Old July 13th, 2012, 11:56 AM   #1
claymaker
Question about tire sizes!
My 100/80/16 is nearly bald and I am buying a new front tire for my 250. If I bought a 130/80/16 would that fit on the rim or would the 130 be too big? Would any size as long as the 80/16 fit?
claymaker is offline   Reply With Quote
Old July 13th, 2012, 07:17 PM   #2
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
I don't even think that'll fit between your forks, and definitely not inside the front fender. The most common size to replace the stock tire with is 100/90-16, it's slightly larger in diameter which makes the speedo slightly more accurate in many cases. The 130 size is typically found in the rear, and again most people go with a 90-series which is slightly larger in diameter. Both sizes, 100/90-16 and 130/90-16, are much easier to find in a variety of tire models and brands than the stock 80-series tires are.
Old July 14th, 2012, 09:50 AM   #3
The metric designation:
"The 130 designates the tire's width in millimeters, measured in a straight line through the tire from one edge of the tire's tread to the other. The second number, 90, is a bit trickier to understand. This represents the aspect ratio between the tire's width and its height, or how tall a tire is in relationship to its width. Simply put, the higher this number is, the taller the tire will be. In this case, the tire is 90 percent as tall as its width, or 117mm.
The last number, 16, is the tire's rim diameter expressed in inches."
http://www.americanmotorcyclist.com/...ignations.aspx
The geometry of the bike would also change, increasing rake and trial and messing the steering balance.
Old July 14th, 2012, 09:55 AM   #4
7oxSin
MSF Coach!
7oxSin's Avatar
Motorcycle(s): 2003 ninja 250
Man thanks! I know I'm not the OP but that was very helpfull!
Posted via Mobile Device
7oxSin is offline   Reply With Quote
Old July 14th, 2012, 01:26 PM   #5
Snake
Snake's Avatar
Some people have been able to fit a 120/80/16 but I would not recommend it it's not a good idea steering wise, to go with a wider front tire.
Tire sizes/tire brand??? Tadydrift 2008 - 2012 Ninja 250R Tech Talk 10 January 5th, 2015 05:24 AM
Mismatched Tire sizes... DmbShn41 2008 - 2012 Ninja 250R Tech Talk 3 May 11th, 2014 12:28 PM
Tire Sizes Kokosun 1986 - 2007 Ninja 250R Tech Talk 7 June 8th, 2013 08:47 AM
Tire sizes fredhsu General Motorcycling Discussion 12 August 9th, 2012 07:37 PM
Help with confusion over tire sizes PitBull General Motorcycling Discussion 14 April 4th, 2011 12:17 PM
