February 25th, 2017, 12:39 PM | #1 |
Join Date: Sep 2016 Motorcycle(s): 2007 Ninja 250 and 1991 Yamaha Virago XV750 Posts: 228
Newbe Question - Does the newer Ninjas (or any bikes) have OBDII connectivity?
Do any newer bikes support OBDII connectivity to their EPU like cars?
February 25th, 2017, 12:57 PM | #2 |
MOTM - July '15
I'm pretty sure there are diagnostic ports on some motorcycles, but I'm not so sure there is a set standard. Mine's carbureted, so someone who's fuel injected could better answer your question.
Also, I'm curious @choneofakind did your Ecotrons fuel injected kit have some kind of diagnostic system? |
February 25th, 2017, 01:30 PM | #3 |
Join Date: Dec 2016 Motorcycle(s): 2015 Kawasaki Ninja 300 Pearl Stardust White Posts: 23
There is a Diagnostic port under the pillion(seat) on Ninja 300's. I haven't messed with mine though.
February 25th, 2017, 01:32 PM | #4 |
February 25th, 2017, 07:07 PM | #5 |
No, there is no standard for motorcycle diagnostic ports like OBD for cars. Would be nice if it got there at some point.
February 25th, 2017, 07:23 PM | #6 |
The diagnostic port on all of my motorcycles is the same form-factor. It is always round, near the back of the bike, and it's the same hole that loud noises come out of while riding.
To interface with the diagnostic port, I typically position my nose within ten inches of the port and inhale.
Just batshit crazy. All his posts are endless diatribes. Some are actually entertaining but mostly batshit crazy. |
5 out of 5 members found this post helpful. |
March 7th, 2017, 07:48 PM | #7 | |
Old and slow
Join Date: May 2014 Motorcycle(s): Suzuki TL1000R, Honda CBR600F3, Ninja 250 Posts: 889
and that was on a 2003 bike... got to be some self diagnostic machines out there today.
March 7th, 2017, 10:55 PM | #8 |
Most modern FI bikes have some sort of diag port, and some type of electronic access, yes. Cars had similar things in the years before OBD as well. What makes OBD standards interesting is just that, standards. Same port, same protocols, etc. For bikes you need manufacturer-specific gadgets.
Car manufacturers didn't just decide to standardize, they were required to in order to sell cars in the US. Would likely have to be similar regulations to move motorcycles in the same direction. With the market as small as it is comparatively, it doesn't seem likely to be a priority of any legislator.
March 8th, 2017, 02:49 PM | #9 | |
Old and slow
then he writes legislation that requires the use of his BIL's plug and volia' instant zillionare.
March 9th, 2017, 06:05 AM | #10 |
OBD is mandatory for new bikes in EU from Jan 1st 2017, I suppose also with a standard for the connector.
March 12th, 2017, 10:48 PM | #11 |
Manufacturers can make more if they sell machines with proprietary interface units.
Having a standardized connector and interface protocols would put a lot of performance shops out of business because the lowest bidders would quickly develop/sell/inundate the market with tech required to interface with a wide range of models. I also think it would be terrible for the actual machines because suddenly any un-qualified idiot could afford the [cheap] tech to interface with the machine and do things to it's various mechanisms that they don't understand enough about. I'm referring to engine tuning and that changes of that nature. Keeping a standardized plug and interface protocols from becoming mainstream would be in the best interest of the manufacturers for the purpose of selling more products. If you need proof of this, look at the development of OBD over the years. OBD1 simply flashed trouble codes, stored after a problem occurred. It took a degree of skill to read the codes and diagnose the problem. That kept mechanics employed. With the advent of OBDII and cheap [widely available] scan tools, anyone could afford the tool for their particular car and that enabled any end-user to get waaaay over their head in terms of performing certain mechanical tasks. Some degree of skill is required to replace sensors, rewire things, or change out mechanical parts as needed. Many modern cars trigger numerous SRS/ABS/PCM/ECU codes at the slightest sign of a hiccup within the diagnostic circuitry. Because the diagnosis tools are so widely available, any car owner without mechanical expertise suddenly feels empowered to undertake massive mechanical projects without proper training or experience. Youtube has played a massive part in this because it enables anyone to feel competent enough to undertake things which should otherwise be left to a qualified mechanic. There's a big difference between an enthusiastic idiot with tools and a qualified technician. Need proof? Look at the picture ^^^^^
March 13th, 2017, 01:35 AM | #12 |
Much truth in this. I have direct experience from troubleshooting a misfire in my car. The code is only part of the information you need to fix something. Plus, for some reason people seem to be allergic to dropping a few bucks on the factory maintenance manual.
FS: bikes! Not ninjas | verboten1 | Motorcycle-related | 8 | January 4th, 2015 05:04 PM |
Question about throttle on larger bikes | Jiggles | General Motorcycling Discussion | 47 | September 27th, 2012 06:43 PM |
cargo net on the newer ninjas | lilninja | General Motorcycling Discussion | 9 | May 29th, 2010 03:39 PM |
Question about newer model fairings | 5150 | 1986 - 2007 Ninja 250R Tech Talk | 3 | January 24th, 2010 04:16 PM |
MotoGP question re bikes.... | adouglas | General Motorcycling Discussion | 20 | August 11th, 2009 04:46 PM |
