Old November 12th, 2010, 02:47 AM   #121
8gauge
8gauge's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R Limited Edition - R.I.P. 12/2/2010
k, i took a look at the pics at the beginning of this thread and it looks like the zipties were filed down at the ends at a 45 degree angle. correct me if i'm wrong. maybe that'll do the trick...
"Your truth, is not my truth" -Bruce Lee
8gauge is offline   Reply With Quote
Old November 12th, 2010, 08:31 AM   #122
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
Originally Posted by randomwalk101 View Post
Yeah, just find the size pipe that will fit the portion where you now have the zip tie glued on.... sorry I forget what diameter pipe the is (1.5"?), but it was close.
bah... here's some pics instead.
I did this mod on the 08 250R (same thing applies to the pre-gen) with PCV pipe as pictured above. Mine is about 2/3 thick as KKIM pic. which is about 2 zipties. I think I'll take it apart (got another throttle tube of Ebay) and redo it with full thickness. I think it'll work...but I only use 1 pull throttle cable instead of 2. With the second cable in place, it'll bind. So I guess the trick is to remove the second cable. The second cable is there for backup in case the 1st one jams up..but that push cable isn't going to do anything I think if there other one "stuck"...test it out yourself..jam the other one with a plier or something preventing it from retracting...the "push" will do nothing. If anything, you can 1) hit the cut off switch button, or 2) grab the clutch or 3)turn off with the key.
Throttle cable failure without the second push cable is about 0.0001% so weight your risk/benefits wisely
I'm thinking of doing the same. I just found some precut PCV piping that fits the throttle tube perfectly.
So, how is the response so far? Better? The same? Have you come across any issues?
Old April 9th, 2011, 03:54 PM   #123
streetracer744
Ninja ZX-5R
streetracer744's Avatar
Motorcycle(s): Ninja
I have filed both of my ends down and trimmed the side in as well...But im still having slight binding at WOT is barley sticks for about 1 sec then goes down smooth..If i almost go WOT is never binds at all...ANy idea how to fix this?
2002 Ninja 500r....Mod friendly
streetracer744 is offline   Reply With Quote
Old April 9th, 2011, 04:00 PM   #124
make sure it's not your cables binding somehow and if that's not the problem, try using some slightly thinner cable ties.
Old April 9th, 2011, 04:15 PM   #125
Betlog
Betlog's Avatar
Motorcycle(s): 2009 250r
That's pretty dangerous, you might want to take that out until you fix it. Good luck.
Betlog is offline   Reply With Quote
Old April 9th, 2011, 04:57 PM   #126
streetracer744
Ninja ZX-5R
im pretty sure its the actual pull cable...what is the cable ties?
Old April 9th, 2011, 05:27 PM   #127
cable tie= zip tie
Old April 11th, 2011, 08:53 AM   #128
streetracer744
Ninja ZX-5R
i double checked everything is there is still little biding!...it only binds with the bike off if i twist it past WOT and if im riding it doesnt stick, catch or bind...WTF...should i remove push cable?
Old April 11th, 2011, 10:00 AM   #129
huh??? how can that be?
hmmmm, okay... what makes you think the throttle is binding... is it an actual physical resistance at the throttle grip when you turn it to WOT? how can you turn it past WOT???
Old April 11th, 2011, 09:59 PM   #130
streetracer744
Ninja ZX-5R
okay since the throttle requires less turning there is a little gap at the end of WOT that does do anything now...does that make sense?? its like a .2 inch play right at the end that if i go passed WOT it will stick for a sec and snap back...and if the bikes on and i rev it WOT it doesnt stick b/c i dont need to go passed to that .2inch play and even if i do it doesnt stick like when its off?? maybe the throttl line needs to be shortend at the carbs? my adjustment for throttle cable is already turned in all the way...If i loosen it at all my throttle binds/sticks more and more!!
Old April 11th, 2011, 10:01 PM   #131
streetracer744
Ninja ZX-5R
and yes it deff the throttle cable binding b/c if i play with the line and the adjuster i can make it stick more/less or not at all for a few secs...... anyway I ordered the r6 throttle and will play with that!!
Old April 11th, 2011, 10:19 PM   #132
WOT = wide open throttle and should happen when the throttle is opened all the way to it's physical stop. Sorry, I don't understand what you're trying to say.
Old April 11th, 2011, 10:44 PM   #133
streetracer744
Ninja ZX-5R
im saying the last .2inch of the throttle dont make my rpms jump any faster and also make it stick...my throttle is a shorter twist now so lets say WOT is a 1.5" twist it only takes me 1.3" to be at WOT..so the last .2" doesnt do anything and is where my cable sticks/binds...so im saying i dont need to twist all the wat to achieve full throttle!..sorry for the confusion
Old April 11th, 2011, 10:47 PM   #134
gotcha... do you have the proper amount of free play at the throttle?
Old April 12th, 2011, 09:19 AM   #135
streetracer744
Ninja ZX-5R
not to much free play b4 I twist the throttle like it used to be. its very sensitive now and as soon as i twist the rpm move
Old April 12th, 2011, 10:55 AM   #136
You need to have some free play when the throttle is at rest. Sounds like the cable is adjusted too tight.
Old April 12th, 2011, 11:22 AM   #137
streetracer744
Ninja ZX-5R
will check on that and loosen it up to see!
Old April 12th, 2011, 08:58 PM   #138
setasai
setasai's Avatar
Mine barely has any binding but it's definitely tight. I dont see how I can adjust it to loosen it up at all though. I looks as if it's as loose as it can get. Will have to check again later.
Old April 15th, 2011, 06:21 PM   #139
streetracer744
Ninja ZX-5R
ok so i got my r6 throttle today and its a shorter throw for sure..its a little less of a twist than the OEM tube w/ the zip tie mod..Id say about a 1/5 turn now w/ the r6 throttle..I love it but it still binds at WOT for a sec.... i have the throttle disassembled and have found that it the pull cable that BINDS! If i pull on just the line its self it still get stuck if i pull it out all the way...What can cause this?? is mt cable kinked some how? even with everthing taken apart the line catchs!!! ERR help!
Old April 15th, 2011, 06:24 PM   #140
have you tried cleaning and lubing the cable?
http://www.ninjette.org/forums/showthread.php?t=10016
what year is your bike?
Old April 15th, 2011, 06:31 PM   #141
streetracer744
Ninja ZX-5R
2002... and no i have not cleaned the line yet but its the main pull throttle cable for sure.... its smooth all the way untill i pull the line out all the way untill it can move any more then it sticks for a sec
Old April 15th, 2011, 06:35 PM   #142
get a cable luber and shoot some wd40 through there and see what kinda crap comes out the end. be sure to put a rag on the end to catch whatever comes out so you can see what was in there.
if that doesn't fix it, then a new pull cable should solve your problem, if you are sure it's the cable that's binding.
Old April 15th, 2011, 10:31 PM   #143
20ninja03
Motorcycle(s): 2003 Ninja 250
Gonna have to try this mod. Thanks for the write up
20ninja03 is offline   Reply With Quote
Old April 16th, 2011, 06:34 PM   #144
streetracer744
Ninja ZX-5R
its deff the cable and im gonna order a new one its only 13$$...I know this b/c even if the throttle is disassembled the cable still sticks by hand..IE the throttle tube isnt pulling the cable my HAND IS and its still sticking
Old May 3rd, 2011, 12:06 AM   #145
Liquidtoon
Liquidtoon's Avatar
Motorcycle(s): 09 Ninja 250r
I know this is in the pre-gen section but does anyone happen to know if the r6 (or any others) throttle will work on the 08+? I am thinking of giving the pvc method a shot just to see the result but would much rather a more professional style solution, just for safety if nothing else.
Liquidtoon is offline   Reply With Quote
Old May 3rd, 2011, 09:27 AM   #146
setasai
setasai's Avatar
I believe it turns out the R6 and 08+ have close to if not the exact same size throttle tube so it doesnt end up changing anything.
Old May 3rd, 2011, 02:06 PM   #147
that's what I've heard as well, but can't confirm it. But, if it is true... does this mean that pregen owners can gain a quick turn throttle by simply changing their throttle tube to a new gen one?
anyone have some pregen and newgen throttle tubes laying around to see if the outside diameters are different?
Old May 14th, 2011, 11:59 AM   #148
nickadolph
Motorcycle(s): ninja 250
I was having trouble getting the zip tie to stick (they would both just pop off) so I tried using a cut closet rod mount and it's just slightly smaller than the throttle so it kind of clips on and stays. No need to hold it with pliers hoping that the glue will stick when you let go, just glue and walk away. Here is what I'm talking about. With the right piece just cut about 1/4" off the round part.
nickadolph is offline   Reply With Quote
Old June 5th, 2011, 06:02 PM   #149
wtfh4xx
Opinionated individual :)
wtfh4xx's Avatar
Motorcycle(s): 2010 Ninjette Special Edition (red/black)
How are everyone's zip ties holding up?
I'd imagine over time the tie will wear down.
Yoshi slip on, shimmed 2 washers, zip tie throttle mod, pre-load #2, snorkel delete
2010 SE 250R!
Miles in the saddle: 1000
wtfh4xx is offline   Reply With Quote
Old June 7th, 2011, 12:18 AM   #150
CynicalC
CynicalC's Avatar
Motorcycle(s): '96 EX250
It shouldn't really... They're plastic just like the throttle tube itself, and there shouldn't be any friction on it. It wouldn't hurt to check, but even if it started to wear through a little bit, which I *think* is unlikely, it wouldn't hurt anything.
Old October 15th, 2011, 01:41 AM   #151
TFKninja
TFKninja's Avatar
Motorcycle(s): 2009 ninja 250r
Just a thought on this, I have my throttle tube off completely at the moment while I wait for a new handle bar, But was thinking Why not just cut a piece of irrigation pipe and file, like cut a thin bit off the end slice it or even take a piece out bevel the two edges at the required angle and clip it on even with the glue, may even be able to get different thickness with class ratings of pipe, It is only another alternative as irrigation is my occupation and it is readily available to me. if any one could think of any issues I could have with this, I'd be interested.
TFKninja is offline   Reply With Quote
Old October 15th, 2011, 08:38 AM   #152
This has been covered on here somewhere already, I think by kkim. IIRC, it had to be just thin enough at the ends so that it didn't get stuck in the throttle control box, and had to be a smooth transition of thickness pipe so that it keeps the throttle pull linear...
Old October 15th, 2011, 08:43 AM   #153
it's actually on the first few pages of this thread. the pictures are down, but you'll get the idea.
Old October 17th, 2011, 03:44 AM   #154
TFKninja
TFKninja's Avatar
Sorry If I was misunderstood, I was just looking at alternative material, this is ok isn't it, Pictures are better.
Hugs it well and is a natural shape. This a class 9 pipe, I hope the thickness is fine and it doesn't bind, I will assemble it before I glue it for a trial to see how it fits.
Old October 17th, 2011, 07:20 AM   #155
That looks pretty darn good!
any binding issues yet?
Old February 2nd, 2012, 09:55 PM   #156
hackeron
Motorcycle(s): Ninja 250r (2009)
Any binding issues?
http://www.fuelly.com/driver/hackeron/ninja-250r
hackeron is offline   Reply With Quote
Old February 2nd, 2012, 11:12 PM   #157
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
FYI - this mod sucks.
Old February 2nd, 2012, 11:14 PM   #158
hackeron
Why does it suck?
Old February 3rd, 2012, 11:18 AM   #159
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Originally Posted by hackeron View Post
Why does it suck?
Because when I attempted this some time last year I immediately experienced cable binding issues. Trailerboy experienced the same thing on his bike @ a trackday event last month. Granted he didn't have any issues prior but you may eventually experience this. Hopefully not during emergency situations.
I'm not a big fan of simple DIY homemade mods--I'm a direct fit kinda guy.
Old February 3rd, 2012, 12:14 PM   #160
+1!! we cut that stupid **** off cause its ****!
DIY How to Lube and Adjust the 250R Clutch Cable and How to Add 10 HP w/ one Mod!!! kkim 2008 - 2012 Ninja 250R Tech Talk 51 October 11th, 2014 06:42 PM
Throttle went while riding -> need new throttle cable? AndrewMack 2008 - 2012 Ninja 250R Tech Talk 13 September 8th, 2013 06:17 PM
Adjusting Throttle Cable - Barrel adjusters and Throttle body adjusters are maxed out theob 2008 - 2012 Ninja 250R Tech Talk 10 July 19th, 2012 05:01 PM
(zip tie mod + u-turn) x me being an idiot = no good Monkeytofu !%@*#$%!)@#&!%@ I crashed! 1 July 4th, 2012 07:59 PM
Throttle & Throttle Cable Smoothness paterick4o8 2008 - 2012 Ninja 250R Tech Talk 3 December 1st, 2009 01:50 PM
