Old August 19th, 2018, 04:09 AM   #1
$wim
Motorcycle(s): 06 ninja 250r, 82 yamaha xj750
exhaust fabrication for 06 250r
looking for advice on possibly either fabricating a new set of mufflers, or a friend had said that I should gut the stock mufflers. but would that cause me to lose ot on horse power?
$wim is offline   Reply With Quote
Old August 19th, 2018, 03:30 PM   #2
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
In my quest to lose weight on the bike and not in my wallet I experimented with making a 2 into one using stock head pipes and stock mufflers.
this didn't turn out to well...lost 6 mph on my test acceleration strip, so next I ran a long drill bit down the exhaust exit, it made a little more noise but didn't pick up any mph on the test course. Next I cut the muffler apart at the front weld of the muffler (where the muffler and head pipe meet) and used a big punch to curve back the center hole I had drilled out, and removed the "screen" on the inside pipe.
before
and after.
this did pick up a couple of mph (and a little more noise) on the test course, but was still 4 mph slower than stock pipes and mufflers. After that I put on another set of stock head pipes and gutted another muffler (so it was dual pipes again) and walla, it was now 2 mph faster than it had been stock with a little more noise again, but easily streetable without getting the neighbors up in arms. So this gained a couple mph but didn't loose more than a few ozs.
My next step was to find a used Muzzy header. It was then 2 mph faster than my gutted mufflers and 4 mph faster than stock. All jetting is stock, I know everybody says you need to rejet, and we did the rejetting thing on two different pregens and they both are fastest with stock jetting. Jetting is still a tiny bit rich at wide open throttle but close enough. BTW we are at 1300 ft. above sea level.
ps: also running stock airbox and stock air filter
Old August 20th, 2018, 07:37 AM   #3
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
What you loose is torque . I found that short open exhaust cost about one or two ft lb of torque. Plus added noise.
Long pipes seem to be the best for scavaging. The best system I ever made was 57 inch primary pipes and long cones. Then a reverse cone at the end. I kept open I g the outlet until the power stopped going up. About an inch and a half .
Worlds fastest 250 ninja
Old August 24th, 2018, 09:52 PM   #4
$wim
I probably won’t gut mine then, do you have any pictures or that 57 in primary with the reverse cone?
Old August 25th, 2018, 07:32 AM   #5
Racer x
Racer x's Avatar
This is the exhaust
File Type: jpg F983D4B4-3E39-4334-AD06-3902389FF134.jpg (132.3 KB, 17 views)
Old August 26th, 2018, 01:39 PM   #6
Is that 57-inches before 2-1 merge? I think there's an optimum angle for the cones on exhaust. Need to look that up...
Old August 26th, 2018, 03:02 PM   #7
Racer x
Racer x's Avatar
It is a twin exhaust system. 57 inch from the valve to the end of the cone. Then a four inch cone.
It is copied from a 500cc MV Augusta system in the Barber museum. Same bore and stroke. I figured they knew what the are doing since I don’t.
File Type: jpg 7746A849-009D-480B-8EA1-05D7B4E26C7C.jpg (68.8 KB, 12 views)
Old August 26th, 2018, 08:02 PM   #8
I'm designing 2-1 for pre-gen now. From what I can gather on various published studies out there, I want header pipes to be between 18-22". Then critical diameter and flow-rates of pipe and muffler after that. What failed on Z1R's experiment was he stuffed 2-cylinder's worth of volume & flow after merge into pipe and muffler designed for 1.
Going to use Tyga's new-gen design for diameters after merge. Appears to work well and better than some other systems on market with pipes that are way, way too large. Large enough for 150-bhp engines!
Old September 11th, 2018, 07:16 AM   #9
rottyfan
Motorcycle(s): 2006 Ninja 250, 1999 Aprilia RS50
I have a used Muzzy 2-into-1 header also. How did you finish the rest of the exhaust, midpipe and muffler, or did you just run the header?
rottyfan is offline   Reply With Quote
Old September 12th, 2018, 08:13 PM   #10
Z1R rider
Z1R rider's Avatar
no, I bought a complete system with the aluminum muffler
Old October 6th, 2018, 09:57 AM   #11
gokartmozart
gokartmozart
gokartmozart's Avatar
Motorcycle(s): 250 ninja ,it's realy a ninja motor on a scratch built alum chassis (avatar is my old kart)
did you keep the OEM crossover on your head pipe?
Will legalized marijuana remove roadrash scars ?
gokartmozart is offline   Reply With Quote
Rear fender fabrication SabreValkyrn 2013 - 2017 Ninja 300 Farkles 6 March 12th, 2014 08:42 AM
250R FI + US Exhaust. Trixxr 2008 - 2012 Ninja 250R Tech Talk 10 April 28th, 2011 01:21 PM
[topix.net] - Falcon Kestrel Motorcycle Hand-Fabrication Gallery Ninjette Newsbot Motorcycling News 0 June 24th, 2010 01:30 PM
250R Exhaust wongboy 2008 - 2012 Ninja 250R Farkles 6 December 18th, 2008 08:17 PM
