Old November 30th, 2023, 03:41 PM   #1
Exponent
Motorcycle(s): Honda CB550, 04 Ninja 250
Overheating, fan not running
Hi,
Anyone know of a cause to this? Rode the bike today and it was overheating, got back and checked that the fan was running and it wasn't. Replaced one fuse that was blown and still nothing, fan is connected and everything. I checked the fan again with the battery and two wires and it works, so the fan itself isn't dead.
Somewhere between the fan and everything else its not getting power. Any ideas?
Exponent is offline   Reply With Quote
Old November 30th, 2023, 06:26 PM   #2
What were the symptoms of overheating? My fan almost never comes on. It takes a hot summer day and a lot of idling in neutral to make it turn on.
Old November 30th, 2023, 06:37 PM   #3
Exponent
Temp gauge way up, smoking, burnt smell
Don't be hasty
Old November 30th, 2023, 07:28 PM   #4
Unless you were running the engine without moving, it didn't overhear because of the fan not running. Something else is wrong too. Yes, the fan should have come on, but as I said, mine almost never runs under normal riding conditions.
I assume you checked the coolant level. Maybe the thermostat is stuck closed.
Old December 1st, 2023, 11:40 AM   #5
Exponent
How would I check if the thermostat is stuck?
Don't be hasty
Old December 1st, 2023, 12:56 PM   #6
Take it out, put it in boiling water, and see if it opens.
Here's the WIKI main page in case you haven't found it: https://faq.ninja250.org/wiki/Ninja250_Howto
Old December 1st, 2023, 01:47 PM   #7
Exponent
Any videos showing how to remove the thermostat?
Don't be hasty
Old December 3rd, 2023, 02:21 PM   #8
Exponent
Update after running the bike again and riding around the block the coolant was low, that happened twice so coolant was refilled, hopefully its fixed.
Don't be hasty
Old December 3rd, 2023, 04:49 PM   #9
Keep an eye out for signs of leaking coolant, including discolored oil, an extra clean spark plug, etc. Except for coolant changes, my 250's coolant has never changed level, so it seems that yours has found a way out.
Old December 3rd, 2023, 06:39 PM   #10
Exponent
I drained some when I was fixing the exhaust collars
Don't be hasty
Old December 7th, 2023, 07:13 PM   #11
How2
Motorcycle(s): None yet
overheating
Hi,
Hello
There is one quirk that might be the culprit. The fan is actually coming on, but the bolt on the propeller is loose and its not spinning.
Or the prop is spinning, but not fast enough to cool the radiator.
You can hear the fan, but aren't noticing if the prop spinning like it should.
Check tightness on the fan bolt.
Maybe, just maybe.
How2 is offline   Reply With Quote
Radiator Fan Always Running Ilham Fahri 2008 - 2012 Ninja 250R Tech Talk 3 July 2nd, 2017 12:06 AM
overheating issue tony7kp 2008 - 2012 Ninja 250R Tech Talk 9 June 21st, 2012 10:50 AM
Overheating Avenged7Fold 2008 - 2012 Ninja 250R Tech Talk 8 May 16th, 2012 06:23 PM
[roadracingworld.com] - Y.E.S./Pat Clark Sports/Graves Yamaha Running Fan Contest Dur Ninjette Newsbot Motorcycling News 0 May 12th, 2011 06:50 PM
Overheating? Reswob 2008 - 2012 Ninja 250R Tech Talk 23 July 24th, 2010 12:03 PM
