April 17th, 2014, 09:58 PM | #1 |
Join Date: Apr 2014 Motorcycle(s): kawasaki 250r Posts: 1
Unique problem with LED indicator/tail light
Hey everyone! New to the forum, thanks for having me.
I have just spent the last couple of days scouring the forum/google looking for a solution to this problem as well as double checking all my wiring/connections and have found nothing. Proud owner of a 2008 Ninja 250R, I have just replaced the front indicators with LED's as well as installing an integrated LED tail light. I installed an electronic flasher (tridon 2 prong) and a no cut diode kit from customLED. At first glance everything is functional, the indicators flash and the relay clicks just as it should except every 10 seconds or so it pauses or ticks double. Then every 30 seconds or so the indicator will just stay illuminated and the flasher will emit a beeping sound. This would be acceptable however as soon as I get the bike moving more than a few km/h it instantly does this and wont flash at all. When I installed the integrated tail light there was only a single cable for each indicator so I just connected those to the green wire in the bike without a resistor. Ive been scratching my head over this for hours, really hoping its something little thats easy to fix. Any possible solutions would be greatly appreciated. Thank you in advance for any responses!! |
April 17th, 2014, 10:03 PM | #2 |
Bad relay.
April 24th, 2014, 11:14 AM | #3 |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
Hey Bill. Welcome to the forums!
I recently started having the same problem. I haven't replaced my relay yet, but I agree with Alex. Most likely bad relay. |
April 24th, 2014, 12:45 PM | #4 |
Join Date: Oct 2013 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: 219
Agreed.
This is the relay I use and I have no problems at all what so ever. I would highly recommend it. http://www.superbrightleds.com/morei...asher/781/835/ Replace your current relay with that one and you should be all set. |
April 24th, 2014, 03:50 PM | #5 | |
April 25th, 2014, 07:17 AM | #6 |
Tail light flickering problem... | skilletmo | 2008 - 2012 Ninja 250R Tech Talk | 7 | August 9th, 2013 04:18 PM |
Signal indicator and tail light problems! | OfficerLove | 1986 - 2007 Ninja 250R Tech Talk | 5 | December 18th, 2011 02:59 PM |
