Old May 6th, 2014, 02:34 AM   #1
wkiltz
Motorcycle(s): 1997 Ninja 250, 1995 CBR 900RR
Header that blocks drain plug
yoshimura made it for a couple of years and also a muffler. i wish i can find any information on it. i contacted yoshi and all they said is that it was discontinued and they had no other information or pictures... does anyone know where i can find out about it. i had a 97 and it was on there when i bought it. i rode the thing for 10000 miles and never changed the oil due to a fear of stripping the exhaust bolts since they were so rusted. go ninja
heres a vid not very good
wkiltz is offline   Reply With Quote
Old May 6th, 2014, 05:07 AM   #2
Skullz
Skullz's Avatar
Motorcycle(s): 2012 Ninja 250
As bad as having the exhaust block the drain plug, not changing your oil for that many miles is the biggest problem, take it to an oil change place and have it evacuated through a tube inserted through the fill plug hole. You can make something cheaply if you aren't able to locate a shop capable of doing it, just get a turkey baster and small tube you can slide on the tip and slip it down the fill hole and suck it out that way, better to change something than to leave contaminated oil in it.
Another option is something like this for a more permanent solution for many other uses than just the bike.
http://www.ebay.com/itm/Mity-Vac-Air..._Tools&vxp=mtr
Old May 6th, 2014, 05:23 AM   #3
Skullz
Skullz's Avatar
Mispost
Old May 6th, 2014, 08:20 AM   #4
Chicagobob
Chicagobob's Avatar
Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B
Can you reach the bottom of the sump from the fill hole? If so, marine supply stores sell pumps designed to evacuate oil from a boat engine's dipstick hole. Doesn't help with the filter, though.
Chicagobob is offline   Reply With Quote
Old May 6th, 2014, 12:01 PM   #5
wkiltz
i had a valve cover leak so i was replacing oil... i added that to the post to just put out there that im amazed by how reliable and bullet proof the kawasaki ninja 250 is... i also had a coolant leak in which i would refill with water daily for the last two years i owned it... go ninja.... and im a honda nut
Magnetic drain plug for pregen? Ninjinsky 1986 - 2007 Ninja 250R Tech Talk 2 May 3rd, 2014 09:55 AM
Ok where's the drain tubes for the spark plug recesses? RBN 1986 - 2007 Ninja 250R Tech Talk 13 January 20th, 2014 10:19 AM
Oil leak from drain plug akh1685 1986 - 2007 Ninja 250R Tech Talk 7 October 4th, 2013 01:03 PM
Okay, so what's that OTHER drain plug for? adouglas 2008 - 2012 Ninja 250R Tech Talk 5 August 23rd, 2009 07:18 PM
Magnetic Drain Plug? chess 2008 - 2012 Ninja 250R Tech Talk 3 April 12th, 2009 07:14 PM
