Old August 30th, 2014, 12:31 PM   #1
james250ninja
james250ninjette.newbie
james250ninja's Avatar
Motorcycle(s): 1986 ninja 250
Smile headlight issues
hi there my low beam wasn't working and my head lamp light came on I changed the bulb, looked at all the fuses and still my head lamp light is still on ..any ideas the bulb was the right fit
james250ninja is offline   Reply With Quote
Old August 30th, 2014, 02:20 PM   #2
cuong-nutz
cuong-nutz's Avatar
Check your plug and wires. make sure that your wire didn't break at the headlight plug. Your post was kind of difficult to read and understand.
Are you saying that your low beam is still on even when you turn off the bike with the key?
If your high beam work but not your low beam, then I would check your light bulb connections. The headlight is under only one fuse so if that's bad, neither one of your headlights should work.
HalfFast Racing Team
Old August 30th, 2014, 03:16 PM   #3
james250ninja
Smile
wires and plug are good
I put a new bulb in now the high and low beam work great, but my head lamp indicator is still on
Old August 31st, 2014, 06:10 AM   #4
You mean the high beam indicator?
headlight issues james250ninja 1986 - 2007 Ninja 250R Tech Talk 2 September 7th, 2014 07:03 AM
08 Ninja 250 : Other Issues due to Headlight Circuit Relay abhijitz 2008 - 2012 Ninja 250R Tech Talk 1 February 26th, 2013 05:41 PM
Mounting stock headlight and gauges using headlight clamps? SV_Hadder 1986 - 2007 Ninja 250R Farkles 0 January 17th, 2011 09:15 PM
