Old August 30th, 2017, 06:31 AM   #1
Texas
Motorcycle(s): 2014 Ninja 300, 2001 CBR 929rr, 03 KTM 450EXC
Ninja 300 - GSXR shock swap - Dogbones?
Hi, all. First post here. Just acquired a 2014 Ninja 300 and am in the process of prepping it for the track. I read about the GSXR rear shock swap and have decided to begin the procedure. I found the shock on Ebay for $35. But it looks like the dogbones aren't available from those listed in the old DIY threads anymore. Do any of you know where I can get 1.25" to 1.5" dogbones for the Ninja 300? All help is appreciated. Thanks!
Texas is offline   Reply With Quote
Old August 30th, 2017, 10:05 AM   #2
sparkcycle
sparkcycle's Avatar
Motorcycle(s): Ninja 300 ABS
This info might be helpful to you:
Step by step GSX-R Shock Install
You could make your own dogbone links if you are handy and know the length you need.
Engineer rocketing through time and space on a Ninja 300 ABS
sparkcycle is offline   Reply With Quote
Old August 30th, 2017, 10:17 AM   #3
The links don't work, sparkcycle.
Old August 30th, 2017, 10:20 AM   #4
sparkcycle
sparkcycle's Avatar
I guess they've been disabled because they point to another forum. A VERY large Ninja300 specific forum.
If you google "Step by step GSX-R Shock Install" it is the very first link. You can reconstruct the links after that.
Old August 30th, 2017, 10:46 AM   #5
You can also google filename at end of URL as well.
129737-easy-rear-lowering-kit-diy.html
Old August 30th, 2017, 02:17 PM   #6
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Motorcycle(s): '09 250 SE 'Booger'
I saw some aluminum links on ebay yesterday.
Dave Wolfe is offline   Reply With Quote
Old August 30th, 2017, 03:21 PM   #7
Texas
Thanks for the links and info, Sparkcycle. That forum post was extremely detailed.
I have found plenty of lowering links. But the problem is I'm trying to raise the bike up. I found 1" links from a company in GB but they are $50-75. I'd like 1.25" minimum as I'm very tall. I wouldn't mind paying for some if they were $20-25. From what I've found, the DIY dogbones look pretty easy and, for the money, I'll probably end up doing that.
Old August 30th, 2017, 05:53 PM   #8
Lazarus
Lazarus's Avatar
Motorcycle(s): 2008 Ninja 250
Not sure If it will work on the 300 (not sure why it wouldn't either) but I used dog bones from a ninja 500. Worked like a charm, height was perfect and the price was good too.
If you go that route you will need to shim the ninja 500 dog bones with some washers/nuts on each side so they will clear the base of the gsxr 600 shock.
Lazarus is offline   Reply With Quote
Old November 30th, 2017, 08:11 AM   #9
WhiteRussian
Motorcycle(s): ninja 300 Winter test
FYI, bikefarmmv has laser cut raising links called a "jack up kit" on their site. Couple different heights to choose from too.
Got the 1" up for my winter test and they are perfect -looks like plain 1/4" stainless or something. Pretty cheap too.
WhiteRussian is offline   Reply With Quote
Old November 30th, 2017, 11:47 AM   #10
Get the GSXR-1000 shock. It's tiny bit longer than stock and will raise rear of bike about 0.5". Then you can raise it even more with preload adjustment. No need to change dog bones.
GSXR-600 Rear Shock Swap Questions Goatsby 1986 - 2007 Ninja 250R Tech Talk 6 April 6th, 2016 01:19 PM
FS : 08+ Ninja 250 GSXR shock setup abhijitz Motorcycle-related 30 December 18th, 2015 08:45 PM
Race-prepped 250 GSXR shock swap question Braden07 2008 - 2012 Ninja 250R Tech Talk 7 November 15th, 2014 07:03 AM
GSXR shock swap questions subxero 2008 - 2012 Ninja 250R Tech Talk 75 March 13th, 2014 12:09 PM
GSXR shock upgrade, complete kit for 250r/300 Dark Motorcycle-related 16 August 21st, 2013 03:15 AM
