Old March 3rd, 2017, 10:30 AM   #1
[motorcycle.com] - Five Things to Love About the Honda CBR500R
If your dreams include parking a brand new Honda RC213V-S or CBR1000RR SP in the garage someday but not just now, it’s nice to know a little of that Championship-winning Honda sportbike DNA is easier to spot than ever in the 2017 CBR500R, and parking one of them in your garage is doable right now. The CBR500R has quite a few things going on for it that bigger sportbikes just can’t match: The ability to travel more than 25 kilometers on a liter of fuel is one of them, and greatly reduced maintenance in an incredibly user-friendly package that weighs just 191.9 Kg. is another. You sit in a semi-racy crouch on this one, in a comfortably aerodynamic swagger that encourages you to ride, sporty as you want, every day – sometimes all day.
ONE: AGGRESSIVE DESIGN
A full fairing with supersport styling provides a sharp look that’s unmistakably CBR, along with aerodynamic lines that slice cleanly through the air while helping to shield the rider from the worst of the elements. A sporty riding position places the rider in a comfortable, dynamic seating stance that’s ideal for mastering curves without being overly cramped when it’s time to commute across town or out on a weekend journey.
There’s something to be said for experience: Honda built its first CBR 25 years ago, and constant refinement has resulted in a modern motorcycle with near-perfect chassis geometry and balance: 25.5 degrees of rake and 102mm of trail atop a 1410mm wheelbase provide a sweet-handling platform that lets the CBR500R take advantage of its light weight to hang with larger motorcycles when the road goes all curvy. It’s also perfectly stable, yet light-steering and agile, when it’s time to take on traffic and hoof it homeward down the highway.
A seat height of just 785mm, along with the bike’s narrow waistline means you don’t have to be tall to feel comfortably in control, and an ergonomically correct passenger seat means you’ll still be friends after you take your friend for a spin.
Lightweight cast aluminum wheels, packing 120/70-17 front and 160/60-17 rear radial tires, a 320mm front and a 240mm rear brake rotor complete the high-performance package as complement the high-performance look. Equipped with optional ABS, those brakes provide plenty of safe braking power in a wide range of conditions.
TWO: ENHANCED AIRFLOW
From the leading edge of its aggressive nose fairing to the tip of its aero-sculpted tail, the highly evolved profile of the CBR is designed to allow rider and machine to cleave as cleanly through the atmosphere as possible. The opening at the bottom of the windscreen relieves the low-pressure area inside the cockpit, reducing turbulence and creating a large still-air pocket for the rider’s torso. Meanwhile, the widest part of the front fairing pushes airflow around the sides of the rider’s hands while the lower section directs air around the legs.
The aerodynamic front fender and nose direct air into the liquid-cooled engine’s radiator, and from there that heated airflow is directed outward through the fairing’s side cutouts and along its trailing edge, away from the rider.
Ergonomics are an integral part of creating comfortable airflow, and the CBR500R’s semi-crouch leans the rider just forward enough to offset air pressure once the bike’s achieved cruising speed. That results in a neutral riding position that unweights the wrists, and lets the rider go on for many fatigue-free miles, backstopped also by a comfortable seat and a near complete lack of vibration from the counterbalanced Twin-cylinder engine.
THREE: OPTIMUM POWER
The CBR500R’s 471cc parallel-twin is a marvel of modern engineering taken in a slightly different direction, one which stresses high efficiency as well as high performance. Even though it’s ridiculously fuel efficient and economical to run, this engine still provides exhilarating performance for just about anyone who’s not already a professional racer or astronaut. In the everyday world, even if you’re a highly experienced rider, it’s really hard to argue with a lightweight yet full-sized motorcycle that has no problem at all cruising smoothly along on the fastest highways and open roads, especially when that performance is accompanied by a huge gain in fuel economy – approaching 27 kpl. It’s also far easier on consumables like tires, drive chains, and maybe even insurance premiums.
The Twin’s tuning provides solid torque in the low- and mid-rpm ranges where most riders spend most of their time, which makes the bike easy to launch and accelerate quickly. And its smooth-shifting six-speed gearbox and light clutch action work with a precision you wouldn’t expect to find on a bike it its price range. Serious sportbike riders already know the real secret anyway: On curvy roads, it is great suspension, light weight, and smooth power delivery that carry the day. The 2017 CBR500R has all three.
Honda’s PGM-FI fuel injection ensures this one “injects” cleanly and linearly from idle right up to its 9,000-rpm redline, providing effortless, controllable propulsion whether you’re hard on the gas chasing your pals to breakfast on winding backroads or picking your way through rush-hour traffic after a dull day in the cubicle.
Top that off with a shim-type valve-adjustment system that not only reduces friction but also means greatly simplified (cheaper) maintenance. Oil changes are only needed every 8,000 miles.
FOUR: LED HEAD AND TAIL LIGHTS, ETC…
High efficiency, bright LED head and tail lights consume less juice, last longer and most importantly, light up the night and the CBR – increasing your margin of safety. They’re but one of many features you wouldn’t expect on a bike that sells for $6,699. Other things include an adjustable front brake lever, a hinged fuel cap, and a level of paint quality and overall fit and finish that Honda is famous for. A scissors-type primary drive gear (as found on earlier Honda icons such as the RC30 and RC45 superbikes), and a scissors-type counterbalancer drive help to eliminate driveline lash and gear whine.
In the cockpit you’ll also find a sophisticated instrument panel with a speedo, easy-to-read bar graph tachometer, two tripmeters, a fuel gauge, clock, and real-time and average fuel consumption readouts. (At around 27 kpl consumption plus a 16.7-liter fuel tank equals a range 450 km.) Vital components are tucked away behind carbon-fiber look trim panels.
The CBR’s suspension, drawing upon five decades of international competition, consists of a preload-adjustable 41mm front fork with 108mm of travel, and a Pro-Link mounted single-shock at the rear with nine-stage spring preload adjustability and 119mm of controlled travel – so riders of all sizes can dial the CBR in for precise handling. In fact, the CBR’s excellent, compliant-yet-controlled suspension is another area where it’s difficult to find any evidence of cost-cutting on Honda’s part.
FIVE: NEW EXHAUST DESIGN FOR A CRISPER, SPORTIER SOUND
Beginning with the 2016 model year, Honda graced the CBR with its current swoopy angular bodywork and a bigger, 16.7 litre fuel tank: Along with those came a revised stainless steel exhaust system that gives the bike a throatier growl and a menacing presence that nearly belies its super-approachable nature. It’s not loud enough to upset the neighbors, but it does let them know this is a real CBR.
Practical and economical though this one may be, it’s still packing a pair of 67mm pistons that squeeze the intake charge from a pair of 34mm throttle bodies up to a compression ratio of 10.7:1. Double-overhead cams control four valves per cylinder, just as Soichiro Honda intended when his little motorcycle factory first went Grand Prix racing at the Isle of Man TT in 1959. The motorcycle it developed for that race was the RC142, with a DOHC parallel Twin much like the CBR500R’s, but with only 125cc engine displacement. Compared to that first effort, which won Honda the Constructor’s Prize in its first year, the new CBR is a fire-breathing monster. Size is relative. In more ways than one, the CBR500R rides way “bigger” than its engine displacement and price tag might lead you to believe.
Five Things to Love About the Honda CBR500R appeared first on Motorcycle.com.
Click here for full story...
Old March 3rd, 2017, 03:44 PM   #2
headshrink
headshrink's Avatar
They forgot to mention burning oil. No review would be complete without mentioning this "feature."
I like mine, but think the Ninja 650 would have been a better choice.
Old March 4th, 2017, 11:09 AM   #3
gitoy
Motorcycle(s): 04 ninja 250, 05 zzr 600 (sold), 07 cbr600rr
so bob, the burning oil "feature" hasn't been rectified in 2017?...
gitoy is offline   Reply With Quote
Old March 4th, 2017, 11:32 AM   #4
pantera
pantera's Avatar
Motorcycle(s): 2016 Kawasaki Vulcan 900 Custom / 2017 Kawasaki Ninja 300
Had one and hated it.Sold a month later.
pantera is offline   Reply With Quote
Old March 4th, 2017, 12:52 PM   #5
headshrink
headshrink's Avatar
Not to my knowledge. The more I look into it, the more I see it's an issue for other Honda engines. I switched from Honda oil to T5, and it seems to have really slowed down though.... this is only the first change since the switch, so more data is needed.
Old March 4th, 2017, 01:01 PM   #6
headshrink
headshrink's Avatar
Forgot to mention the lies they tell about the suspension. Adding preload adjusters helped a lot, but it still sucks. Springs are wayyyyy weak, and there's practically no damping. Bounces like a Pogo-stick. I added the Traxxion drop-in kit, which helped a lot (new springs, spacer, gold valve emulators, damper rods, oil).
They improved a shifting issue in 2016, which I was able to use parts from to fix my 2014... not perfect, but acceptable for a used bike at this point.
It's pretty comfy (Corbin seats on all bikes), and does a lot of what the 250r did a little better, although more like a Cadillac, not a Porsche.
I tend to turn my bikes into light to middle-weight sport touring bikes, so my eyes are on the Ninja 1000 for the next one (too bad so heavy). The VFR was also on the short list, but Honda killed it again!
Old March 4th, 2017, 08:59 PM   #7
britx303
Motorcycle(s): TOOOOOO MANY!!
Its so good, it needs another 200cc to compete against eveyone elses 300's......oh wait,thats a bad thing
britx303 is offline   Reply With Quote
[motorcycle.com] - Six Things To Love About Honda’s CRF450R Ninjette Newsbot Motorcycling News 0 February 17th, 2017 12:31 AM
[motorcycle.com] - Honda CBR500R, CB500F Fuel Sensor Recall Affects 14,575 Motorcycle Ninjette Newsbot Motorcycling News 0 August 21st, 2015 01:21 PM
[motorcycle.com] - Value-For-Money Hondas: 2014 Honda CB500F/CBR500R Ninjette Newsbot Motorcycling News 0 June 30th, 2014 03:00 PM
[motorcycle.com] - 2013 Honda CB500F and CBR500R Review - First Ride Ninjette Newsbot Motorcycling News 0 May 22nd, 2013 08:40 PM
[motorcycle-usa.com] - 2013 Honda CBR500R First Ride Ninjette Newsbot Motorcycling News 0 May 22nd, 2013 05:20 PM
