsung Moment running Android.
Old July 3rd, 2010, 07:51 AM   #37
Snake
Snake's Avatar
Glad to hear it works. I love plug and play. Just stick the two ends together and you are ready to go.
Old September 23rd, 2010, 08:40 PM   #38
Rosie
Rosie's Avatar
Motorcycle(s): 2007 Blue Ninja 250R
Ok.. I'm trying to connect my GPS unit to a charger but I have no idea where to start and I have ZERO knowledge of electrical stuff so I went to the powerlet website hoping to find a magical outlet I could just hook up to the accessory wires and mount somewhere but when I search by vehicle the Ninja 250 is not there
Which one should I order?? Help please
Rosie is offline   Reply With Quote
Old September 23rd, 2010, 08:53 PM   #39
Ash
Ash's Avatar
Because I like to keep the battery charged in the winter when I am not riding, I use the Battery Tender Jr. Charger.
This item:
Is intended to be used in conjunction with the battery cable from:
http://www.amazon.com/Battery-Tender...5299982&sr=8-1
Old September 23rd, 2010, 09:06 PM   #40
Rosie
Rosie's Avatar
I see... hubby had to make a drawing so I could understand but I think I got it I'll go with the battery tender/cigarette lighter option. Thank you!
cigarette lighter installation Josh_kcco 1986 - 2007 Ninja 250R Tech Talk 12 March 29th, 2014 10:12 AM
Yet Another Cigarette Lighter Socket Install quanttrom 2008 - 2012 Ninja 250R Tech Talk 16 March 7th, 2012 10:42 AM
How To: DIY 12v Power Source ChaosFromAbove 2008 - 2012 Ninja 250R Tech Talk 4 September 27th, 2011 07:00 AM
Cigarette lighter socket for gadgets BobsPT 1986 - 2007 Ninja 250R Farkles 6 August 25th, 2011 11:30 AM
12v lighter adapter TnNinjaGirl 2008 - 2012 Ninja 250R Farkles 16 January 14th, 2009 06:44 PM
