Old April 2nd, 2011, 03:33 AM   #1
chef
Motorcycle(s): 1965 Honda S90 , 2010 Ninja 250,2012 Vespa LX 150(Yes,a vespa!)
Backfire after exhaust install?
Hi guys,
Am wondering what causes exhaust backfire on start up?
Last month i got a great deal on a used yoshi system.
Had it installed,jet kit installed & was no problem until this week,when it has suddenly developed a huge backfire several times when starting.
Conditions remain the same,no choke ( warm weather here in Bali )
Will be installing the Sportisi hugger next week,great service from them & cant wait !
Cheers,
Matt
chef is offline   Reply With Quote
Old April 2nd, 2011, 03:39 AM   #2
chef
Shoulda checked before posting!
Seems its a common problem & nothing too serious to worry about but yeah,it did scare the chocolate outta me too!
Old April 2nd, 2011, 03:50 AM   #3
wayanlam
wayanlam's Avatar
Motorcycle(s): 2014 Z250
plug up the kleen air hose, there are several threads on doing that already
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer
Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield
wayanlam is offline   Reply With Quote
Old April 2nd, 2011, 05:29 AM   #4
warlord
warlord's Avatar
Motorcycle(s): 2014 Ducati Panigale 899
^^^ +1 on Kleen Air delete
warlord is offline   Reply With Quote
Old April 2nd, 2011, 09:48 AM   #5
wvninja
wvninja's Avatar
Motorcycle(s): 2009 Honda CBR600RR
remove kleen air system, and snorkle
maybe do a carb shim or new jets. removes a lot of that pop on decel and startup.
"Riding a motorcycle is like playing sports, not everyone is cut out for it." - WVNinja
wvninja is offline   Reply With Quote
Old April 2nd, 2011, 09:53 AM   #6
start up backfire will occur with a stock or an aftermarket exhaust. removing the Kleen system doesn't help this at all.
http://www.ninjette.org/forums/showthread.php?t=15025&
learn to live with it and chalk it up to one of the mysteries of the 250R. have you heard the bike whining, yet?
Old April 2nd, 2011, 09:55 AM   #7
gfloyd2002
User Title Free Since '12
gfloyd2002's Avatar
MOTM - Feb '12
Backfiring often means that you are too lean, though there is some degree of backfire that is just going to happen regarless because that is just the way the bikes are. (Technically not a backfire, but burning mixture remaining in the cylinder until the beginning of the next intake stroke when it can ignite the incomming air/fuel mixture.) This is common when you put a new exhaust on if you haven't adjusted your fuel system properly. What happens is that the exhaust lets air flow more freely through the engine and your air/fuel ratio gets out of whack. Too much air, too little fuel in the mix. So you may need to increase the fuel flow by opening up your carb mix screws or getting bigger jets in.
Also, removing the kleen system or snorkel won't help. That is going to add even more air into the mix and lean you out further. You are going to need to either restrict airflow (a bad idea) or increase fuel flow (the way to go) if this is more than the typical occassional ninjete backfiring.
How to remove stock exhaust and install aftermarket Slip-On Exhaust System Ninja 300 SON1C 2013 - 2017 Ninja 300 Tech Talk 4 August 14th, 2014 05:45 PM
DIY- AreaP quiet core SS Exhaust Install kkim 2008 - 2012 Ninja 250R Tech Talk 55 December 12th, 2011 11:12 AM
Not another PLM exhaust install icbm 2008 - 2012 Ninja 250R Tech Talk 16 December 7th, 2011 07:18 AM
exhaust backfire question Mizono 2008 - 2012 Ninja 250R Tech Talk 6 May 30th, 2011 09:00 AM
Backfire athimmel General Motorcycling Discussion 25 March 5th, 2009 06:42 AM
