Old June 26th, 2013, 02:01 PM   #1
tsdexter
Motorcycle(s): 2008 Ninja 250R - Kawi Green
Removing spark spark plugs?
How easily should the rubber plug/cap be to remove from the motor...I pulled it upward a bit and it wouldn't come out... Is there a lock or anything to it of some trick to get it off? I didn't want to ruin anything so I stopped when it didn't come right up easily..
tsdexter is offline   Reply With Quote
Old June 26th, 2013, 02:28 PM   #2
dino74
dino74's Avatar
Sometimes they can be pretty snug. Usually I'll twist them first then pull from the base.
CVMA #55
Old June 26th, 2013, 03:04 PM   #3
bkh2
bkh2's Avatar
Motorcycle(s): 2006 GSXR 750; 1983 CB750SC
It will be very difficult to remove the plugs if they have not been moved in a while (or ever). Just take your time and ease the cap out. Don't do what I did and apply extreme force, pop the thing off, but hit your hand really hard on surrounding objects.
bkh2 is offline   Reply With Quote
Old June 26th, 2013, 03:48 PM   #4
indr
Take the tank off. Grasp the frame and the plug cap with the same hand, and squeeze.
indr is offline   Reply With Quote
Changing Spark plugs w/o removing gas tank? ScorpionNinja 2008 - 2012 Ninja 250R Tech Talk 6 March 9th, 2016 09:12 PM
spark plugs jcsalazar 2008 - 2012 Ninja 250R Tech Talk 11 May 17th, 2015 08:44 AM
Spark Plugs.... DmbShn41 2008 - 2012 Ninja 250R Tech Talk 13 August 8th, 2014 04:13 AM
Spark plugs? corksil 2008 - 2012 Ninja 250R Tech Talk 12 October 1st, 2013 11:04 AM
Spark plugs Betlog 2008 - 2012 Ninja 250R Tech Talk 2 March 1st, 2010 10:59 PM
