Old April 20th, 2011, 12:40 PM   #1
Want to know: Stock turn signal type? Wattage? Socket type? Similar?
See title.
Oh, and are they the same from the previous to current-gen?
Old April 20th, 2011, 01:53 PM   #2
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
I need the exact thing, was about to post and ask.... Also voltage
Old April 20th, 2011, 03:22 PM   #3
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Voltage is nominally 12V though packaging and specs often quote 13 or 14 volts. It doesn't matter. The voltage of just the battery is 12, but when the motor's running the alternator puts out 13-14 volts to keep the battery charged properly.
The 2006-2007 bikes used R10W bulbs for the turn signals which where 10W and a single contact bayonet base. Older gens used an 1156 IIRC, it's ~27 watts.
You'll see some confusion on watt ratings, with the same bulb rated different watts on different sites. The reason is that watts is the result of volts times amps, so a 2.1 amp bulb at 12V uses 25.2 watts, and the same bulb at 14 volts uses 29.4 watts. Don't worry about it...
anyone try this type of helmet, 3/4 to full transformer type lol rabies Motorcycle Gear 36 June 6th, 2014 11:57 PM
GTA type of sh** right here.. RJprod Videos 6 October 6th, 2013 10:43 AM
What type of camera do you have? Old Lemon Videos 11 May 8th, 2012 08:39 AM
type of glue to use wayanlam 2008 - 2012 Ninja 250R Tech Talk 5 April 30th, 2011 09:33 AM
what type of riding do you do? gitoy General Motorcycling Discussion 21 June 22nd, 2009 06:53 PM
