Old April 15th, 2009, 09:01 AM   #1
Buffalony
Buffalony's Avatar
Older led video
Any one catch this old video?
Pretty interesting little point in there somewhere!
Last futzed with by Alex; April 15th, 2009 at 11:01 AM. Reason: embedded video
Old April 15th, 2009, 09:38 AM   #2
Nemy
Nemy's Avatar
Motorcycle(s): 2009 SE Ninja 250R
That's pretty cool. Didn't know miliseconds translated into several feet. But you also gotta factor in that LEDs are harder to see during the day... lose-lose for bikers
Nemy is offline   Reply With Quote
Old April 15th, 2009, 11:02 AM   #3
Hi Joe -
You should try to embed the videos in your posts, give it a shot. I edited your post to do it, just hit edit yourself now and you can see what it looks like. Here's a link with detailed instructions on how to do it.
Old April 15th, 2009, 12:59 PM   #4
Syphen
Some weird Canuck!
Syphen's Avatar
Motorcycle(s): '92 CBR250RR "Babyblade", 2008 Ninja 250R, 2001 CBR600F4i
Bahahhahah I love the pinto being rear ended. That was great.
My F4 had a mototeck undertail and used LED tail light bulbs. I ended up modifying the housing to use standard bulbs because the LED's could not be seen during the day.
I still like CBR's more Just kidding.
Syphen is offline   Reply With Quote
Old April 15th, 2009, 01:05 PM   #5
Snake
Snake's Avatar
That was a perty good video. I swaped my brake lights to LED's. They are alot brighter.
Old April 15th, 2009, 05:50 PM   #6
Buffalony
Buffalony's Avatar
Originally Posted by Alex View Post
Hi Joe -
Thanks for the link
Old April 15th, 2009, 06:09 PM   #7
sombo
Newb..... on a steeek! :D
sombo's Avatar
Motorcycle(s): 2012 Harley Davidson XL883L Sportster Superlow
Actually just the opposite. Any vehicle I've seen with LED lights instead of the old ones have been a LOT more noticeable day or night. Also working in the electronic field and seeing alot of modern day LED's I can say without a doubt that they are MUCH easier to see in the day then normal lights cause their light is both brighter and more direct. In case you didn't know, alot of 'laser' lights on the market use high power LED's with a focusing lens.
sombo is offline   Reply With Quote
Old April 15th, 2009, 06:12 PM   #8
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
My tail light burned out one time as darkness fell, thanks to fellow motorists I was notified of my problem. Instead of getting a OEM replacement i put in one of those LED lights. So far it has lasted longer. Seems to be as bright. It doesn't "glow" and spread light as well as the filament bulb but you can see it just fine. At least I haven't been hit yet, so I guess it's working well.
Old April 15th, 2009, 06:33 PM   #9
Buffalony
Buffalony's Avatar
Some one correct me but I think the average LED last something like 100000 Hrs. No? I could Google it but dont have time right now....off to work..graveyard
I'm in the market for a new brake light. I specifically want one that lights up at the back towards the reflectors on top of lighting at the rear. I found a few but havent ordered yet. I want to upgrade to LED all around because of their lifetime. I'm trying to get all of the bulb types matched correctly first, including the clusters.
I believe LED's are brighter during the day depending on the LEDs being used and how many. I know some are not as bright as bulbs too. The replacements I put in the Camaro are brighter than the bulbs, only they don't reflect in the housing like a bulb, if ya know what I mean.
Old April 15th, 2009, 09:31 PM   #10
Nemy
Nemy's Avatar
ya the one's I've seen on trucks are definitely brighter. But especially some of the LED turn sigs that people have on their bikes - I have to strain to see whether they're blinking or not. Plus it usually doesn't help that they're blinking much faster than normal.
Old April 16th, 2009, 06:32 AM   #11
Agreed. LED's can be tremendously bright and visible, and those housings on newer trucks, cars, and bikes that are designed for/with LED's make use of them quite well. But when a housing designed for an incandescent bulb has an LED bulb put into it, I've never seen one that was an improvement in any way over the original bulb, and in most cases it's significantly less visible from most angles.
Old April 16th, 2009, 08:34 AM   #12
Nemy
Nemy's Avatar
ah good point, just realized that all the LED-specific housing is clear. Make's sense!
Old April 16th, 2009, 10:19 AM   #13
Rynownd
Rynownd's Avatar
I'm working towards all LEDs on my bike. Rear signals installed, front signals waiting for install, still lookin' for the right brake light. Then HIDs for the headlights when I can afford it both time and money wise.
Nice video tho!
http://www.southparkstudios.com/clips/224099
Rynownd is offline   Reply With Quote
Old April 19th, 2009, 05:20 AM   #14
Buffalony
Buffalony's Avatar
If anyone knows where to get some led cluster bulb replacements letmeknow
thanks
My Ninja's older step-brother BRad704 Pictures 30 March 21st, 2013 08:22 AM
What to check on older bikes? OCMagnum General Motorcycling Discussion 9 December 31st, 2012 12:09 PM
Why is everyone older and richer than me here?... 249cc Off-Topic 41 November 15th, 2012 12:04 AM
'08 or older ninjas? McLovin General Motorcycling Discussion 17 April 2nd, 2009 09:21 PM
Possibly getting an older 600 djpharoah General Motorcycling Discussion 7 March 1st, 2009 07:10 PM
