Old April 11th, 2011, 12:47 PM   #1
Jesse8931
Jesse8931's Avatar
Motorcycle(s): 2007 ninja 250r
Brakes
How is your guys stopping power. Seems like mine is fading way to fast at 60mph it takes about 70ft to come to a complete stop.
Maybe I'm just used to my other bike witch stops really fast.
Jesse8931 is offline   Reply With Quote
Old April 11th, 2011, 12:52 PM   #2
when was the last time the brake fluid was changed?
Old April 11th, 2011, 12:56 PM   #3
Jesse8931
Jesse8931's Avatar
Not sure probably never. bike has 4500 miles so pads should be fine.
Old April 11th, 2011, 12:57 PM   #4
1994Ninja250F
‘94 Rider
1994Ninja250F's Avatar
Motorcycle(s): 1994 Kawasaki Ninja EX250F
There could be air in the system, which means you should start by bleeding the breaks. Also, it could be that the stock rubber lines are getting old. When the rubber ages, it "stretches" a little more when fluid is pushed through it, which translates to a mushy feel at the brake lever. The best fix for this is to install stainless steel brake lines.
1994Ninja250F is offline   Reply With Quote
Old April 11th, 2011, 01:00 PM   #5
Jesse8931
Jesse8931's Avatar
Already one the way along with new tires. Also whats up with the wobble above 40 with my hands off the bars. My buddys 07 model with less then 800 miles does the same thing so not really sure.
Old April 11th, 2011, 01:03 PM   #6
I would start with flushing the brake fluid and replacing with a relatively good fluid. I'm partial to this.... cheap, easily available and rates pretty well as a do it all type of fluid.
Old April 11th, 2011, 01:07 PM   #7
Jesse8931
Jesse8931's Avatar
Well since the new lines are on there way I will try the valvoline out.
Old April 11th, 2011, 06:17 PM   #8
shiftdrift06
Motorcycle(s): None
alittle off topic but has anyone swap brakes from a new gen?
shiftdrift06 is offline   Reply With Quote
Brakes what would you do? crazymadbastard General Motorcycling Discussion 7 March 30th, 2015 11:27 AM
Need new brakes! corksil 2008 - 2012 Ninja 250R Tech Talk 18 September 28th, 2014 11:36 PM
Brakes momoru 1986 - 2007 Ninja 250R Tech Talk 7 August 10th, 2014 07:26 AM
Better brakes?? LittleRedNinjette 2013 - 2017 Ninja 300 Tech Talk 39 July 11th, 2014 08:42 AM
Brakes marc_previtera 1986 - 2007 Ninja 250R Tech Talk 5 October 3rd, 2013 05:22 AM
