February 28th, 2011, 06:30 PM | #1 |
two ninjas, no regrets.
Join Date: Nov 2010 Motorcycle(s): RED 2009 Kawasaki Ninja 250R... Special Edition 2009 Kawasaki Ninja 250R Posts: 23
Cant find my stock resistor!!!! (Mitsuba FR22-091)
I recently purchased a hotbodies undertail with the LED turn signals and knew about the whole turn signals stay on issue so i purchased a Tridon LL552 Long Life Electronic Flasher and im staring at my bike as i type this trying to find the stock one!!!!! i found two things that look like it both are on the left side of the bike (if you were sitting on it) one is closer to the front of the bike almost beside the carburetor and the other one is beside the fuse box. i took each one apart and realized each had things screwed onto it. i dont see anywhere to screw anything on my new resistor. PLEASE HELP!
is this here the resistor? located beside the fuse box. http://s1185.photobucket.com/albums/...t=DSCN0103.jpg OR is this it? located near the carb. http://s1185.photobucket.com/albums/...3DDSCN0102.jpg not sure how to upload photos directly to the website so im just linking you to two photos i took. |
February 28th, 2011, 06:44 PM | #2 |
I take it you are looking for the flasher unit? It is located behind the left rear tail panel.
February 28th, 2011, 07:08 PM | #3 |
Thanks bro! i was clearly having a blond moment.. just installed it and it works perfect!
ignition bypass? 100ohm resistor | JarodVoss | 2008 - 2012 Ninja 250R Tech Talk | 11 | June 30th, 2022 06:11 PM |
[roadracingworld.com] - Bradl Goes 209.091 mph, Breaks MotoGP Top Speed Record For In | Ninjette Newsbot | Motorcycling News | 0 | August 16th, 2013 02:00 PM |
Looking for a place to find good prices on stock fairings. | blades8306 | Items Wanted | 6 | August 24th, 2012 08:51 PM |
FS: 08+ Yosh CF Slipon, Stock Headers, Stock Brake Lines, Stock Rearsets | Dmitriy | Motorcycle-related | 16 | August 24th, 2011 11:03 AM |
What resistor should I get for my LED's? | Poltart | 2008 - 2012 Ninja 250R Tech Talk | 15 | February 18th, 2010 12:49 PM |
