Old February 4th, 2014, 07:10 PM   #1
timone1002
timone1002's Avatar
Motorcycle(s): ninja 250, used to own ninja zx6r, and drz 400 sm
Seat height for race bike
HI i was wondering if i could get some advice, i just bought new seat foam for my ninja 250 race bike (just the thin flat foam you see on motogp/ superbikes) and was going to replace the foam on the stock seat i have with it for better feel since the new foam is alot harder and thinner, but when i took apart the stock seat, the foam on the seat was a lot thiker than i thought it was and takes up most of the seats shape (see picture) so if i put the new foam on, it would lower the ride height by 2 or 3 inches. is till havent figured out how to attach the new foam. i was wondering if this would be better/ worse for the handling of the bike to have my weight lower on the bike?
thanks
timone1002 is offline   Reply With Quote
Old February 4th, 2014, 07:17 PM   #2
timone1002
timone1002's Avatar
Old February 4th, 2014, 07:18 PM   #3
timone1002
timone1002's Avatar
okay i was just looking up center of gravity, and a lower seat height lowers the center of gravity and a lower center of gravity makes for sharper turning, so maybe the bike will handle better?
Old February 4th, 2014, 07:26 PM   #4
broken neck
Motorcycle(s): 2011 Ninja 250R Special Edition (sold), 2017 CRF250 Rally
The only drawback would be your leg room with the thinner seat...
As long as you still feel comfortable and not cramped with it, it can't be bad as you wrote...
broken neck is offline   Reply With Quote
Old February 4th, 2014, 07:38 PM   #5
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
The foam they sell for race bikes is meant to go on "superbike" race bodywork, which is effectively the same shape and height as the stock seat, but in fiberglass. A superbike tail replaces both your tail section and your seat.
A typical sbk tail vs. a standard race tail that uses the stock seat (representative only... the SBK tail is not a Ninjette part):
I don't think you can use that sheet of foam on your stock seat pan... Doesn't it have various lumps and projections all over it that allow the stock foam to be located positively?
Don't forget that if you remove two inches of stock seat foam and lower yourself down, the bike's ergonomics are going to change radically. If you've got rearsets you might find they're now way too high. The tank will also seem to be much taller and the handlebars will seem higher as well.
A lower seat will indeed make the bike rotate around its longitudinal axis faster... less rotational inertia.
Old February 4th, 2014, 07:40 PM   #6
they make glue in a can. you spray it onto the foam then spray it onto the seat. let it sit a minute then stick them together. you buy it at the upholstery store. i think its called spray-on upholstery glue.
Old February 4th, 2014, 07:41 PM   #7
timone1002
timone1002's Avatar
Yeah I was thinking about attaching the foam to the stock plastic seat. But I haven't figured out how yet as it has bumps too
Old February 4th, 2014, 07:42 PM   #8
timone1002
timone1002's Avatar
Yeah I think the foam has adhesive on the bottom
Old February 4th, 2014, 07:43 PM   #9
mgentz
Board Member
buy thicker foam and shave it. dirt bike guys do this all the time.
Old February 4th, 2014, 07:47 PM   #10
timone1002
timone1002's Avatar
i imagine having the weight lower on the bike will tkae more weight off the front in hard breaking, so it will probobly change the compression and feel of the front going into turns. i wonder if this will be bad or good
Old February 4th, 2014, 09:54 PM   #11
timone1002
timone1002's Avatar
i think what ive decided to do is to attatch the foam to the fron tof the plastic seat with glue or some other method, and since the foam is small im going to use the back of the normal foam as the back of the seat, also i was sitting on my bike with just the plastic seat and i have short legs so it felt comfertable but the bars did seem a little high, so i was thinking about taking off the clip ons and putting them under the tripple clamp, as the triple clamp is as about as thick as the foam seat so it should even out, i think this combined with a lower seat will make the bike alot more ergonomic for racing since i will be closer and farther down on the bike for cornering both my upper and lower body.
what do you guys think?
Old February 5th, 2014, 04:56 AM   #12
mgentz
Board Member
Be careful of the bars hitting the bodywork. You may also run into legroom issues.
Old February 10th, 2014, 12:12 PM   #13
shane liberty
shane liberty's Avatar
Motorcycle(s): None Yet
What I would recommend is that you fiberglass a new seat pan that will add some height to your seat and allow you to stick the race pad to it.
Just a question. Why did you remove the stock seat? Speaking as someone who raced with a super bike tail in the past I can tell you there's nothing nice about running the thin foam pad. The stock seat is great for racing and it doesn't tire you out nearly as much after several laps from all of the vibration a thin pad would do. We only sit on the seat in the straights anyway so it's not like there's much advantage to running a less comfortable seat.
shane liberty is offline   Reply With Quote
Old February 13th, 2014, 10:15 AM   #14
Dmented
CVMA#747 Ⓓⓜⓔⓝⓣⓔⓓ ⓡⓐⓒⓘⓝⓖ
Dmented's Avatar
Motorcycle(s): 09 250R * 09 Yamaha R6 * 08 CBR 1000RR * 04 NSR 50 * 02 KX 250
I agree... I tried a thinned out seat before. just hurt my knees more since the pegs are so high.
**CVMA#747**AFM#747R**M1GP#77**LeoVince*RaceTech*Hotbodies*Cyclemall*Bridgestone *
Motorad*Dainese*PolyMoto*Woodcraft**Visit The Dmented Racing Youtube Channel*
Dmented is offline   Reply With Quote
Old February 13th, 2014, 10:16 AM   #15
Dmented
Dmented's Avatar
...p.s.
you wouldn't want to lower the pegs either. FOR OBVIOUS REASONS.
Old February 13th, 2014, 10:22 AM   #16
timone1002
timone1002's Avatar
yeah luckily im pretty short so it feels comfortable, though the fairings are in the way of the lower handle bars, i was thinking about cutting the fairings so my hands will fit, but idk if that will be race legal, i will post some pictures when im done, im hoping to have my hands fit like they do on moto 3 bikes between the fairings: https://www.google.com/search?q=moto...ke%3B950%3B534 but currently the fairings attactch to the gas tank which is where it hits, but i dont think removing the upper part of the fairing will reduce aerodynamics
Old February 13th, 2014, 11:12 AM   #17
Dmented
Dmented's Avatar
lotta guy's round here cut thier fairings to make it all work.
Old February 16th, 2014, 04:07 PM   #18
RacerX113
Motorcycle(s): Triumph Thruxton, Ninja 250
My clipons had clearance issues with the race fairing so I trimmed it up. No problem in WERA, shouldn't be an issue.
RacerX113 is offline   Reply With Quote
Old February 21st, 2014, 11:14 AM   #19
Xtina
Xtina's Avatar
Motorcycle(s): 2013 Ninja 300, 2007 Gsxr 600, R6-sold :(
Why refoam the seat in the first place? Leave it stock
Xtina is offline   Reply With Quote
Seat height and width archaeofreak General Motorcycling Discussion 23 July 4th, 2017 11:07 PM
[RoadRUNNER] - MotoMojo: Seat Height & The Factors That Contribute To It Ninjette Newsbot Motorcycling News 0 December 3rd, 2014 03:12 AM
tires changed ride height mikedabike64 General Motorcycling Discussion 13 March 6th, 2014 11:06 AM
Adapting bike/suspension to my weight/height? peterpayne 1986 - 2007 Ninja 250R Tech Talk 5 July 28th, 2013 07:49 AM
Height and Comfort mSoueiD General Motorcycling Discussion 13 July 17th, 2010 02:42 PM
