July 18th, 2016, 08:39 AM | #7521 | |
Will definitely consider threadlocker when we put that back together, thanks for the suggestion. |
July 18th, 2016, 08:43 AM | #7522 | |
July 18th, 2016, 09:00 AM | #7523 |
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
Join Date: Nov 2013 Motorcycle(s): 2009 Ninja 250R and 2014 Triumph 675R Posts: A lot.
At NYST this weekend we had a guy strip out the bottom threads on the bolt that holds his tank and seat to the frame on his Aprilia. All one piece held in by that single bolt. The fix was thread locker, since the top threads held just the bottom ones didn't. No issues after that, he ran in Expert all weekend.
Spoiler for topic:
July 18th, 2016, 10:03 AM | #7524 | |
Certified Troublemaker
Join Date: Oct 2012 Motorcycle(s): 2006 Ninja 250r "Pikachu", 2017 Ninja 650 "Epona" Posts: A lot.
Red is just evil.
Raven's Rejuvenation A bruise is a lesson... and each lesson makes us better... |
July 18th, 2016, 10:22 AM | #7525 |
Certified looney toon
MOTM Jul '13, Jul '14
Of course, that is why you need high heat to deal with it.
July 18th, 2016, 10:36 AM | #7526 |
I like the official "wicked" rating for the green Everything you wanted to know about threadlocker, but were afraid to ask http://na.henkel-adhesives.com/indus...tite-13445.htm http://catalogs.na.henkel-adhesives....gt=11&lang=enu
July 18th, 2016, 10:43 AM | #7527 |
Blue or purple threadlock- got it. We probably have some in the garage.
Nuts ordered. Hopefully will be in soon. |
July 18th, 2016, 10:46 AM | #7528 | |
I've seen others drowned the bolts with the stuff, no need for that. As far as your closing sentence, I'm not even gonna touch that
July 18th, 2016, 04:25 PM | #7529 |
Not today, yesterday. And not me, my dad. But a handy application of JB Weld got my mirror reattached after the less than graceful plop on the training course Saturday.
My poor bike, finally crossed the line of things being held on by zip ties, electrical/duct tape, and now home repaired metal parts.
July 18th, 2016, 10:59 PM | #7530 |
Well, you know, whatever works. I'm not above using zip ties or paracord or whatever is handy. If it truly disturbs me, I can replace it later with the proper thing.
July 19th, 2016, 05:58 AM | #7531 |
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
Once I get home I'm going to be taking the calipers off to check the brake pads, Summitracing seems to have a good deal on EBCs
Spoiler for topic:
July 24th, 2016, 07:26 PM | #7532 |
Join Date: Jul 2015 Motorcycle(s): 2001 Ninja 250, 2019 Harley Ultra Classic, 2001 Suzuki SV650 Posts: A lot.
MOTM - Jan '16
I got to use my emergency cable kit!
Went for about a 100 mile ride through the Northern VA farming and horse country. About 15 miles from home I pulled the clutch in and the lever stayed that way. Managed to pull over into a local park. Well this isn't going to make getting home easy. Oh wait, don't I have that cable kit thing I bought off Amazon? Yep here it is, in the bottom of the tank bag. Had a little extra cable and nothing to cut it off with (Note to self, Leatherman goes in tank bag) Got me home. A well spent $10. Just ordered a replacement kit, and one each for my son and daughter. |
4 out of 4 members found this post helpful. |
July 25th, 2016, 12:37 PM | #7533 |
Routine maintenance time, with some extra pieces. New oil filter bolt, the old one was slightly rounded by the P.O., NewGen oil pump screen cover, new oil drain plugs, O-rings, crush washers, gaskets, fresh Mobile 1 15-50w.
More information on the NewGen oil pump screen cover, for those whom are interested. http://faq.ninja250.org/wiki/Changin...ver/drain_plug
July 25th, 2016, 02:09 PM | #7534 |
July 27th, 2016, 03:29 PM | #7535 | |
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
Spoiler for topic:
July 27th, 2016, 05:45 PM | #7536 |
Did you service the calipers?
July 27th, 2016, 06:09 PM | #7537 |
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
They were in good shape. Had to clean up the front one, had a cacoon casing in it. Sprayed it with brake cleaner and wiped it out.
Spoiler for topic:
July 27th, 2016, 08:53 PM | #7538 | |
So did you disassemble them? Inspect the pistons? Seals? Grease the slider pins? Flush the old fluid?
July 28th, 2016, 04:55 AM | #7539 |
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
Skeptical dog can remain skeptical, its like telling an OCD person you cleaned your house. Only service the inner working if they are appearing weathered or your doing a full maintenance on the bike. I am waiting to do a flush on the brake fluid until after the brake pads are broke in. Pistons were able to be pushed in by hand and visually are as shiny as a new printed/polished penny. I pressed and pulled on the slider and it slide without any portions feeling as if they had any rough spots. They are sound in my view.
Spoiler for topic:
July 28th, 2016, 07:06 AM | #7540 | |
I know where you're coming from and I know you're right. Generally accepted best practice is to do a nice clean/inspect/lubricate job on a caliper when you change pads instead of just doing a pad slap. HOWEVER... it's not your bike and it's not worth getting holier-than-thou about it. DEFY has been around here a while, not some newbie who's had to introduce his hand to a wrench for the first time. Asking once was enough; no need to be elitist. #callingyouout because we all get a bit ahead of ourselves at times. Myself included. |
July 28th, 2016, 07:23 AM | #7541 |
Us KY folk be serious bout dem brakes ya hear. I betcha Scott oils dose wobbly wheels on dem der buggies at the wal-marts too.
July 28th, 2016, 07:49 AM | #7542 |
Fair enough, and I ment no disrespect to @DEFY, just looking out for a fellow forum member.
If I offended @DEFY, or anyone else, I apologize. Now back to your regular scheduled shenanigans.
July 28th, 2016, 07:56 AM | #7543 | |
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
Spoiler for topic:
July 28th, 2016, 12:35 PM | #7544 |
All good here Just making sure we stay friendly.
I've had my share of... ahem... unnecessarily abrasive interactions with some members in the past too. |
July 28th, 2016, 12:42 PM | #7545 |
MOTM - Sep '14
I don't believe that is even possible of you.
Keep calm and ride on -Motofool Never quit on a rainy day -ally99 |
August 12th, 2016, 03:24 PM | #7546 |
Join Date: Nov 2012 Motorcycle(s): 2012 Ninja 250R, 2007 Ninja 650R, 2001 F650 Dakar Posts: A lot.
August 12th, 2016, 03:50 PM | #7547 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
Look good newb
August 12th, 2016, 03:55 PM | #7548 |
Thank, JohnnyBravo. I did snag a couple selfies of me with the bike, but we all know how I'm not big on showing my ugly mug, lol. Next come the new jets, bar ends, lever guards, and bodywork. Maybe not in that order.
August 12th, 2016, 04:08 PM | #7549 |
Sweet
I get to charge the battery tomorrow, unless I'm indisposed
August 13th, 2016, 10:48 PM | #7550 |
Track Clown
MOTM - Sep '15
new tach!
August 13th, 2016, 11:18 PM | #7551 |
Nice! Which one did you get?
August 14th, 2016, 02:42 AM | #7552 |
MOTM - Sep '14
New chain. After I changed it I was having a difficult time getting into 1st gear. After doing a search of your friendly neighborhood ninjette, I adjusted the shifter.
Keep calm and ride on -Motofool Never quit on a rainy day -ally99 Last futzed with by allanoue; August 14th, 2016 at 06:26 AM. |
August 14th, 2016, 06:49 AM | #7553 |
Battery charged, sure could use a bath
August 14th, 2016, 07:03 AM | #7554 |
Join Date: Dec 2013 Motorcycle(s): Ducati 999 2012 Ninja 250r Ducati748 Yellow finally running 2003 SV650 S (SOLD) Posts: A lot.
August 14th, 2016, 07:06 AM | #7555 |
August 14th, 2016, 07:09 AM | #7556 |
Hhhhmmm smells like teen spirit.
August 14th, 2016, 07:21 AM | #7557 |
smells like somethin I ain't sure it's teen spirit though
August 14th, 2016, 07:33 AM | #7558 |
Maybe a dead spirit lol.
August 14th, 2016, 07:51 AM | #7559 |
I can't remember if I need to changed the oil or not. I haven't been paying attention to mileage. With it raining, maybe I'll check the valve lash since it's cooler than the 100+ degree weather.
August 14th, 2016, 07:59 AM | #7560 |
If you can't remember when the last time was that you changed the oil then you need to go ahead and change oil and start keeping track.
Discovered something scary about my Ninjette today... | kjohng | General Motorcycling Discussion | 28 | October 15th, 2021 01:40 PM |
Sold the 2006 Ninjette today :( | Renner | General Motorcycling Discussion | 31 | October 16th, 2014 11:46 PM |
Today I Gave My Ninjette Wings! | BlueHairSar | Pictures | 5 | June 20th, 2013 07:38 AM |
my bro went down today on his ninjette | richierich781 | !%@*#$%!)@#&!%@ I crashed! | 46 | January 18th, 2013 11:59 AM |
Ninjette. org hacked today | CC Cowboy | Off-Topic | 9 | April 3rd, 2011 08:55 AM |
