Old August 14th, 2017, 05:15 PM   #1
rustyshackelford
LED Indicator Lights
Does anyone know if I can replace the indicator lights (signals, oil pressure, high beams, neutral) by the speedo/tach with LEDs? I want to replace the gauges with a trail tech, but retain the indicator lights. I was thinking about putting together a separate little box with LEDs using the existing wiring.
Thanks!
rustyshackelford is offline   Reply With Quote
Old August 14th, 2017, 05:34 PM   #2
I replaced all my dash bulbs with LEDs. You just have to do the two diode and ground change to the turn signal indicator to isolate the two sides. Next time my speedometer or tachometer give me trouble, I'm going to replace the whole assembly with one of these:
https://www.dan-moto.com/DM_US/danmo...5d7990ca0273a8
It has all the indicators built in, so it'll be an easy swap for my non-fairing ninja 250.
Welcome to the board Jay!
Old August 14th, 2017, 06:13 PM   #3
rustyshackelford
Thanks for the welcome and the quick response! I'm planning on putting LED signals on anyways so that should work out perfect. That danmoto is pretty slick though, hmmm.
Wiring LED strips as brake lights, turn signals, and "day-time lights" blackninja18 2008 - 2012 Ninja 250R Farkles 32 August 7th, 2013 03:41 PM
Electric start problem, lights, blinkers, and indicator lights work. claymaker 1986 - 2007 Ninja 250R Tech Talk 8 July 10th, 2012 07:04 PM
newbie with another LED indicator issue illuzi0nz 2008 - 2012 Ninja 250R Tech Talk 13 April 10th, 2012 08:15 AM
