Old June 29th, 2017, 09:09 AM   #1
dreygata
Motorcycle(s): 06 Honda 599, 2013 Can Am Spyder ST-S, 84 Honda Sabre 1100
Fork Compatibility for 2015 Ninja 300?
I'm needing to replace the front forks on a 2015 Ninja 300. Are the forks from previous years compatible with the 2015 model?
Also, does anyone have some they'd sell?
Thanks!
dreygata is offline   Reply With Quote
Old July 3rd, 2017, 03:40 PM   #2
bruce71198
bruce71198's Avatar
Thanks!
The 08 to 12 250 forks will fit but you wont be able to mount the speed sensor for the speedo. you can put the lower fork leg off your 300 on a 250 upper tube as long as your lower is still good
Old July 22nd, 2017, 06:35 PM   #3
sparkcycle
sparkcycle's Avatar
Motorcycle(s): Ninja 300 ABS
The speed sensor for the Ninja 300 is read from the CS sprocket in the rear.
Engineer rocketing through time and space on a Ninja 300 ABS
sparkcycle is offline   Reply With Quote
Old July 24th, 2017, 06:37 AM   #4
bruce71198
bruce71198's Avatar
Sorry, your correct, it's the sensor for the ABS if so equipped.
