Old May 10th, 2013, 08:57 AM   #1
RandomPhantom
The Motorcycle Newb!
RandomPhantom's Avatar
Motorcycle(s): 2010 Ninja 250R (Red/SOLD), 2008 Ninja 250R (Black/SOLD), 2005 ZX6R (Black)
When to clean carbs and Adjust Valves
I have a 2010 Ninja 250r Its at 10k miles already and previous owner told me that he hasnt gotten valves adjusted yet or even carbs cleaned because the carbs didnt show any signs of needed cleaning. So my question is, how do i know when i need a valve adjustment and to clean the carbs? When is the mileage that i should b cleaning them at? Thanks!
RandomPhantom is offline   Reply With Quote
Old May 10th, 2013, 09:02 AM   #2
cuong-nutz
cuong-nutz's Avatar
Valve adjustments at every 7500 miles. As long as the bike has been running, you shouldn't be needing to clean the carbs. If the carbs sit long for a month or so WITH fuel in it then maybe. Anything longer than yes. Really, if the bike runs fine, doesn't have issues with hard starts, sputtering, than the carbs are most likely fine.
HalfFast Racing Team
Old May 10th, 2013, 09:04 AM   #3
RandomPhantom
Dang im way overdue for a valve adjustment mate! Well thanks for that i'll get right to it then and get that done. Also do u know when to replace spark plugs as well? i havent pulled mine out yet or even looked at them
Old May 10th, 2013, 09:12 AM   #4
cuong-nutz
cuong-nutz's Avatar
At the top page, you'll see the stickies. Download the maintenance schedule for your reference
http://www.ninjette.org/forums/showthread.php?t=10577
I usually inspect my plugs at every valve adjustment. If they're still good I pop them back in. The spark plugs will tell you a lot about how your engine is running.
Old May 10th, 2013, 09:57 AM   #5
RandomPhantom
quite a hefty list there mate! Looks like im going to b busy this weekend haha and thank you for this! But what does the (x) represent in the boxes with it marked? I dont need to check during those mileages?
Old May 10th, 2013, 01:10 PM   #6
sLick415
The X's are merely tick marks, meaning you do check those at those mileages.
sLick415 is offline   Reply With Quote
Old May 10th, 2013, 01:12 PM   #7
my routine:
oil change every 3.5k miles.
valves, oil filter, cooling system every 7k.
usually the chain and sprockets last around 10k.
inspect all bearings and mating surfaces every 15k.
Old May 10th, 2013, 01:26 PM   #8
Neglected valves can get burnt (expensive repair) because the clearance gets reduced with wear: please make that priority #1.
Include service of cam chain tensioner.
Plugs are cheap, just replace them.
Be very gentle about torquing them down, the holes in the heads strip easily (expensive repair).
http://faq.ninja250.org/wiki/Changin...rands_to_avoid
Old May 10th, 2013, 02:23 PM   #9
just some extra info on this. over torquing the plugs might not strip threads immediately. but an overtorqued plug will stuck itself in the plug hole to the point its welded in. after that, trying to remove the plug will simply shatter the porcelain and you're stuck with the bottom half of a plug in your head. which means you get to remove the head from the engine (not just valve cover- the entire head), drill the remainder of the plug out, tap to a bigger size, put in a helicoil and a new plug.
Old May 10th, 2013, 03:18 PM   #10
New plugs have a crushable gasket (metal ring) that gives some, avoiding excessive torque.
The gasket of the old ones has been crushed all the way down and the transition between not enough and too much is a more drastic step, being another reason to replace the whole plug by new.
Not to be scared, just careful
Old May 10th, 2013, 03:58 PM   #11
RandomPhantom
thanks alot for the help and advice guys! i'll definitely take out the bike to a shop to get the valves adjusted and possibly get it shimmed if its needed as well
I think I need to clean my carbs.. Hero Danny 1986 - 2007 Ninja 250R Tech Talk 44 June 9th, 2014 02:06 PM
Should I adjust my valves or are they good enough? Floki 2008 - 2012 Ninja 250R Tech Talk 17 January 7th, 2014 05:55 AM
Watch first hand in person how to adjust your valves rojoracing53 General Motorcycling Discussion 17 July 6th, 2013 08:26 PM
clean carbs? MLecl0001 2008 - 2012 Ninja 250R Tech Talk 8 December 2nd, 2012 02:12 PM
DIY- Clean and Adjust Chain islanderman7 2008 - 2012 Ninja 250R Tech Talk 25 April 2nd, 2010 10:42 PM
