July 10th, 2009, 10:24 PM | #1 |
Level in sight glass is rising!
I have suspected, since my last oil change, that I MAY have coolant sloooowly mixing with my oil. The sight glass seemed a little higher than normal before popping the drain plug (I always do my own changes), and the oil looked suspiciously runny. It wasn't real obvious, and I don't think it was real cloudy, but it very subtly looked "off."
I know there can be a tendency to see things when you are looking for something that is wrong, but ever since then I have been very meticulous about how I take my oil level readings. It is always in the same spot of my garage, and I use a second person and rear stand to put pressure on the spools (but not lift) so that it would be perfectly level every time I check the glass. Well, I have my bike stripped down right now for an unrelated DIY I am working on, and I noticed the level in the sight glass is higher than it was earlier this week. It is not over, but ALMOST to the max mark on the glass (I believe it was ~2/3 of the way when I filled it). Also, the coolant reservoir is still withing the "safe" zone, but the level is hovering just above the min. mark (I believe it used to be at about the middle). I just installed the Daytona Temp. gauge about a week ago, and am surprised at how high the temps get, but since I didn't have a reference point, don't know if this is normal for this bike (I run in the neighborhood of 175-185 on the highway when the weather is in the 80s, and can get up to 220 at stop lights, generally when it is in the upper 80s to low 90s). If I was mixing fluids, I suspect the cooling properties would not be as sufficient. Any ideas on what I am likely looking at? Is this a 'go to the dealer, do not collect $200' situation, or should I just keep an eye on it? I am now under the extended warranty, so should I expect it all to be covered? |
July 10th, 2009, 10:31 PM | #2 |
ninjette.org Monkey Spank
Join Date: Apr 2009 Motorcycle(s): 2008 250R Track-Bike Woodcraft clip-ons and rearsets FZ-6 track bike Posts: A lot.
I just installed my temp gauge today and get about the same readings as you.
Hope that helps. If you were mixing oil and coolant you would see it. There would be no doubt. Pull the oil filler cap and look at the underside. If theres a creamy color film on the bottom of it your getting coolant in the oil.
Black 250R Full Area P QC Dyno Jet Kit 100 main 41T Rear Sprocket |
July 10th, 2009, 10:43 PM | #3 | |
I just checked the cap, and I don't see any obvious creamy film. The oil still has a newish appearance (~500 miles). It also has a gasoline-like smell in there.... but I am assuming that is normal. I just don't know why it seems to be creeping up..... this is going to drive me crazy! |
July 10th, 2009, 10:53 PM | #4 |
don't worry about it... you are crazy. (I won't ask your profession)
if you were leaking coolant into the oil, it would be very noticeable in the sight glass by a creamy, chocolate coffee colored oil. If you had oil in the coolant, there would be a ring of brown stuff in your bottle. you worry too much... ride the bike and don't obsess. |
July 10th, 2009, 10:54 PM | #5 |
Elves are pouring in a couple extra ounces of oil each night. If it gets too high, take out a few ounces every few days and sell 'em on ebay.
Happy to help.
July 10th, 2009, 11:06 PM | #6 |
Well.... in that case I prefer to be a little crazy than have a broken bike.
But I will probably need an RX because I will obsess over the mystery oil. I mean, the laws of physics are actually being broken inside my motorcycle - amazing! |
July 10th, 2009, 11:42 PM | #7 |
Thought I would post a pic before heading off to bed.
It is difficult to see in the pic, but I think I see a slight greenish tint, and maybe a little cloudyness.. but hard to say. Maybe tomorrow I will take some oil and coolant, and mix it for reference. Oh, and the level looks normal in this picture because it is on the rear stand. |
July 11th, 2009, 01:32 AM | #8 |
July 11th, 2009, 05:37 AM | #9 |
Bob,
Based on the last picture (on the stand), I would venture to say your level is OK. I just checked mine on the stand and it shows full. When my bike is on the ground and vertical, it is normally just below the top mark. As long as it took you to spend your Father's Day $50, I hope you don't worry about the oil level more than a couple of weeks. |
July 11th, 2009, 07:05 AM | #10 | |
I did spend the Father's Day Money over a week ago.... but I do still get the occasional suggestion (people don't read the whole thread I think). |
July 11th, 2009, 07:35 AM | #11 |
Gearhead
Join Date: Jun 2009 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 242
If you were mixing oil/coolant, the oil would appear "milky". Also, if it had been sitting long enough for all of the oil to drain to the bottom, the oil level would appear to be a little higher than if you just filled it or ran it.
If you drain the oil when it's cold, and there was coolant in it, the coolant would be the first thing out of the drain hole. Coolant is heavier than oil and will settle to the bottom.
July 11th, 2009, 08:17 AM | #12 |
That oil is fine. If there was even the slightest bit of coolant in there you would KNOW.
CHILL DUDE its all good.
July 11th, 2009, 08:52 AM | #13 |
self wrencher
your head is shrinking..i can see it..
August 3rd, 2009, 12:48 PM | #14 |
Join Date: May 2009 Motorcycle(s): 2009 Ninja 250R (sold) Posts: 356
The reason is looks like the oil is changing is just the dyes in the oil breaking down. That green color of RotellaT is just dye. It gradually loses its color and gets that foggy look.
August 3rd, 2009, 01:40 PM | #15 |
Track Junkie
Join Date: Dec 2008 Motorcycle(s): '08 Ninja 250r Track Bike, DR350 commuter, KDX220 woods bike Posts: 602
maybe this was posted already (didn't read it all), but the longer your bike sits after running, the higher it'll read in the sight window. so... checking oil level 3 or 4 minutes after turning off the bike will read a lot different than checking the oil level 20 minutes after turning it off.
Las Escobas -- Track Bikes Save Lives JonBroom.com |
August 3rd, 2009, 01:43 PM | #16 | |
Although I had come to the conclusion that I probably was crazy, since the level is not rising, and everyone says I am |
August 3rd, 2009, 01:58 PM | #17 |
You are right. Your oil is slightly green tinted. That's how it's supposed to look I've noticed NORMAL oil when you tend to overanalyze everything and what you're looking through is less than say an inch thick of oil, it will appear a light brown, gray around the edges, and somewhere between almost green tinged. It's perfectly fine. Oil and water/coolant don't mix. They might get mixed into each other, but they'll always separate again. If you had coolant in your oil, you'd know.
Here's something to consider: Has your assistant been slowly gaining weight? If they're weighing it down, wouldn't that cause the sight to read a little more full? I find it slightly surprising you think you're gaining fluid in your oil rather than burning some :P |
August 3rd, 2009, 02:07 PM | #18 | |
So to answer your question, it really never occurred to me. I thought in a closed system the coolant would have no where to go, unless it leaked out. |
Overfilled Oil Sight Glass | RandomPhantom | 2008 - 2012 Ninja 250R Tech Talk | 6 | May 25th, 2013 06:11 AM |
Oil level sight glass | adouglas | General Motorcycling Discussion | 53 | May 16th, 2013 02:30 PM |
Oil sight glass | BlueHairSar | 1986 - 2007 Ninja 250R Tech Talk | 20 | December 13th, 2012 01:23 PM |
Oil level sight glass | divingtigger | 2008 - 2012 Ninja 250R Tech Talk | 6 | June 28th, 2009 04:29 PM |
Oil Sight Glass | empyrean | 1986 - 2007 Ninja 250R Tech Talk | 7 | June 25th, 2009 10:25 AM |
