Old August 24th, 2018, 06:14 PM   #1
patrickm15
Motorcycle(s): 2012 kawasaki ex 250 ninja 250r
2012 kawasaki ninja 250r low beam wont work and bulb isn't burned out and new relays
Hi i have a 2012 kawasaki ninja 250r and ive been having a problem with the low beam for awhile now where it wont turn on but high beam and running lights work currently the bike has a KT HID kit in it that i installed due to the cheap headlights it had before I have a decent knowledge of electrical work but cant seem to trace down where this issue lies the running lights work and the high beam and the bulb is definitely fine and i tried replacing the main relays and that didnt fix the issue its been having this issue since about 2 weeks after i got the bike in june the bike always had an issue with low beam randomly turning off or flashing badly and just finally stopped working entirely im wondering if its a bad wire somewhere or the high low switch but havent had a lot of time to look at it due to work and am not sure which wire to trace if needed thanks for any help.
patrickm15 is offline   Reply With Quote
Old August 25th, 2018, 02:54 PM   #2
Hi and Welcome Patrick!
How do you know HID bulb is fine? Did you test that bulb with different known-good ballast?
Intermittent failures are not relay-related as they typically are yes/no conditions. Sounds more like wiring or switch issues.
Remove HID kit and restore low-beam light and circuit to factory condition. I bet it'll work perfectly fine then.
Head light bulb burned out allanoue 2013 - 2017 Ninja 300 General Discussion 19 December 13th, 2014 12:57 AM
low beam or high beam brighter? only choose one passive101 General Motorcycling Discussion 3 July 26th, 2013 06:27 AM
Low Beam Bulb Died Falcor 2008 - 2012 Ninja 250R Tech Talk 10 November 20th, 2012 09:54 PM
Low Beam Bulb Replacement c_wang 2008 - 2012 Ninja 250R Tech Talk 4 October 15th, 2012 09:03 PM
High Beam wont work! StaylorT 2008 - 2012 Ninja 250R Tech Talk 5 May 20th, 2012 02:52 PM
