Old August 4th, 2009, 11:40 PM   #1
emt250
2 Wheel Newb
emt250's Avatar
Motorcycle(s): 2007 250r
GPS power draw
So I bought a Garmin Nuvi 260 and a RAM mount to use on my bike, and the manual says the GPS has a 5 W max usage. I read that there are around 60W or so to play with as far as accessories go. I shouldn't have any issues, should I?
Yes, this might be a stupid question and I probably should have done more research before hand, but the damage (to my wallet) is done so I was just looking for some actual wisdom on the subject.
This is the particular GPS.
http://www.amazon.com/Garmin-260-3-5.../dp/B000UU7ZPS
Any help would be appreciated. Also, if there are any well-written "how-to" guides to doing a 12v adaptor that'd be great.
"Always remember, your mind is like a parachute. It works best when not being eaten by zombies"
-Someone
emt250 is offline   Reply With Quote
Old August 4th, 2009, 11:45 PM   #2
You're OK, you'll have no issues adding a GPS to the electrical draw. I doubt it typically uses even that 5W, so you could put a whole phalanx of them on your handlebars if you felt the urge.
Old August 5th, 2009, 12:01 AM   #3
emt250
2 Wheel Newb
emt250's Avatar
much thanks Alex You always have the quickest replies.
-Someone
Old August 5th, 2009, 06:27 AM   #4
camaroz1985
camaroz1985's Avatar
Motorcycle(s): 2008 WR250R, 2006 Ural Raven (Sold), 2009 Versys Green (Sold), 2008 Ninja 250R Green (Sold)
You can use my DIY as a start, then add a 12V adapter to one of the fused circuits.
http://www.ninjette.org/forums/showthread.php?t=15388
camaroz1985 is offline   Reply With Quote
Old August 5th, 2009, 08:41 AM   #5
M
Motorcycle(s): Ninja 250 x2, Ninja 650R
GPS draw is milliwatts, less than 1w nominal.
M is offline   Reply With Quote
Old August 11th, 2009, 12:49 PM   #6
emt250
2 Wheel Newb
emt250's Avatar
So im pretty much a newb at wiring...well..anything. I was hoping to just add a 12v outlet to the accessory leads at the left of the front fork. Does it matter what gauge wire or what size/type of connectors i use? I think the waterproof plug im going to get from walmart has some wires already ready to go. Just need to figure out what goes where, really.
I was also considering just using some epoxy to essentially glue it under the left side of the gauge cluster instead of bolting it in. Thoughts? Oh, and would adding an inline fuse be a good idea too? TY if anyone gets to this.
-Someone
Convert USB cable to power GPS? setasai 2008 - 2012 Ninja 250R Farkles 11 August 17th, 2015 09:32 AM
2014 World Cup Draw rasta Off-Topic 12 December 11th, 2013 10:38 PM
Draw Something Jiggles Off-Topic 1 March 6th, 2012 09:57 AM
[topix.net] - Classics draw crowds Ninjette Newsbot Motorcycling News 0 September 4th, 2011 04:51 AM
[topix.net] - Luck of the draw Ninjette Newsbot Motorcycling News 0 May 21st, 2010 06:50 AM
