Old October 31st, 2014, 08:47 AM   #1
kxpower?
kxpower?'s Avatar
Motorcycle(s): Ugly 89 frankenstien special ex250, and the "Zooks" : 1982 GS450 and 1979 GS1000
Spark plug adapter for leakdown tester??
Hey guys and gals,
I have this harbor freight leak down tester: http://www.harborfreight.com/cylinde...ter-94190.html
I went to play with it on the ninja (pregen), and discovered that the kit doesn't have a plug adapter small enough to thread into the plug hole. It only goes down to 12mm. Is 10 mm the right size for the ninja? Will any of the 10mm plug adapters thread right into this tester or do I need one specific to the HFT model?
I'm probably overthinking all this but chewing up my head is a headache I need to avoid!
THANKS!!
TLDR; what do I need to use the HFT tester in the link above on the Ninja?
Oh god the bikes are multiplying!!!
kxpower? is offline   Reply With Quote
Old October 31st, 2014, 09:07 AM   #2
Ghostt
Ghostt's Avatar
Good question, and I have no idea, best bet is to take a plug with you, and match it up.
wish I had more for you.
I gotta ask, why are you doing a leakdown test?
violente et ignorantia
ZX-2R BLOG
Old October 31st, 2014, 09:11 AM   #3
what i would suggest is not ever using any gauges from harbor freight. i have tried like... 4. none of them have ever worked. get a craftsman gauge.
Old October 31st, 2014, 09:15 AM   #4
Ghostt
Ghostt's Avatar
Well yeah, that too, also stay away from their torque wrench, or any other metering devices
ZX-2R BLOG
Old October 31st, 2014, 10:14 AM   #5
Originally Posted by kxpower? View Post
..........Will any of the 10mm plug adapters thread right into this tester or do I need one specific to the HFT model?..........
The spark plug's thread is 10 mm exterior diameter x 1.0 mm pitch = M10x1.0.
Rub some motor oil over the threads of the HF adapters and place it sideways over a piece of paper.
If you count 10 valleys within 1 cm (10 mm), you have a 1.0 mm pitch.
If you count 8 valleys within 1 cm (10 mm), you have a 1.25 mm pitch.
Both are fine threads.
If you count around 6 valleys within 1 cm (10 mm), you have a 1.5 mm pitch, which is called coarse thread.
http://en.wikipedia.org/wiki/ISO_metric_screw_thread
http://faq.ninja250.org/wiki/Helicoi...park_plug_hole
Old October 31st, 2014, 10:31 AM   #6
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
One thing I found and you should avoid. The adapter is screwed on to the hose. The adapter has a hex on the outside. When you screw the adapter into the head it will tighten up to provide a seal. When you try to unscrew the hose the adapter could stay in the head. And if the spark plug hole is not perfectly centered one of the flat sides of the hex will lock it in place. The only way to remove the adapter is to pull the head or do some tricky work down the plug tube. Ask me how I know this could happen?
Worlds fastest 250 ninja
Old October 31st, 2014, 11:42 AM   #7
kxpower?
kxpower?'s Avatar
Hernan you are the man. That is all.
Old October 31st, 2014, 11:49 AM   #8
kxpower?
kxpower?'s Avatar
Hmm, seems like they'd make the adapter where the regular 5/8" plug wrench would fit the hex. So you're saying the hex may be a bigger size? Save a lot of headache if it were just 5/8".
Old October 31st, 2014, 01:59 PM   #9
Racer x
Racer x's Avatar
No the size of the tube is small. So a socket will fit around the hex on the adapter may be to thick to fit down the tube. And if the spark plug hole is not centered then the hex actually touches the side of the spark plug tube. I ended up grinding off the hex then used red Lock tight on the adapter to the hose.
Old November 1st, 2014, 09:59 AM   #10
kxpower?
kxpower?'s Avatar
Hmm I'll be careful of that thanks Eric. I'll probably loc tite it to the hose as well.
Old November 1st, 2014, 01:31 PM   #11
Racer x
Racer x's Avatar
That's what I did. And lube the threads
Spark Plug Poll smokinsingle Ninjettes At Speed 15 November 29th, 2015 08:12 PM
spark plug removal eddiekay 2008 - 2012 Ninja 250R Tech Talk 3 October 21st, 2011 10:56 AM
Spark Plug Colour OK ? GiGs 2008 - 2012 Ninja 250R Tech Talk 9 October 8th, 2010 02:11 AM
What is the best Spark Plug to buy? dive1tom 2008 - 2012 Ninja 250R Tech Talk 7 November 5th, 2009 09:44 AM
Spark plug reading Racer x 2008 - 2012 Ninja 250R Tech Talk 14 October 7th, 2009 07:53 PM
