Old March 15th, 2011, 07:07 PM   #41
Peanut_EOD
Peanut_EOD's Avatar
Motorcycle(s): Green 2013 ZX-6R
Originally Posted by Rexbo View Post
I like that guy out on pole
Yeah man super fun weekend, I def wish I had peanut's lean angles too, now to smooth out your lines!
Thanks guys, I'm still learning the bike. It's way different from my ZX-6R. Does anyone make a slipper clutch for the 250?
http://www.simplysurrealphotography....es/peanut2.png
Peanut_EOD is offline   Reply With Quote
Old March 15th, 2011, 07:07 PM   #42
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
This is a friend's garage;
A couple nice rides, including some Kawasaki's.
Old March 15th, 2011, 07:23 PM   #43
ztrack157
The Sportisi Master
ztrack157's Avatar
Motorcycle(s): 2008 Ninja 250
LMAO. no
Built I do build quick shifters for it.
Sportisimoto USA is born.
ztrack157 is offline   Reply With Quote
Old March 15th, 2011, 07:24 PM   #44
Peanut_EOD
Peanut_EOD's Avatar
******, but why is that funny?
Old March 15th, 2011, 07:33 PM   #45
ztrack157
The Sportisi Master
ztrack157's Avatar
its a 250 :P
Old March 15th, 2011, 08:03 PM   #46
Peanut_EOD
Peanut_EOD's Avatar
Originally Posted by ztrack157 View Post
its a 250 :P
Yeah, and a slipper clutch is way more useful than a quick shifter is! The bike isn't fast enough for my shift speed to be a factor, but I do get wheel hop downshifting at speed. So, again what is so funny? Other than a quick shifter on a 250?
Old March 15th, 2011, 08:32 PM   #47
ztrack157
The Sportisi Master
ztrack157's Avatar
I'm just giving you crap. Your use to a 600 and you probably just need a little more time on the 250 to get use to it. The quick shifters have shown to gain apx a foot a shift its not much I know. But for fast guys it matters slow pokes it doesn't.
No one will make a slipper yet because its not to the point where it would be profitable for them to produce it. If the AMA series we are working on happens then you might is one pop up sometime in the future. They are racing these things on the Euro stage this season so maybe one may pop up in the UK.
Old March 15th, 2011, 08:57 PM   #48
Peanut_EOD
Peanut_EOD's Avatar
Ok. Some good points. I do need to get used to this thing. Will your quick shifter work with GP shift? I still think a slipper clutch would have helped me more this past weekend. I experienced wheel hop a few times trying to hold the lead. Andrew was just too fast.
Old March 15th, 2011, 09:02 PM   #49
08ninja250
08ninja250's Avatar
Motorcycle(s): 2008 ninja 250
Colin #191 - Area P, Elka Shock, Woodcraft Clip-Ons and Rearsets, Attack Race Bodywork, BT 003RS, .700 Fork Springs, DynoJet Stage 2 and BMC High Flow Air Filter.
613 MOTORSPORTS.COM
08ninja250 is offline   Reply With Quote
Old March 15th, 2011, 09:07 PM   #50
ztrack157
The Sportisi Master
ztrack157's Avatar
I can get sensors for either setup.
Old March 15th, 2011, 11:03 PM   #51
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
If this pic was focused I would have bought:
http://www.caliphotography.com/photo...ewImage=926893
Old March 16th, 2011, 09:16 AM   #52
CC Cowboy
CC Cowboy's Avatar
Try using more brake than engine to slow down.
Old March 16th, 2011, 10:34 AM   #53
tiggen
tiggen's Avatar
Motorcycle(s): 2003 250
^That and know that the rev limiter doesn't work on downshifts. I'm pretty sure I destroyed the top end of my first motor over-revving it on downshifts.
And I agree that a quickshifter on a Ninja 250 is pretty funny.
tiggen is offline   Reply With Quote
Old March 16th, 2011, 01:03 PM   #54
austexjg
austexjg's Avatar
Motorcycle(s): '09 zx6r Green/Black, (ex-)Diablo Black '09 Ninja 250r
When I first got the 250, I thought the same thing about a slipper clutch when I first tried to "blip" on a fast twisty road.
I just can't seem to link the blip and the downshift - it seems like the bike takes too long to respond to the blip in throttle.
After a few rear tire hops - I still want one.
austexjg is offline   Reply With Quote
Old March 16th, 2011, 02:32 PM   #55
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Are you guys downshifting two really quick and popping the clutch out hence experiencing a wheel hop...is this why you feel a slipper clutch is needed?
Old March 16th, 2011, 03:45 PM   #56
switch
switch's Avatar
Motorcycle(s): 900cc's worth
when downshifting, i feather the clutch then back on the gas hard (i used to just dump the clutch). don't really get wheel hop, don't know if i ever really did. i've felt it 'slide' if i'm being aggressive, but even then its just kinda 'meh whatever'. don't know if i'd like a slipper, overkill IMO =P
CMRA #250
Brought to you by: Lockhart Phillips USA-Sam's Cycles-South Central Race Center-HPC Decals-Highperformancecrew.com-and my amazing friends!
switch is offline   Reply With Quote
Old March 16th, 2011, 03:49 PM   #57
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
But are you downshifting one or two gears at once? Two gears I can understand...meaning you'll get some movement but nothing wild. One gear...don't feel a thing. Just modulate the clutch.
I usually just dump/pop it out which I don't recommend.
Old March 16th, 2011, 04:10 PM   #58
austexjg
austexjg's Avatar
I was talking about going down at least two gears - I try too hard to ride some of the local roads IOM TT style (only with AGATT and very minimal traffic). It seems like using one gear at a time would mean letting off the throttle earlier - in a track mentality - which means slower times.
And I guess it "sliding" for a bit is the more common outcome, but at least twice while going from 6th to 3rd, I felt a little hop - but I guess it could have been my heart skipping a beat.
Old March 17th, 2011, 06:15 AM   #59
Peanut_EOD
Peanut_EOD's Avatar
I got wheel hop when I dropped two gears trying to drive in deep going into "Patience" trying to pass Andrew. I also got it driving in hard into Turn 8 and dropping a couple of gears to get a good torquey drive out of Turn 10 while I was trying to hold Andrew off. It didn't work. I know I still need to learn this bike. I'm still riding like I'm on a 600. A few more track days and races will be good. I'm heading back to Colorado for a while. Maybe I'll hit High Plains Raceway.
Old March 17th, 2011, 07:09 AM   #60
Bueller999
Oldie but a goodie
Bueller999's Avatar
Motorcycle(s): 08 Ninja 650r, 06 SV 650 race, 08 250r race, 03 Buell XB9s, 01 KTM 300 EXC
Are you going to race with us in the MRA "250 spec class"?
Unfortunately slippers and Q shifters not allowed
There is also going to be a "spec" class for us @ IMI with the Rocky Mountain minimoto org.
ABRacing
Bueller999 is offline   Reply With Quote
Old March 17th, 2011, 07:57 AM   #61
JS73
JS73's Avatar
Motorcycle(s): 08 Ninja 250
Cool thread! Some great looking paint jobs in here. Mine is just rattle can
This is all I have for now. Hope to get some more at Roebling Road this weekend.
Crappy cell phone pic.
WERA #273 Novice
Boogeyman Racing.
JS73 is offline   Reply With Quote
Old March 18th, 2011, 07:12 AM   #62
Peanut_EOD
Peanut_EOD's Avatar
I'd love to if there are any races going on while I'm in town.
Old March 20th, 2011, 01:36 PM   #63
Rexbo
CVMA / AFM / M1GP #250
Rexbo's Avatar
Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650
haha yeah stop shifting so much! Most of those turns you could carry enough speed through to hold a higher gear. You've definitely got the lean angle down, but need to carry more cornering speed and use more runout area.
Rexbo is offline   Reply With Quote
Old March 20th, 2011, 02:32 PM   #64
Bueller999
Oldie but a goodie
Bueller999's Avatar
MRA 2011 Season Schedule**250 Ninja Cup (spec class) runs 1 race each day**
The 250's are also eligible in lightweight classes and Colorado Class
And your licence would probably reciprocate.
http://www.mra-racing.org/
May '11
Saturday & Sunday, May 7th, 8th Race #1 at High Plains Raceway
Saturday & Sunday, May 21st, 22nd Race #2 at Pikes Peak International Raceway
June '11
Saturday & Sunday, June 11th, 12th Race #3 at High Plains Raceway
July '11
Saturday & Sunday, July 9th, 10th Race #4 at Pueblo Motorsports Park
Saturday & Sunday, July 30th, 31st Race #5 at High Plains Raceway
August '11
Saturday & Sunday, Aug 27th, 28th Race #6 at High Plains Raceway
September '11
Saturday & Sunday, September 17th, 18th Race #7 at Pikes Peak Interational Raceway
October '11
Saturday & Sunday, October 8th, 9th Race #8 at High Plains Raceway
There is also a 17" class that the local mini moto has put together to try to attract the ninjettes to.
http://www.rmminimoto.com/
2011 Schedule
1.
2. June 5 - IMI Motorsports- Erie (17")
3.
4.
5. July 24 - IMI Motorsports- Erie (17")
6. Aug 7 - IMI Motorsports- Erie (17")
7.
8. Sept 11- IMI Motorsports- Erie (17")
The empty slots are at Bandimere, no ninja race as track is too small.
ABRacing
Old March 20th, 2011, 04:58 PM   #65
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
maxton 2009 121.854 mph
Old March 20th, 2011, 06:30 PM   #66
Peanut_EOD
Peanut_EOD's Avatar
Yeah, I need more track time on the 250 so I stop trying to ride it like my 600. I'm doing a track day at High Plains Raceway in Colorado next weekend.
Old March 21st, 2011, 02:40 PM   #67
V2Neal
Bad-ass 250 racer
V2Neal's Avatar
Motorcycle(s): Ninja 250r, ATK 605, Honda CR250R
a vanity and an action shot ...
CRA #28. Just wave as you go by!
V2Neal is offline   Reply With Quote
Old April 18th, 2011, 11:49 AM   #68
sowega
sowega's Avatar
Motorcycle(s): 899, 748, 250, 250, 70
Here's mine in "preseason testing," hahaha:
Since then, I've added the Area P, removed the tape art, and started rattlecanning the fairings.
sowega is offline   Reply With Quote
Old April 18th, 2011, 01:33 PM   #69
08ninja250
08ninja250's Avatar
Finally got everything ready for the 2011 racing season. Test day got cancelled cant wait for the first race!!!
Let me know what you all think!
613 MOTORSPORTS.COM
Old April 18th, 2011, 02:10 PM   #70
08ninja250
08ninja250's Avatar
Almost 200km/h!!! Wow congrats!
613 MOTORSPORTS.COM
Old April 18th, 2011, 07:36 PM   #71
Old April 21st, 2011, 07:12 AM   #72
JS73
JS73's Avatar
Action shot I got from a track photographer at Roebling Road. This is a cel phone pic of the actual picture, hence the poor quality.
WERA #273 Novice
Boogeyman Racing.
Old May 3rd, 2011, 06:59 PM   #73
toptier
Motorcycle(s): Ninja 250R
Here's a picture of my Ninjette ready for the MRA spec Ninja Cup.
toptier is offline   Reply With Quote
Old May 3rd, 2011, 07:00 PM   #74
sowega
sowega's Avatar
Ready for WERA Barber this weekend
Old May 3rd, 2011, 08:03 PM   #75
Rexbo
Rexbo's Avatar
Theme for this thread now:
http://www.youtube.com/watch?v=eHuebHTD-lY
Old May 4th, 2011, 04:41 PM   #76
Bueller999
Oldie but a goodie
Bueller999's Avatar
See ya out there, getting close now
ABRacing
Old May 10th, 2011, 07:38 PM   #77
Bueller999
Oldie but a goodie
Bueller999's Avatar
MRA Racing weekend #1
We had a great turnout for the inaugural weekend. 15 bikes on the grid.
The photogs page
The pics I got from him.
ABRacing
Old May 10th, 2011, 07:54 PM   #78
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Luv it mang...luv it!
Old May 10th, 2011, 11:04 PM   #79
dino74
dino74's Avatar
Toptier,
You might want to trim your rear brake reservoir hose, it looks like it might rub against your rear tire. It has happened to me and another guy on the same day.
Old May 11th, 2011, 12:44 AM   #80
leed
leed's Avatar
Motorcycle(s): Time will tell
Those are some good actions, for sure. You remind me of RoboCop with the flip-down visor And 143 looks like his arm is triple jointed...
Race bike mods #19 Ninjettes At Speed 14 August 9th, 2014 09:37 AM
Fan on a race bike Konaunit1 Ninjettes At Speed 18 January 30th, 2014 06:17 PM
My race bike sandman889 Pictures 11 May 15th, 2013 11:19 AM
Jetting on my race bike nick5446 2008 - 2012 Ninja 250R Tech Talk 17 February 20th, 2013 12:06 AM
ZZR Race bike steadyeddie 1986 - 2007 Ninja 250R Tech Talk 0 September 27th, 2010 05:15 PM
